How to set the path of sdk.
in my disc, C:\ncs\v3.0.0  is here.
but in nrf extension, weclome page shows the button ("install sdk").  it looks find no sdk.
I need set the path to C:\ncs\v3.0.0 (I do not want to download the ncs sdk from web again and again.)
can I use the existing directory as the sdk?
how to let the vscode or extenstion find the existing sdk? what version is it?  it looks 1.103 cannot do this.
    This is actually possible.
    If you open a command line terminal (with the toolchain active), you can enter the v3.0.0\nrf folder, and run the command: "west zephyr-export". After this has completed, you need to restart VS Code, or at least reload the plugins by hitting ctrl + shift + p, and use the command "Reload Window". After this, the v3.0.0 SDK should be detected by the plugin.
    Edvin
