USB CDC_ACM uart example not working on nRF Connect SDK Toolchain v3.1.0
Hi Nordic,
        I try to print hello world from promicro(nrf52840).
        I am sure board is ok, because I test zephyr 4.2 cdc_acm example on it, and I can see /dev/ttyACM* & console output.
        But when I use nRF Connect SDK Toolchain v3.1.0 in vscode, there is no any /dev/ttyACM*.
        How can I use usb acm to print hellow world?
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_REGULATOR is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_MAIN_STACK_SIZE=1024
# CONFIG_MIPI_DSI is not set
# CONFIG_MODEM is not set
CONFIG_BOARD_REQUIRES_SERIAL_BACKEND_CDC_ACM=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_DEVICE_STACK=y
# CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT is not set
# CONFIG_USB_DEVICE_REMOTE_WAKEUP is not set
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=4000
CONFIG_FLASH_LOAD_OFFSET=0x26000
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_CLOCK_CONTROL=y
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_KERNEL_ENTRY="__start"
CONFIG_BUILD_OUTPUT_BIN=y
CONFIG_XIP=y
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
# CONFIG_COUNTER is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
# CONFIG_FPU is not set
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_USE_DT_CODE_PARTITION=y
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_ZERO_LATENCY_IRQS is not set
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
# CONFIG_INIT_STACKS is not set
CONFIG_TIMESLICE_SIZE=20
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
# CONFIG_BUILD_OUTPUT_S19 is not set
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_FLASH is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_POWER_DOMAIN is not set
# CONFIG_MFD is not set
CONFIG_GPIO=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_SPI is not set
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_MEMC is not set
# CONFIG_CACHE is not set
CONFIG_LOG=y
CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_LOG_DOMAIN_NAME=""
# CONFIG_ASSERT is not set
# CONFIG_DEVICE_DEPS is not set
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
# CONFIG_SYSCON is not set
# CONFIG_WINSTREAM is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_GEN_SW_ISR_TABLE=y
# CONFIG_REBOOT is not set
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
# CONFIG_BOOTLOADER_MCUBOOT is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_KERNEL_MEM_POOL=y
CONFIG_MULTITHREADING=y
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_HFXO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
# end of Devicetree Info
# Modules
# CONFIG_BUILD_ONLY_NO_BLOBS is not set
# Available modules.
# nrf (/home/wols/ncs/v3.1.0/nrf)
# CONFIG_NRF_802154_RADIO_DRIVER is not set
CONFIG_LOG_BUFFER_SIZE=1024
CONFIG_MPSL_WORK_STACK_SIZE=1024
# CONFIG_ZMS is not set
# CONFIG_MBEDTLS is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NRF_SECURITY_ENABLER=y
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Subsystems
# Bootloader
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# BLE over nRF RPC
CONFIG_HEAP_MEM_POOL_SIZE=0
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# CONFIG_NRF_CLOUD is not set
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_DOWNLOADER is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_OFF is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_ERR is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_WRN is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_INF is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DBG is not set
CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DEFAULT=y
CONFIG_WIFI_PROV_CORE_LOG_LEVEL=3
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_NRF_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=25
CONFIG_MPSL_HFCLK_LATENCY=1400
CONFIG_MPSL_INIT_PRIORITY=40
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=3
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# Additional MCUmgr configuration
# Additional MCUmgr group configuration
# Additional MCUmgr OS group management functionality
# end of Additional MCUmgr OS group management functionality
# end of Additional MCUmgr group configuration
# end of Additional MCUmgr configuration
# CONFIG_CAF is not set
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_HSS is not set
# CONFIG_PSA_WANT_ALG_LMS is not set
# CONFIG_PSA_WANT_ALG_ML_DSA is not set
# CONFIG_PSA_WANT_ALG_XMSS is not set
# CONFIG_PSA_WANT_ALG_XMSS_MT is not set
# CONFIG_PSA_WANT_ALG_ML_KEM is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_AES_KW is not set
# CONFIG_PSA_WANT_ALG_AES_KWP is not set
# CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
# CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
# CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
# CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
# end of nRF Security
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
