USB CDC_ACM uart example not working on nRF Connect SDK Toolchain v3.1.0
Hi Nordic,
        I try to print hello world from promicro(nrf52840).
        I am sure board is ok, because I test zephyr 4.2 cdc_acm example on it, and I can see /dev/ttyACM* & console output.
        But when I use nRF Connect SDK Toolchain v3.1.0 in vscode, there is no any /dev/ttyACM*.
        How can I use usb acm to print hellow world?
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_REGULATOR is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_MAIN_STACK_SIZE=1024
# CONFIG_MIPI_DSI is not set
# CONFIG_MODEM is not set
CONFIG_BOARD_REQUIRES_SERIAL_BACKEND_CDC_ACM=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_DEVICE_STACK=y
# CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT is not set
# CONFIG_USB_DEVICE_REMOTE_WAKEUP is not set
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=4000
CONFIG_FLASH_LOAD_OFFSET=0x26000
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_CLOCK_CONTROL=y
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_KERNEL_ENTRY="__start"
CONFIG_BUILD_OUTPUT_BIN=y
CONFIG_XIP=y
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
# CONFIG_COUNTER is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
# CONFIG_FPU is not set
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_USE_DT_CODE_PARTITION=y
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_ZERO_LATENCY_IRQS is not set
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
# CONFIG_INIT_STACKS is not set
CONFIG_TIMESLICE_SIZE=20
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
# CONFIG_BUILD_OUTPUT_S19 is not set
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_FLASH is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_POWER_DOMAIN is not set
# CONFIG_MFD is not set
CONFIG_GPIO=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_SPI is not set
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_MEMC is not set
# CONFIG_CACHE is not set
CONFIG_LOG=y
CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_LOG_DOMAIN_NAME=""
# CONFIG_ASSERT is not set
# CONFIG_DEVICE_DEPS is not set
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
# CONFIG_SYSCON is not set
# CONFIG_WINSTREAM is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_GEN_SW_ISR_TABLE=y
# CONFIG_REBOOT is not set
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
# CONFIG_BOOTLOADER_MCUBOOT is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_KERNEL_MEM_POOL=y
CONFIG_MULTITHREADING=y
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_HFXO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
# end of Devicetree Info
# Modules
# CONFIG_BUILD_ONLY_NO_BLOBS is not set
# Available modules.
# nrf (/home/wols/ncs/v3.1.0/nrf)
# CONFIG_NRF_802154_RADIO_DRIVER is not set
CONFIG_LOG_BUFFER_SIZE=1024
CONFIG_MPSL_WORK_STACK_SIZE=1024
# CONFIG_ZMS is not set
# CONFIG_MBEDTLS is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NRF_SECURITY_ENABLER=y
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Subsystems
# Bootloader
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# BLE over nRF RPC
CONFIG_HEAP_MEM_POOL_SIZE=0
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# CONFIG_NRF_CLOUD is not set
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_DOWNLOADER is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_OFF is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_ERR is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_WRN is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_INF is not set
# CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DBG is not set
CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DEFAULT=y
CONFIG_WIFI_PROV_CORE_LOG_LEVEL=3
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_NRF_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=25
CONFIG_MPSL_HFCLK_LATENCY=1400
CONFIG_MPSL_INIT_PRIORITY=40
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=3
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# Additional MCUmgr configuration
# Additional MCUmgr group configuration
# Additional MCUmgr OS group management functionality
# end of Additional MCUmgr OS group management functionality
# end of Additional MCUmgr group configuration
# end of Additional MCUmgr configuration
# CONFIG_CAF is not set
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_HSS is not set
# CONFIG_PSA_WANT_ALG_LMS is not set
# CONFIG_PSA_WANT_ALG_ML_DSA is not set
# CONFIG_PSA_WANT_ALG_XMSS is not set
# CONFIG_PSA_WANT_ALG_XMSS_MT is not set
# CONFIG_PSA_WANT_ALG_ML_KEM is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_AES_KW is not set
# CONFIG_PSA_WANT_ALG_AES_KWP is not set
# CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
# CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
# CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
# CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
# end of nRF Security
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
