nRF Connect VS Code Extention
I'm having an issue while trying to install the nRF Connect vsCode extension. I assume that extension has auto board detection feature. However, on my computer, this feature does not work as expected. There is another device connected to my computer which opens a couple of virtual com ports. When I enable the nrf extension, it continuously opens and closes these com ports, making them unusable. How can I disable the auto-board-detection feature ?
    Sorry for the confusion. I've successfully installed and uploaded code to nrf54L devkit. I'm also doing development on  Quectel's SoC's which connected via USB and creates seven virtual com ports for different purposes. I meant the Quectel's SoC by "another device".
    The problem arises when I plug in the Quectel device while the nRF Connect extention is enabled. Once connected, extention continuously opens and closes the com ports of Quectel SoC. Since its automatically does this open/close behaviour, I've assumed that nRF connect continously search through avaiable com ports to find a nrf board.
    The problem continues even if I plug in a Nordic device. I've confirmed the open/close behaviour caused by extention since it only happens when VS Code is open and extention enabled. In this state, I cannot use the Quectel's com ports with any application. When I disable the extention, open/close behaviour immediately stops and com ports became usable.
  • Hi Dejan,
    No, I've also tried STM boards and the problem is not happening. My colleague also faced this issue on another computer.
    Thanks & Best Regards,
    Emre.
  • Hi Emre,
    Can you send support log (Generate Support Information)?
    Is Quectel device J-Link device?
    Are drivers, J-Link OB firmware and everything else working as expected?
    Which operating system version do you use? Has your colleague seen the same issue using computer with the same operating system and the same version? Can you check if this problem is present on any operating system (Mac, Linux)?
    Dejan
  • Hi Dejan,
    I've found the reason for this problem while exploring the nrfUtil's features for my own application:
     - nrfUtil have a list function to detect available J-Link devices which tries to open/close every possible com port on the computer. nRF VS Code extention probably run this command every second to detect device removal from computer. However, this feature causes to Quectel device's com ports to continously being open/close every second, which makes them unusuable.
  • Hello, I have forwarded your observation now.
    Thank you,
    Kenneth
  • Hello again,
    A few questions to ensure they understand the current issues correctly:
    - Could you run "nrfutil device list --hotplug --log-level trace" again and see if you get the COM ports closing and opening every second? I'm interested in seeing the log from <USERHOME>/.nrfutil/logs/nrfutil-device.log regardless of the outcome.
    - Could you also paste the output of "nrfutil device list --traits serialports"? And maybe rerun it 4-5 times.
    - Also, how do you detect that the serial ports are being opended and closed? Could it be that are you seeing other symptoms that might be similar to open/close?
    Thank you,
    Kenneth
  • Hello again,
    Thank you,
    Kenneth