# Log levels
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_UART_ASYNC_ADAPTER is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
# CONFIG_LOG_FORWARDER_RPC is not set
# CONFIG_LOG_BACKEND_RPC is not set
# end of Logging over RPC
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
CONFIG_WFA_QT_LOG_LEVEL=3
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# CONFIG_APP_JWT is not set
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_AT_PARSER is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
# CONFIG_HW_UNIQUE_KEY_LOAD is not set
CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_FLASH_RPC is not set
CONFIG_HW_CC3XX=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# end of Device Drivers
# External libraries
# end of External libraries
# Test
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (/home/wols/ncs/v3.1.0/nrf)
# hostap (/home/wols/ncs/v3.1.0/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (/home/wols/ncs/v3.1.0/modules/lib/hostap)
# mcuboot (/home/wols/ncs/v3.1.0/bootloader/mcuboot)
# MCUboot
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (/home/wols/ncs/v3.1.0/bootloader/mcuboot)
# mbedtls (/home/wols/ncs/v3.1.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# end of mbedtls (/home/wols/ncs/v3.1.0/modules/crypto/mbedtls)
# oberon-psa-crypto (/home/wols/ncs/v3.1.0/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (/home/wols/ncs/v3.1.0/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (/home/wols/ncs/v3.1.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (/home/wols/ncs/v3.1.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
# cjson (/home/wols/ncs/v3.1.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (/home/wols/ncs/v3.1.0/modules/lib/cjson)
# azure-sdk-for-c (/home/wols/ncs/v3.1.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (/home/wols/ncs/v3.1.0/modules/lib/azure-sdk-for-c)
# cirrus-logic (/home/wols/ncs/v3.1.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (/home/wols/ncs/v3.1.0/modules/hal/cirrus-logic)
# openthread (/home/wols/ncs/v3.1.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (/home/wols/ncs/v3.1.0/modules/lib/openthread)
# memfault-firmware-sdk (/home/wols/ncs/v3.1.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (/home/wols/ncs/v3.1.0/modules/lib/memfault-firmware-sdk)
# coremark (/home/wols/ncs/v3.1.0/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (/home/wols/ncs/v3.1.0/modules/benchmark/coremark)
# canopennode (/home/wols/ncs/v3.1.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (/home/wols/ncs/v3.1.0/modules/lib/canopennode)
# chre (/home/wols/ncs/v3.1.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (/home/wols/ncs/v3.1.0/modules/lib/chre)
# lz4 (/home/wols/ncs/v3.1.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (/home/wols/ncs/v3.1.0/modules/lib/lz4)
# nanopb (/home/wols/ncs/v3.1.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (/home/wols/ncs/v3.1.0/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (/home/wols/ncs/v3.1.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (/home/wols/ncs/v3.1.0/modules/lib/zscilib)
# cmsis (/home/wols/ncs/v3.1.0/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
# end of cmsis (/home/wols/ncs/v3.1.0/modules/hal/cmsis)
# cmsis-dsp (/home/wols/ncs/v3.1.0/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (/home/wols/ncs/v3.1.0/modules/lib/cmsis-dsp)
# cmsis-nn (/home/wols/ncs/v3.1.0/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (/home/wols/ncs/v3.1.0/modules/lib/cmsis-nn)
# cmsis_6 (/home/wols/ncs/v3.1.0/modules/hal/cmsis_6)
CONFIG_ZEPHYR_CMSIS_6_MODULE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis_6 (/home/wols/ncs/v3.1.0/modules/hal/cmsis_6)
# fatfs (/home/wols/ncs/v3.1.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (/home/wols/ncs/v3.1.0/modules/fs/fatfs)
# hal_nordic (/home/wols/ncs/v3.1.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# nrfx drivers logging
# CONFIG_NRFX_CLOCK_LOG is not set
# CONFIG_NRFX_GPIOTE_LOG is not set
# CONFIG_NRFX_POWER_LOG is not set
# CONFIG_NRFX_PPI_LOG is not set
# end of nrfx drivers logging
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_CLOCK_LF_CAL_ENABLED is not set
# CONFIG_NRFX_CLOCK_LF_SRC_RC is not set
CONFIG_NRFX_CLOCK_LF_SRC_XTAL=y
# CONFIG_NRFX_CLOCK_LF_SRC_SYNTH is not set
# CONFIG_NRFX_CLOCK_LF_SRC_LOW_SWING is not set
# CONFIG_NRFX_CLOCK_LF_SRC_FULL_SWING is not set
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
CONFIG_NRFX_GPPI=y
# CONFIG_NRFX_I2S0 is not set
# CONFIG_NRFX_LPCOMP is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM0 is not set
CONFIG_NRFX_POWER=y
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
# CONFIG_NRFX_SPI2 is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SPIS0 is not set
# CONFIG_NRFX_SPIS1 is not set
# CONFIG_NRFX_SPIS2 is not set
# CONFIG_NRFX_SPIS3 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIS0 is not set
# CONFIG_NRFX_TWIS1 is not set
# CONFIG_NRFX_UART0 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
# end of hal_nordic (/home/wols/ncs/v3.1.0/modules/hal/nordic)
# hal_st (/home/wols/ncs/v3.1.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (/home/wols/ncs/v3.1.0/modules/hal/st)
# hal_tdk (/home/wols/ncs/v3.1.0/modules/hal/tdk)
CONFIG_ZEPHYR_HAL_TDK_MODULE=y
