Using Python/pylink to program thingy91
I am updating our production tools and starting by simply trying to program the Thingy91 (or DK) with the following example from the internet. I keep getting timeout errors during erase and can not find any help on the matter.
I have updated all of my tools.
Is there a decent (and up to date) tutorial anywhere?
Rich
Here is the output
Connecting to the first available J-Link probe...
Connecting to target device: nRF9160_xxAA...
Flashing firmware from c:\Temp\ModemShellRtt.hex...
Timeout while preparing target, RAMCode did not respond in time!
Failed to perform RAMCode-sided Prepare()
Failed to perform RAMCode-sided Prepare()Timeout while preparing target, RAMCode did not respond in time!
An error occurred: Failed to erase sector.
import pylink
import os
# The serial number of your J-Link probe.
# This is useful if you have multiple J-Link devices connected.
# You can find the serial number using the 'pylink.jlink_list()' function or the J-Link Commander.
JLINK_SERIAL_NO = None # Or provide your serial number here
# The path to the firmware HEX file you want to flash.
# Example: Using a pre-compiled hex from the nRF Connect SDK.
FIRMWARE_FILE_PATH = os.path.join("c:\Temp", "ModemShellRtt.hex")
# Define the device name. For the Thingy:91's nRF9160 SiP, this is 'nRF9160_xxAA'.
TARGET_DEVICE = 'nRF9160_xxAA'
# The address where the firmware should be flashed. For the nRF9160, this is typically 0.
FLASH_ADDRESS = 0x0
def connect_and_flash():
    Connects to a J-Link probe, flashes firmware to a Thingy:91, and resets the device.
    try:
        # Create a JLink object
        jlink = pylink.JLink()
        # Open a connection to the J-Link.
        # The serial number is optional but recommended for clarity.
        if JLINK_SERIAL_NO:
            print(f"Connecting to J-Link probe with serial number {JLINK_SERIAL_NO}...")
            jlink.open(serial_no=JLINK_SERIAL_NO)
        else:
            print("Connecting to the first available J-Link probe...")
            jlink.open()
        # Connect to the target device (Thingy:91's nRF9160)
        print(f"Connecting to target device: {TARGET_DEVICE}...")
        jlink.connect(TARGET_DEVICE, verbose=True)
        # Flash the firmware file
        print(f"Flashing firmware from {FIRMWARE_FILE_PATH}...")
        jlink.flash(FIRMWARE_FILE_PATH, FLASH_ADDRESS)
        # Reset the device to run the new firmware
        print("Resetting the target device...")
        jlink.reset()
        print("Flashing successful!")
    except pylink.errors.JLinkException as e:
        print(f"An error occurred: {e}")
        if jlink and jlink.connected():
            jlink.close()
    finally:
        # Always close the connection in the 'finally' block to ensure cleanup
            jlink.close()
            print("Connection to J-Link closed.")
if __name__ == "__main__":
    if not os.path.exists(FIRMWARE_FILE_PATH):
        print(f"Error: Firmware file not found at {FIRMWARE_FILE_PATH}")
    else:
        connect_and_flash()