# Log levels
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_UART_ASYNC_ADAPTER is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
# CONFIG_LOG_FORWARDER_RPC is not set
# CONFIG_LOG_BACKEND_RPC is not set
# end of Logging over RPC
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
CONFIG_WFA_QT_LOG_LEVEL=3
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# CONFIG_APP_JWT is not set
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_AT_PARSER is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
# CONFIG_HW_UNIQUE_KEY_LOAD is not set
CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_FLASH_RPC is not set
CONFIG_HW_CC3XX=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# end of Device Drivers
# External libraries
# end of External libraries
# Test
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (/home/wols/ncs/v3.1.0/nrf)
# hostap (/home/wols/ncs/v3.1.0/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (/home/wols/ncs/v3.1.0/modules/lib/hostap)
# mcuboot (/home/wols/ncs/v3.1.0/bootloader/mcuboot)
# MCUboot
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (/home/wols/ncs/v3.1.0/bootloader/mcuboot)
# mbedtls (/home/wols/ncs/v3.1.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# end of mbedtls (/home/wols/ncs/v3.1.0/modules/crypto/mbedtls)
# oberon-psa-crypto (/home/wols/ncs/v3.1.0/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (/home/wols/ncs/v3.1.0/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (/home/wols/ncs/v3.1.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (/home/wols/ncs/v3.1.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
# cjson (/home/wols/ncs/v3.1.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (/home/wols/ncs/v3.1.0/modules/lib/cjson)
# azure-sdk-for-c (/home/wols/ncs/v3.1.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (/home/wols/ncs/v3.1.0/modules/lib/azure-sdk-for-c)
# cirrus-logic (/home/wols/ncs/v3.1.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (/home/wols/ncs/v3.1.0/modules/hal/cirrus-logic)
# openthread (/home/wols/ncs/v3.1.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (/home/wols/ncs/v3.1.0/modules/lib/openthread)
# memfault-firmware-sdk (/home/wols/ncs/v3.1.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (/home/wols/ncs/v3.1.0/modules/lib/memfault-firmware-sdk)
# coremark (/home/wols/ncs/v3.1.0/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (/home/wols/ncs/v3.1.0/modules/benchmark/coremark)
# canopennode (/home/wols/ncs/v3.1.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (/home/wols/ncs/v3.1.0/modules/lib/canopennode)
# chre (/home/wols/ncs/v3.1.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (/home/wols/ncs/v3.1.0/modules/lib/chre)
# lz4 (/home/wols/ncs/v3.1.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (/home/wols/ncs/v3.1.0/modules/lib/lz4)
# nanopb (/home/wols/ncs/v3.1.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (/home/wols/ncs/v3.1.0/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (/home/wols/ncs/v3.1.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (/home/wols/ncs/v3.1.0/modules/lib/zscilib)
# cmsis (/home/wols/ncs/v3.1.0/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
# end of cmsis (/home/wols/ncs/v3.1.0/modules/hal/cmsis)
# cmsis-dsp (/home/wols/ncs/v3.1.0/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (/home/wols/ncs/v3.1.0/modules/lib/cmsis-dsp)
# cmsis-nn (/home/wols/ncs/v3.1.0/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (/home/wols/ncs/v3.1.0/modules/lib/cmsis-nn)
# cmsis_6 (/home/wols/ncs/v3.1.0/modules/hal/cmsis_6)
CONFIG_ZEPHYR_CMSIS_6_MODULE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis_6 (/home/wols/ncs/v3.1.0/modules/hal/cmsis_6)
# fatfs (/home/wols/ncs/v3.1.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (/home/wols/ncs/v3.1.0/modules/fs/fatfs)
# hal_nordic (/home/wols/ncs/v3.1.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# nrfx drivers logging
# CONFIG_NRFX_CLOCK_LOG is not set
# CONFIG_NRFX_GPIOTE_LOG is not set
# CONFIG_NRFX_POWER_LOG is not set
# CONFIG_NRFX_PPI_LOG is not set
# end of nrfx drivers logging
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_CLOCK_LF_CAL_ENABLED is not set
# CONFIG_NRFX_CLOCK_LF_SRC_RC is not set
CONFIG_NRFX_CLOCK_LF_SRC_XTAL=y
# CONFIG_NRFX_CLOCK_LF_SRC_SYNTH is not set
# CONFIG_NRFX_CLOCK_LF_SRC_LOW_SWING is not set
# CONFIG_NRFX_CLOCK_LF_SRC_FULL_SWING is not set
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
CONFIG_NRFX_GPPI=y
# CONFIG_NRFX_I2S0 is not set
# CONFIG_NRFX_LPCOMP is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM0 is not set
CONFIG_NRFX_POWER=y
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
# CONFIG_NRFX_SPI2 is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SPIS0 is not set
# CONFIG_NRFX_SPIS1 is not set
# CONFIG_NRFX_SPIS2 is not set
# CONFIG_NRFX_SPIS3 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIS0 is not set
# CONFIG_NRFX_TWIS1 is not set
# CONFIG_NRFX_UART0 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
# end of hal_nordic (/home/wols/ncs/v3.1.0/modules/hal/nordic)
# hal_st (/home/wols/ncs/v3.1.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (/home/wols/ncs/v3.1.0/modules/hal/st)
# hal_tdk (/home/wols/ncs/v3.1.0/modules/hal/tdk)
CONFIG_ZEPHYR_HAL_TDK_MODULE=y
# TDK drivers
# CONFIG_TDK_HAL is not set
# end of TDK drivers
# end of hal_tdk (/home/wols/ncs/v3.1.0/modules/hal/tdk)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# liblc3 (/home/wols/ncs/v3.1.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (/home/wols/ncs/v3.1.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# littlefs (/home/wols/ncs/v3.1.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (/home/wols/ncs/v3.1.0/modules/fs/littlefs)
# loramac-node (/home/wols/ncs/v3.1.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (/home/wols/ncs/v3.1.0/modules/lib/loramac-node)
# lvgl (/home/wols/ncs/v3.1.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (/home/wols/ncs/v3.1.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
# nrf_wifi (/home/wols/ncs/v3.1.0/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
# CONFIG_NRF70_BUSLIB is not set
# end of nrf_wifi (/home/wols/ncs/v3.1.0/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# percepio (/home/wols/ncs/v3.1.0/modules/debug/percepio)
# Percepio Tracealyzer support can be enabled from the tracing subsystem
# CONFIG_PERCEPIO_DFM is not set
CONFIG_ZEPHYR_PERCEPIO_MODULE=y
# end of percepio (/home/wols/ncs/v3.1.0/modules/debug/percepio)
# picolibc (/home/wols/ncs/v3.1.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (/home/wols/ncs/v3.1.0/modules/lib/picolibc)
# segger (/home/wols/ncs/v3.1.0/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# end of segger (/home/wols/ncs/v3.1.0/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (/home/wols/ncs/v3.1.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (/home/wols/ncs/v3.1.0/modules/lib/uoscore-uedhoc)
# zcbor (/home/wols/ncs/v3.1.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (/home/wols/ncs/v3.1.0/modules/lib/zcbor)
# nrfxlib (/home/wols/ncs/v3.1.0/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_MPSL is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_HAS_HW_NRF_CC3XX=y
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (/home/wols/ncs/v3.1.0/nrfxlib)
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
# connectedhomeip (/home/wols/ncs/v3.1.0/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (/home/wols/ncs/v3.1.0/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_bouffalolab module not available.
# hal_gigadevice module not available.
# hal_nxp module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="promicro_nrf52840"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="promicro_nrf52840/nrf52840/uf2"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_PROMICRO_NRF52840=y
CONFIG_BOARD_PROMICRO_NRF52840_NRF52840_UF2=y
CONFIG_BOARD_QUALIFIERS="nrf52840/uf2"
# Board Options
CONFIG_BOARD_SERIAL_BACKEND_CDC_ACM=y
# CONFIG_BOARD_HAS_NRF5_BOOTLOADER is not set
# end of Board Options
# Hardware Configuration
CONFIG_SOC="nrf52840"
CONFIG_SOC_SERIES="nrf52"
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52840=y
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_ARMV8_1_M_PMU_EVENTCNT=8
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_TWI1=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_HAS_NORDIC_RAM_CTRL=y
# CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
# CONFIG_NRF_SYS_EVENT is not set
# CONFIG_NRF_PERIPHCONF_SECTION is not set
# CONFIG_GPIO_AS_PINRESET is not set
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0
CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# ARM Options
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_MPU_STACK_GUARD=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_ARM_MPU=y
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_USERSPACE is not set
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_ARCH_DEVICE_STATE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