# TDK drivers
# CONFIG_TDK_HAL is not set
# end of TDK drivers
# end of hal_tdk (/home/wols/ncs/v3.1.0/modules/hal/tdk)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# liblc3 (/home/wols/ncs/v3.1.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (/home/wols/ncs/v3.1.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# littlefs (/home/wols/ncs/v3.1.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (/home/wols/ncs/v3.1.0/modules/fs/littlefs)
# loramac-node (/home/wols/ncs/v3.1.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (/home/wols/ncs/v3.1.0/modules/lib/loramac-node)
# lvgl (/home/wols/ncs/v3.1.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (/home/wols/ncs/v3.1.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
# nrf_wifi (/home/wols/ncs/v3.1.0/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
# CONFIG_NRF70_BUSLIB is not set
# end of nrf_wifi (/home/wols/ncs/v3.1.0/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# percepio (/home/wols/ncs/v3.1.0/modules/debug/percepio)
# Percepio Tracealyzer support can be enabled from the tracing subsystem
# CONFIG_PERCEPIO_DFM is not set
CONFIG_ZEPHYR_PERCEPIO_MODULE=y
# end of percepio (/home/wols/ncs/v3.1.0/modules/debug/percepio)
# picolibc (/home/wols/ncs/v3.1.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (/home/wols/ncs/v3.1.0/modules/lib/picolibc)
# segger (/home/wols/ncs/v3.1.0/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# end of segger (/home/wols/ncs/v3.1.0/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (/home/wols/ncs/v3.1.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (/home/wols/ncs/v3.1.0/modules/lib/uoscore-uedhoc)
# zcbor (/home/wols/ncs/v3.1.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (/home/wols/ncs/v3.1.0/modules/lib/zcbor)
# nrfxlib (/home/wols/ncs/v3.1.0/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_MPSL is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_HAS_HW_NRF_CC3XX=y
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (/home/wols/ncs/v3.1.0/nrfxlib)
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
# connectedhomeip (/home/wols/ncs/v3.1.0/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (/home/wols/ncs/v3.1.0/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_bouffalolab module not available.
# hal_gigadevice module not available.
# hal_nxp module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="promicro_nrf52840"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="promicro_nrf52840/nrf52840/uf2"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_PROMICRO_NRF52840=y
CONFIG_BOARD_PROMICRO_NRF52840_NRF52840_UF2=y
CONFIG_BOARD_QUALIFIERS="nrf52840/uf2"
# Board Options
CONFIG_BOARD_SERIAL_BACKEND_CDC_ACM=y
# CONFIG_BOARD_HAS_NRF5_BOOTLOADER is not set
# end of Board Options
# Hardware Configuration
CONFIG_SOC="nrf52840"
CONFIG_SOC_SERIES="nrf52"
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52840=y
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_ARMV8_1_M_PMU_EVENTCNT=8
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_TWI1=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_HAS_NORDIC_RAM_CTRL=y
# CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
# CONFIG_NRF_SYS_EVENT is not set
# CONFIG_NRF_PERIPHCONF_SECTION is not set
# CONFIG_GPIO_AS_PINRESET is not set
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0
CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# ARM Options
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_MPU_STACK_GUARD=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_ARM_MPU=y
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_USERSPACE is not set
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_ARCH_DEVICE_STATE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
# CONFIG_SCHED_DUMB is not set
CONFIG_SCHED_SIMPLE=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_DUMB is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_SIMPLE=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_BOOT_CLEAR_SCREEN is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_POLL is not set
# CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# MMU Features
# end of MMU Features
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_PREP_HOOK is not set
# CONFIG_SOC_EARLY_INIT_HOOK is not set
# CONFIG_SOC_LATE_INIT_HOOK is not set
# CONFIG_SOC_PER_CORE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_NRF2_COMMON is not set
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_DP_DRIVER is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
# CONFIG_ENTROPY_GENERATOR is not set
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_GPIO_RA_HAS_VBTICTLR is not set
# CONFIG_HAPTICS is not set
CONFIG_HWINFO=y
