Inquiry Regarding CONSTRAINT_ERROR (Status 126) with AddGroup Command in Matter Device
Dear Nordic Team,
I hope this email finds you well.
I am currently working on integrating group functionality with a Matter device (Node ID: 114, Endpoint ID: 1) using the chip-tool command-line utility. However, when attempting to add the device to a group using the AddGroup command, I consistently encounter a CONSTRAINT_ERROR (status code 126). Could you please help me identify the root cause? Below are the details of my setup and the issue:
Steps to Reproduce:
  1. Run the following command:
    bash
    ./chip-tool-debug groups add-group 0x0001 "Gp1" 114 1
  2. The command fails with the following response:
    json
    AddGroupResponse: {
      status: 126,  // CONSTRAINT_ERROR
      groupID: 1
What I’ve Already Tried:
  1. Verified Groups Cluster Support:
    • The device responds to AddGroup commands, confirming that the Groups cluster is implemented.
    • Used descriptor read server-list to confirm the Groups cluster (0x0004) is present.
  2. Tested Alternative Group IDs:
    • Tried different Group IDs (e.g., 0x01010x10011000) and simpler group names (e.g., "Test").
    • All attempts resulted in the same CONSTRAINT_ERROR.
  3. Checked Device State:
    • Read the group-table and group-names attributes, both returned empty lists.
      Confirmed the device is not already a member of any group.