# CONFIG_SCHED_DUMB is not set
CONFIG_SCHED_SIMPLE=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_DUMB is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_SIMPLE=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_BOOT_CLEAR_SCREEN is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_POLL is not set
# CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# MMU Features
# end of MMU Features
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_PREP_HOOK is not set
# CONFIG_SOC_EARLY_INIT_HOOK is not set
# CONFIG_SOC_LATE_INIT_HOOK is not set
# CONFIG_SOC_PER_CORE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_NRF2_COMMON is not set
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_DP_DRIVER is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
# CONFIG_ENTROPY_GENERATOR is not set
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_GPIO_RA_HAS_VBTICTLR is not set
# CONFIG_HAPTICS is not set
CONFIG_HWINFO=y
# CONFIG_HWINFO_LOG_LEVEL_OFF is not set
# CONFIG_HWINFO_LOG_LEVEL_ERR is not set
# CONFIG_HWINFO_LOG_LEVEL_WRN is not set
# CONFIG_HWINFO_LOG_LEVEL_INF is not set
# CONFIG_HWINFO_LOG_LEVEL_DBG is not set
CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
CONFIG_HWINFO_LOG_LEVEL=3
CONFIG_HWINFO_HAS_DRIVER=y
CONFIG_HWINFO_NRF=y
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=3
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MBOX is not set
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
CONFIG_PINCTRL=y
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
# CONFIG_PINCTRL_NPCX_EX is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
CONFIG_SERIAL_INIT_PRIORITY=50
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
# CONFIG_UART_LOG_LEVEL_INF is not set
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL_DEFAULT=y
CONFIG_UART_LOG_LEVEL=3
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
# CONFIG_UART_NATIVE_POSIX is not set
CONFIG_UART_NRFX=y
CONFIG_UART_NRFX_UARTE=y
CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
# CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set
CONFIG_UART_0_INTERRUPT_DRIVEN=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
# CONFIG_SMBUS is not set
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
CONFIG_CORTEX_M_SYSTICK_LPM_TIMER_NONE=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
# CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
# CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_DEFAULT is not set
CONFIG_USB_DRIVER_LOG_LEVEL=1
# USB common
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
CONFIG_NRF_USBD_COMMON=y
CONFIG_NRF_USBD_ISO_IN_ZLP=y
# end of USB common
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTIO is not set
# CONFIG_VIRTIO_LOG_LEVEL_OFF is not set
# CONFIG_VIRTIO_LOG_LEVEL_ERR is not set
# CONFIG_VIRTIO_LOG_LEVEL_WRN is not set
# CONFIG_VIRTIO_LOG_LEVEL_INF is not set
# CONFIG_VIRTIO_LOG_LEVEL_DBG is not set
CONFIG_VIRTIO_LOG_LEVEL_DEFAULT=y
CONFIG_VIRTIO_LOG_LEVEL=3
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_COMMON_LIBC_REMOVE is not set
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
# CONFIG_CRC is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
CONFIG_SYS_HEAP_ARRAY_SIZE=0
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
# CONFIG_NET_BUF is not set
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
# CONFIG_POSIX_C_LIB_EXT is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM_R is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
# CONFIG_POSIX_TIMERS is not set
# X/Open system interfaces
# CONFIG_XSI_REALTIME is not set
# CONFIG_XSI_SINGLE_PROCESS is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_OFF is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_ERR is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_WRN is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_INF is not set
# CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DBG is not set
CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DEFAULT=y
CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL=3
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
# CONFIG_RING_BUFFER_LARGE is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_UTF8 is not set
# CONFIG_COBS is not set
# end of Utility Library
# Universally Unique Identifier (UUID)
# CONFIG_UUID is not set
# end of Universally Unique Identifier (UUID)
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_DAP is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_UBSAN is not set
# CONFIG_STACK_USAGE is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
# CONFIG_CPU_LOAD is not set
CONFIG_CPU_LOAD_LOG_PERIODICALLY=0
