Bricked nFR9151-DK board
I have started working with the nFR9151-DK board.
After some time, I may have accidentally erased all data from the board using the PROGRAMMER application.
As a result, the board no longer allows programming via USB.
A log file is attached.
How can I resolve this issue?
2025-09-10T10:34:23.249Z INFO Initialising the bundled nrfutil device
2025-09-10T10:34:23.322Z DEBUG Started watching devices
2025-09-10T10:34:25.101Z INFO Using the bundled core version for nrfutil device: 8.1.1
2025-09-10T10:34:25.155Z INFO Using nrfutil-device version: 2.10.2
2025-09-10T10:34:25.156Z INFO Using nrf-device-lib version: 0.17.71
2025-09-10T10:34:25.156Z INFO Using nrf-probe version: 0.38.0
2025-09-10T10:34:25.156Z INFO Using JLink version: JLink_V8.18
2025-09-10T10:34:26.251Z DEBUG Selected device: nRF9151 DK
2025-09-10T10:34:26.308Z DEBUG Changed step: Info
2025-09-10T10:34:30.880Z DEBUG Changed step: Rename
2025-09-10T10:34:36.899Z DEBUG Changed step: Info
2025-09-10T10:34:39.908Z DEBUG Changed step: Rename
2025-09-10T10:34:44.030Z DEBUG Changed step: Info
2025-09-10T10:34:44.857Z DEBUG Changed step: Connect
2025-09-10T10:35:39.543Z DEBUG Selected device: nRF9151 DK
2025-09-10T10:35:39.567Z DEBUG Changed step: Info
2025-09-10T10:35:42.054Z DEBUG Changed step: Rename
2025-09-10T10:36:04.784Z DEBUG Changed step: Program
2025-09-10T10:37:21.847Z ERROR [ProbeLib] [2025-09-10 10:37:21.840613Z] Failed to initialize worker: Timed out waiting for response from worker.
2025-09-10T10:37:26.045Z ERROR [ProbeLib] [2025-09-10 10:37:26.045986Z] Trace channel disconnected unexpectedly.
2025-09-10T10:37:26.056Z ERROR [ProbeLib] [2025-09-10 10:37:26.056724Z] Worker exited with error code 1.
  • Another LOG file
    2025-09-10T10:48:54.102Z INFO Initialising the bundled nrfutil device
    2025-09-10T10:48:54.118Z DEBUG Application data folder: C:\Users\Oleg\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2025-09-10T10:48:54.224Z DEBUG App pc-nrfconnect-programmer v4.6.2 (official)
    2025-09-10T10:48:54.224Z DEBUG App path: C:\Users\Oleg\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2025-09-10T10:48:54.224Z DEBUG nRFConnect 5.2.0, required by the app is (>=5.2.0)
    2025-09-10T10:48:54.224Z DEBUG nRFConnect path: C:\Users\Oleg\AppData\Local\Programs\nrfconnect\resources\app.asar
    2025-09-10T10:48:54.224Z DEBUG HomeDir: C:\Users\Oleg
    2025-09-10T10:48:54.224Z DEBUG TmpDir: C:\Users\Oleg\AppData\Local\Temp
    2025-09-10T10:48:54.258Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:48:56.563Z DEBUG Requested nrfutil core version 8.0.0 is already installed.
    2025-09-10T10:48:56.620Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:01.176Z INFO Successfully installed nrfutil device version: 2.12.3
    2025-09-10T10:49:01.290Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:01.291Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:01.352Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:01.528Z INFO Using the bundled core version for nrfutil device: 8.0.0
    2025-09-10T10:49:01.625Z INFO Using nrfutil-device version: 2.12.3
    2025-09-10T10:49:01.625Z INFO Using nrf-device-lib version: 0.17.81
    2025-09-10T10:49:01.625Z INFO Using nrf-probe version: 0.40.1
    2025-09-10T10:49:01.625Z INFO Using JLink version: JLink_V8.18
    2025-09-10T10:49:01.890Z INFO Getting serial port options from the persistent store for 001051285002.pc-nrfconnect-programmer
    2025-09-10T10:49:01.891Z INFO Device connected with the serial number 001051285002
    2025-09-10T10:49:01.892Z DEBUG Sending event "programmer: device connected"
    2025-09-10T10:49:03.435Z INFO Selecting device with the serial number 001051285002
    2025-09-10T10:49:03.496Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:18.762Z ERROR Error: Failed with exit code 1.
    One or more device info tasks failed:
     * 1051285002: Timed out waiting for response from worker. (Generic)
    Message: Operation device-info failed, Timed out waiting for response from worker.
    2025-09-10T10:49:18.762Z INFO Selected device with the serial number 001051285002
    2025-09-10T10:49:18.762Z INFO Using nrfutil device to communicate with target via JLink
    2025-09-10T10:49:18.818Z DEBUG Sending event "programmer: device selected"
    2025-09-10T10:49:18.818Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:19.234Z DEBUG Sending event "programmer: running nrfutil device"
    2025-09-10T10:49:21.830Z INFO Device connected with the serial number 001051285002
    2025-09-10T10:49:21.922Z INFO Reading readback protection status for Application core
    2025-09-10T10:49:21.922Z ERROR Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Emulator error: Failed to open connection
    2025-09-10T10:49:21.939Z ERROR Error: Failed with exit code 1.
    One or more batch tasks failed:
     * 1051285002: Emulator error: Failed to open connection (Generic)
    Message: Batch task protection-get failed, Emulator error: Failed to open connection.
    2025-09-10T10:49:23.009Z INFO Getting serial port options from the persistent store for 001051285002.pc-nrfconnect-programmer
    2025-09-10T10:49:23.010Z INFO Device connected with the serial number 001051285002
    2025-09-10T10:49:23.010Z DEBUG Sending event "programmer: device connected"
    Can you show all steps you made when accidently erasing all data using Programmer application?
    Which commands gave 2 shown output logs?
    Dejan
  • On "nrfConnect for Desktop" > "Programmer (v4.6.2)" select device and press "Erase all" button - These are the steps after which the board stopped functioning
    First log - when after "Erase all"  I try to use "Quick Start" from "nrfConnect for Desktop"
    Second log - when after "Erase all"  I try to do "Reset" tor "Read" with "nrfConnect for Desktop" > "Programmer (v4.6.2)"
    You could try to recover your device using
    nrfutil device recover
    Dejan
  • "nrfutil device recover" fail with the error
    ⠒ Recover 1051285002
    ⠓ Recover 1051285002
    x Failed to recover 1051285002, Timed out waiting for response from worker.
    Recover 1051285002
    Error: One or more recover tasks failed:
