Need to clarification on nrf http server example
I’m working with the nRF7002 DK and following the guide for the HTTP server sample here: HTTP Server Example. The build process is successful, but when I flash the device, I see this in the terminal:
Welcome to minicom 2.9
OPTIONS: I18n
Port /dev/ttyACM1, 12:22:25
Press CTRL-A Z for help on special keys
*** Booting nRF Connect SDK v3.1.0-6c6e5b32496e ***
*** Using Zephyr OS v4.1.99-1612683d4010 ***
[00:00:00.314,208] <inf> http_server: HTTP Server sample started
[00:00:00.314,270] <inf> http_server: Network interface brought up
and after nothing happens.
What’s the difference between the Zephyr HTTP server and the nRF HTTP server? examples And how do I configure the Wi-Fi credentials for the device?
    Sorry, I was out of the office yesterday, which caused the delay in responding to this issue.
    From the shared logs, it looks like Wi-Fi is not connected, although the sample you flashed is working. I believe this is because the Wi-Fi credentials have not been configured. This is mentioned in the documentation for the sample. Please also refer to the Wi-Fi credential library.
    The difference between the Zephyr HTTP sample and the Nordic sample is that our SDK sample is tailored for Nordic boards and includes overlays for running on our boards. The Zephyr sample, on the other hand, is a more generic example showcasing the HTTP server library.
    Abhijith
  • Thanks! I managed to get the Wi-Fi connectivity working successfully. However, I'm now trying to send data over HTTP with TLS-PSK, but I'm encountering an error."
    [00:00:00.513,641] <inf> http_server: HTTP Server sample started
    [00:00:00.514,373] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.557,006] <inf> http_server: Network interface brought up
    Connected
    [00:00:22.569,335] <inf> http_server: Network connected
    [00:00:22.570,434] <inf> http_server: Waiting for IPv6 HTTP connections on port 443, sock 12
    [00:00:22.571,228] <inf> http_server: Waiting for IPv4 HTTP connections on port 443, sock 15
    uart:~$
    ---- Sent utf8 encoded message: "net ipv4\r" ----
    net ipv4
    IPv4 support                              : enabled
    IPv4 fragmentation support                : disabled
    IPv4 conflict detection support           : disabled
    Path MTU Discovery (PMTU)                 : disabled
    Max number of IPv4 network interfaces in the system          : 1
    Max number of unicast IPv4 addresses per network interface   : 1
    Max number of multicast IPv4 addresses per network interface : 2
    IPv4 addresses for interface 1 (0x200013c8) (WiFi)
    Type            State           Ref     Address
    DHCP    preferred       1       10.250.23.68/255.255.255.0
    [00:01:09.488,677] <err> http_server: Error in accept -2, try again
    [00:01:36.104,064] <err> http_server: Error in accept -2, try again
    [00:02:34.461,883] <err> http_server: Error in accept -2, try again
    [00:03:35.459,259] <err> http_server: Error in accept -2, try again
     * Copyright (c) 2024 Nordic Semiconductor ASA
    #include <zephyr/kernel.h>
    #include <zephyr/net/tls_credentials.h>
    #include <zephyr/logging/log_ctrl.h>
    static const unsigned char server_certificate[] = {
    #if defined(HTTP_SERVER_CA_CERT)
    #include HTTP_SERVER_CA_CERT
    /* Null terminate certificate */
    (0x00)
    #else
    static const unsigned char server_private_key[] = {
    #if defined(HTTP_SERVER_PRIVATE_KEY)
    #include HTTP_SERVER_PRIVATE_KEY
    (0x00)
    #else
    static const unsigned char psk[] = {0x01, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06,
    0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f};
    static const char psk_id[] = "PSK_identity";
    #define PSK_TAG 42
    LOG_MODULE_REGISTER(http_server_credentials_provision, CONFIG_HTTP_SERVER_SAMPLE_LOG_LEVEL);
    int credentials_provision(void)
    	int ret;
    	ret = tls_credential_add(PSK_TAG,
    				 TLS_CREDENTIAL_PSK_ID,
    				 psk_id,
    				 sizeof(psk_id));
    	if (ret == -EEXIST) {
    		LOG_DBG("CA certificate already exists, sec tag: %d",
    			CONFIG_HTTP_SERVER_SAMPLE_SERVER_CERTIFICATE_SEC_TAG);
    	} else if (ret < 0) {
    		LOG_ERR("Failed to register CA certificate: %d", ret);
    		return ret;
    				 TLS_CREDENTIAL_PSK,
    				 psk,
    				 sizeof(psk));
    		LOG_DBG("Public certificate already exists, sec tag: %d",
    		LOG_ERR("Failed to register public certificate: %d", ret);
    		return ret;
    	// ret = tls_credential_add(CONFIG_HTTP_SERVER_SAMPLE_SERVER_CERTIFICATE_SEC_TAG,
    	// 			 TLS_CREDENTIAL_PRIVATE_KEY,
    	// 			 server_private_key, sizeof(server_private_key));
    	// if (ret == -EEXIST) {
    	// 	LOG_DBG("Private key already exists, sec tag: %d",
    	// 		CONFIG_HTTP_SERVER_SAMPLE_SERVER_CERTIFICATE_SEC_TAG);
    	// } else if (ret < 0) {
    	// 	LOG_ERR("Failed to register private key: %d", ret);
    	// 	return ret;
    	return 0;
    on other side
    openssl s_client -connect 10.250.23.68:443 -tls1_2 \
      -psk 010102030405060708090a0b0c0d0e0f \
      -psk_identity "PSK_identity"
    CONNECTED(00000003)
    40A7A17E5C790000:error:0A000126:SSL routines:ssl3_read_n:unexpected eof while reading:../ssl/record/rec_layer_s3.c:316:
    no peer certificate available
    No client certificate CA names sent
    SSL handshake has read 0 bytes and written 247 bytes
    Verification: OK
    New, (NONE), Cipher is (NONE)
    Secure Renegotiation IS NOT supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    SSL-Session:
        Protocol  : TLSv1.2
        Cipher    : 0000
        Session-ID:
        Session-ID-ctx:
        Master-Key:
        PSK identity: None
        PSK identity hint: None
        SRP username: None
        Start Time: 1757932743
        Timeout   : 7200 (sec)
        Verify return code: 0 (ok)
        Extended master secret: no
    I’m glad to hear that your Wi-Fi provisioning problem has been resolved. For this new issue, I recommend creating a separate ticket, as it is different from the original query you raised. This helps keep DevZone organized and makes it easier for others to find relevant information in the future.
    Abhijith
