Invalid argument error when running "west rtt" with nRF9151
I tried to use west rtt with v3.1.0 and I'm getting the following error:
ERROR: runners.jlink: [Errno 22] Invalid argument
How to reproduce:
  1. Connect J-Link to Thingy:91 X (switch set to connect SWD to the nRF9151)
  2. cd /opt/nordic/ncs/v3.1.0/zephyr/samples/subsys/shell/shell_module
  3. west build -p -b thingy91x/nrf9151/ns --sysbuild -- -DCONF_FILE="prj_minimal_rtt.conf"
  4. west rtt
Produces the following output:
-- west rtt: rebuilding
[0/31] Performing build step for 'mcuboot'
ninja: no work to do.
[1/31] Performing build step for 's1_image'
[2/31] No install step for 'mcuboot'
[3/31] Performing build step for 'b0'
[7/25] Completed 's1_image'
[8/25] Performing build step for 'shell_module'
[0/14] Performing build step for 'tfm'
[12/19] cd /opt/nordic/ncs/v3.1.0/zephyr/samples/subsys/shell/shell_module/build/_sysbuild && /opt/nordic/ncs/toolchains/5c0d382932/Cellar/cmake/3.21.0/bin/cmake -E true
[14/18] No install step for 'shell_module'
[15/18] Completed 'shell_module'
[16/18] cd /opt/nordic/ncs/v3.1.0/zephyr/samples/subsys/shell/shell_module/build/_sysbuild && /opt/nordic/ncs/toolchains/5c0d382932/Cellar/cmake/3.21.0/bin/cmake -E true
-- west rtt: using runner jlink
-- runners.jlink: reset after flashing requested
-- runners.jlink: JLink version: 8.64
-- runners.jlink: J-Link GDB server running on port 2331; no thread info available
-- runners.jlink: J-Link RTT server running on port 19021
SEGGER J-Link GDB Server V8.64 Command Line Version
JLinkARM.dll V8.64 (DLL compiled Aug 28 2025 10:03:47)
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      yes
Generate logfile:              off
Verify download:               off
Init regs on start:            off
Silent mode:                   on
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 nRF9151_xxCA
Target device parameters:      none
Target interface:              SWD
Target interface speed:        4000kHz
Target endian:                 little
Is there something else I need to do to get this working?
When I use the Segger RTT Viewer application instead of west rtt, the RTT functionality works correctly.
  • Hi Chris,
    Are you seeing this with other samples as well, or just this one for this particular board?
    Elfving
  •  I saw this on a custom app I'm working on using NCS 3.0.1. I tried reproducing it on the latest 3.1.0 with the sample app to check if it was something specific to my app, but I saw the same behavior.
    Are you able to reproduce it on your end using the steps I posted above?
  • Hi again Chris, and sorry about the wait.
    I'm also seeing an error doing this, but not exactly what you are seeing. Given that you have more boards on hand, could you see if you're only getting this issue on the Thingy?
    Elfving
  • I've only tried this on the Thingy:91 X so far. I'll try to test this out on another Nordic dev kit and reply back.
    What error are you seeing? I'm on macOS with Apple Silicon, what OS are you using?
  •  I tried this same process on a nRF54L15-DK board and I'm seeing the same behavior.
    1. Connect USB to nRF54L15-DK
    3. west build -p -b nrf54l15dk/nrf54l15/cpuapp/ns --sysbuild -- -DCONF_FILE="prj_minimal_rtt.conf"
    4. west rtt
    I get the following error:
    ❯ west rtt
    [0/5] Performing build step for 'shell_module'
    [0/16] Performing build step for 'tfm'
    [2/3] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [3/3] Completed 'tfm'
    [4/5] cd /opt/nordic/ncs/v3.1.0/zephyr/samples/subsys/shell/shell_module/build/_sysbuild && /opt/homebrew/bin/cmake -E true
    -- runners.jlink: JLink version: 8.72a
    SEGGER J-Link GDB Server V8.72a Command Line Version
    JLinkARM.dll V8.72a (DLL compiled Sep 25 2025 17:23:39)
    GDBInit file:                  none
    Silent mode:                   on
    Single run mode:               on
    J-Link script:                 none
    Target device:                 nRF54L15_M33
    However, if I open the JLinkRTTViewer.app from Segger, the RTT functionality works OK.