# CONFIG_CPU_LOAD_LOG_LEVEL_OFF is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_ERR is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_WRN is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_INF is not set
# CONFIG_CPU_LOAD_LOG_LEVEL_DBG is not set
CONFIG_CPU_LOAD_LOG_LEVEL_DEFAULT=y
CONFIG_CPU_LOAD_LOG_LEVEL=3
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM_LIB_LINK is not set
# CONFIG_FILE_SYSTEM is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# CONFIG_LLEXT_EDK is not set
# Logging
CONFIG_LOG_CORE_INIT_PRIORITY=0
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_FRONTEND_OPT_API is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
CONFIG_LOG_FLUSH_SLEEP_US=10000
# Logging levels filtering
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_THREAD_ID_PREFIX is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
# CONFIG_LOG_DBG_COLOR_BLUE is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_SWO is not set
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
CONFIG_LOG_BACKEND_UART_AUTOSTART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_FMT_STRING_VALIDATE is not set
# CONFIG_LOG_MEM_UTILIZATION is not set
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_RATELIMIT=y
CONFIG_LOG_RATELIMIT_INTERVAL_MS=5000
CONFIG_LOG_OUTPUT=y
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# end of Power Management
# Platform Management Communication Infrastruction (PMCI)
# CONFIG_MCTP is not set
# end of Platform Management Communication Infrastruction (PMCI)
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
CONFIG_CSPRNG_AVAILABLE=y
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SECURE_STORAGE is not set
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
# CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DEFAULT is not set
CONFIG_USB_DEVICE_LOG_LEVEL=1
CONFIG_USB_DEVICE_VID=0x2FE3
CONFIG_USB_DEVICE_PID=0x0001
CONFIG_USB_DEVICE_MANUFACTURER="ZEPHYR"
CONFIG_USB_DEVICE_PRODUCT="Zephyr CDC ACM sample"
CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
# CONFIG_USB_CONFIGURATION_STRING_DESC_ENABLE is not set
CONFIG_USB_COMPOSITE_DEVICE=y
CONFIG_USB_MAX_NUM_TRANSFERS=4
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
CONFIG_USB_WORKQUEUE=y
CONFIG_USB_WORKQUEUE_STACK_SIZE=1024
CONFIG_USB_WORKQUEUE_PRIORITY=-1
# USB CDC ACM Class support
CONFIG_USB_CDC_ACM=y
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=1024
CONFIG_CDC_ACM_INTERRUPT_EP_MPS=16
CONFIG_CDC_ACM_BULK_EP_MPS=64
CONFIG_CDC_ACM_TX_DELAY_MS=100
CONFIG_CDC_ACM_IAD=y
# CONFIG_CDC_ACM_DTE_RATE_CALLBACK_SUPPORT is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF=y
# CONFIG_USB_CDC_ACM_LOG_LEVEL_ERR is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_WRN is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_INF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DBG is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DEFAULT is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL=0
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_FLASH_LOAD_SIZE=0xc6000
CONFIG_ROM_END_OFFSET=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_DEPRECATION_TEST is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_UF2=y
# CONFIG_BUILD_OUTPUT_MOT is not set
CONFIG_BUILD_OUTPUT_UF2_FAMILY_ID="0xada52840"
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
# end of Compatibility
0246.zephyr.dts
nRF Connect: Build: samples/subsys/usb/cdc_acm/cdc_acm (active)
Building cdc_acm
west build --build-dir /home/wols/ncs/v3.1.0/zephyr/samples/subsys/usb/cdc_acm/build --domain cdc_acm
-- west build: building domain(s): cdc_acm
ninja: no work to do.
  • This is not work build command
    nRF Connect: Generate config promicro_nrf52840/nrf52840/uf2 for /home/wols/Documents/GitHub/BtnSync
    Building BtnSync
    west build --build-dir /home/wols/Documents/GitHub/BtnSync/build /home/wols/Documents/GitHub/BtnSync --pristine --board promicro_nrf52840/nrf52840/uf2 -- -DCONF_FILE="prj.conf" -DDTC_OVERLAY_FILE="app.overlay"
    Here is working build command
    Building BtnSync
    west build --build-dir /home/wols/Documents/GitHub/BtnSync/build /home/wols/Documents/GitHub/BtnSync --pristine --board promicro_nrf52840/nrf52840/uf2 --no-sysbuild -- -DCONF_FILE="prj.conf" -DDTC_OVERLAY_FILE="app.overlay"
    I guess the issue is because you mixed two bootloaders by accident, i.e. from your command, the board target promicro_nrf52840/nrf52840/uf2 assumes the UF2 bootloader is on the chip. Also, when you use sysbuild, this adds the MCUBoot. And this confusion (MCUBoot+UF2) will cause the app to be placed incorrectly and thus it never runs. This is why you don't see any /dev/ttyACM*.
    Hence, not using sysbuild helps in running it correctly.
    Or if you need sysbuild, then you could change the target to promicro_nrf52840/nrf52840
    -Priyanka