# CONFIG_HWINFO_LOG_LEVEL_OFF is not set
# CONFIG_HWINFO_LOG_LEVEL_ERR is not set
# CONFIG_HWINFO_LOG_LEVEL_WRN is not set
# CONFIG_HWINFO_LOG_LEVEL_INF is not set
# CONFIG_HWINFO_LOG_LEVEL_DBG is not set
CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
CONFIG_HWINFO_LOG_LEVEL=3
CONFIG_HWINFO_HAS_DRIVER=y
CONFIG_HWINFO_NRF=y
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=3
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MBOX is not set
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
CONFIG_PINCTRL=y
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
# CONFIG_PINCTRL_NPCX_EX is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
CONFIG_SERIAL_INIT_PRIORITY=50
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
# CONFIG_UART_LOG_LEVEL_INF is not set
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL_DEFAULT=y
CONFIG_UART_LOG_LEVEL=3
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
# CONFIG_UART_NATIVE_POSIX is not set
CONFIG_UART_NRFX=y
CONFIG_UART_NRFX_UARTE=y
CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
# CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set
CONFIG_UART_0_INTERRUPT_DRIVEN=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
# CONFIG_SMBUS is not set
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
CONFIG_CORTEX_M_SYSTICK_LPM_TIMER_NONE=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
# CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
# CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_DEFAULT is not set
CONFIG_USB_DRIVER_LOG_LEVEL=1
# USB common
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
CONFIG_NRF_USBD_COMMON=y
CONFIG_NRF_USBD_ISO_IN_ZLP=y
# end of USB common
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTIO is not set
# CONFIG_VIRTIO_LOG_LEVEL_OFF is not set
# CONFIG_VIRTIO_LOG_LEVEL_ERR is not set
# CONFIG_VIRTIO_LOG_LEVEL_WRN is not set
# CONFIG_VIRTIO_LOG_LEVEL_INF is not set
# CONFIG_VIRTIO_LOG_LEVEL_DBG is not set
CONFIG_VIRTIO_LOG_LEVEL_DEFAULT=y
CONFIG_VIRTIO_LOG_LEVEL=3
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_COMMON_LIBC_REMOVE is not set
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
# CONFIG_CRC is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
CONFIG_SYS_HEAP_ARRAY_SIZE=0
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
# CONFIG_NET_BUF is not set
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
# CONFIG_POSIX_C_LIB_EXT is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM_R is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
# CONFIG_POSIX_TIMERS is not set
# X/Open system interfaces
# CONFIG_XSI_REALTIME is not set
# CONFIG_XSI_SINGLE_PROCESS is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_OFF is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_ERR is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_WRN is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_INF is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DBG is not set
CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DEFAULT=y
CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL=3
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
# CONFIG_RING_BUFFER_LARGE is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_UTF8 is not set
# CONFIG_COBS is not set
# end of Utility Library
# Universally Unique Identifier (UUID)
# CONFIG_UUID is not set
# end of Universally Unique Identifier (UUID)
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_DAP is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_UBSAN is not set
# CONFIG_STACK_USAGE is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
# CONFIG_CPU_LOAD is not set
CONFIG_CPU_LOAD_LOG_PERIODICALLY=0
# CONFIG_CPU_LOAD_LOG_LEVEL_OFF is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_ERR is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_WRN is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_INF is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_DBG is not set
CONFIG_CPU_LOAD_LOG_LEVEL_DEFAULT=y
CONFIG_CPU_LOAD_LOG_LEVEL=3
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM_LIB_LINK is not set
# CONFIG_FILE_SYSTEM is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# CONFIG_LLEXT_EDK is not set
# Logging
CONFIG_LOG_CORE_INIT_PRIORITY=0
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_FRONTEND_OPT_API is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
CONFIG_LOG_FLUSH_SLEEP_US=10000
# Logging levels filtering
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_THREAD_ID_PREFIX is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
# CONFIG_LOG_DBG_COLOR_BLUE is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_SWO is not set
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
CONFIG_LOG_BACKEND_UART_AUTOSTART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_FMT_STRING_VALIDATE is not set
# CONFIG_LOG_MEM_UTILIZATION is not set
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_RATELIMIT=y
CONFIG_LOG_RATELIMIT_INTERVAL_MS=5000
CONFIG_LOG_OUTPUT=y
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# end of Power Management
# Platform Management Communication Infrastruction (PMCI)
# CONFIG_MCTP is not set
# end of Platform Management Communication Infrastruction (PMCI)
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
CONFIG_CSPRNG_AVAILABLE=y
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SECURE_STORAGE is not set
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
# CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DEFAULT is not set
CONFIG_USB_DEVICE_LOG_LEVEL=1
CONFIG_USB_DEVICE_VID=0x2FE3
CONFIG_USB_DEVICE_PID=0x0001
CONFIG_USB_DEVICE_MANUFACTURER="ZEPHYR"
CONFIG_USB_DEVICE_PRODUCT="Zephyr CDC ACM sample"
CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
# CONFIG_USB_CONFIGURATION_STRING_DESC_ENABLE is not set
CONFIG_USB_COMPOSITE_DEVICE=y
CONFIG_USB_MAX_NUM_TRANSFERS=4
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
CONFIG_USB_WORKQUEUE=y
CONFIG_USB_WORKQUEUE_STACK_SIZE=1024
CONFIG_USB_WORKQUEUE_PRIORITY=-1
# USB CDC ACM Class support
CONFIG_USB_CDC_ACM=y
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=1024
CONFIG_CDC_ACM_INTERRUPT_EP_MPS=16
CONFIG_CDC_ACM_BULK_EP_MPS=64
CONFIG_CDC_ACM_TX_DELAY_MS=100
CONFIG_CDC_ACM_IAD=y
# CONFIG_CDC_ACM_DTE_RATE_CALLBACK_SUPPORT is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF=y
# CONFIG_USB_CDC_ACM_LOG_LEVEL_ERR is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_WRN is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_INF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DBG is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DEFAULT is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL=0
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_FLASH_LOAD_SIZE=0xc6000
CONFIG_ROM_END_OFFSET=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_DEPRECATION_TEST is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_UF2=y
# CONFIG_BUILD_OUTPUT_MOT is not set
CONFIG_BUILD_OUTPUT_UF2_FAMILY_ID="0xada52840"
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
# end of Compatibility
0246.zephyr.dts
nRF Connect: Build: samples/subsys/usb/cdc_acm/cdc_acm (active)
Building cdc_acm
west build --build-dir /home/wols/ncs/v3.1.0/zephyr/samples/subsys/usb/cdc_acm/build --domain cdc_acm
-- west build: building domain(s): cdc_acm
ninja: no work to do.
  • I found that not work example .confing has more two setting
    No idea where it came from and how to disable it, since I use default setting.
  • Remember that there is an USB dongle with the NRF52840 MCU, and that one uses a bootloader and thus an unusual flash layout (that won't work without that loader present).
    This one sample project might be set up for this hardware by default.
    Compare EVERYTHING that changes between your working and the non-working sample codes. The base Zephyr sample code is very often set up for different hardware, remember that the Zephyr RTOS supports a TON of other MCUs.
    "Copy a sample" in VS code nordic plugin should have worked if -and only if- you selected the NRF/nordic USB sample code (and not the zephyr sample). May need reading fine print.
  • NRF/nordic USB sample code dosen't enable CONFIG_PARTITION_MANAGER_ENABLED.
    But zephyr sample does.
    In NRF/nordic USB cdc acm sample, no main.c, kconfig require  zephyr sample does, prj.conf same as zephyr sample does.
    I have no idea why copy from will cause CONFIG_PARTITION_MANAGER_ENABLED
    I guess the issue is that when you try the zephyr sample, the sample expects your board to already enable USBD and if those aren't enabled for your Pro Micro board. the you might get the /dev/ttyACM*.
    Could you tell me what build command you give? i.e. try building for the correct board, say, west build -b promicro_nrf52840
    -Priyanka
  • This is not work build command
    nRF Connect: Generate config promicro_nrf52840/nrf52840/uf2 for /home/wols/Documents/GitHub/BtnSync
    Building BtnSync
    west build --build-dir /home/wols/Documents/GitHub/BtnSync/build /home/wols/Documents/GitHub/BtnSync --pristine --board promicro_nrf52840/nrf52840/uf2 -- -DCONF_FILE="prj.conf" -DDTC_OVERLAY_FILE="app.overlay"
    Here is working build command
    Building BtnSync
    west build --build-dir /home/wols/Documents/GitHub/BtnSync/build /home/wols/Documents/GitHub/BtnSync --pristine --board promicro_nrf52840/nrf52840/uf2 --no-sysbuild -- -DCONF_FILE="prj.conf" -DDTC_OVERLAY_FILE="app.overlay"
    I guess the issue is because you mixed two bootloaders by accident, i.e. from your command, the board target promicro_nrf52840/nrf52840/uf2 assumes the UF2 bootloader is on the chip. Also, when you use sysbuild, this adds the MCUBoot. And this confusion (MCUBoot+UF2) will cause the app to be placed incorrectly and thus it never runs. This is why you don't see any /dev/ttyACM*.
    Hence, not using sysbuild helps in running it correctly.
    Or if you need sysbuild, then you could change the target to promicro_nrf52840/nrf52840
    -Priyanka
    -Priyanka
