MCUBOOT not loging, serial DFU not compile
I've been trying to get MCUboot running on my custom board with the nRF9160 for two days now, and I'm honestly at my wit's end. The main application is written and works perfectly — LTE, UART, SPI, everything runs as it should.
Now I wanted to add DFU over UART, but I just can't get it to work.
To simplify things, I'm using the Nordic Academy examples (l8_e1 and l9_e1). On the nRF9160DK, everything works flawlessly. But on my custom board, MCUboot doesn't work at all.
The board was generated automatically by nRF Connect.
Simply enabling MCUboot results in no MCUboot log output on boot. When I add the following configuration:
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_UART=y
the build fails with an error: pm_config: No such file or directory
For now, I just want to get MCUboot logging working.
sysbuil.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
mcuboot.conf:
CONFIG_SERIAL=y
dts:
	chosen {
		zephyr,flash = &flash0;
		zephyr,sram = &sram0_ns;
		zephyr,code-partition = &slot0_ns_partition;
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
defconfig (board)
CONFIG_ARM_MPU=y
CONFIG_HW_STACK_PROTECTION=y
CONFIG_ARM_TRUSTZONE_M=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
#dodane:
# Enable RTT
CONFIG_USE_SEGGER_RTT=y
# Enable PINCTRL
CONFIG_PINCTRL=y
# Enable GPIO
CONFIG_GPIO=y
# Enable UARTE
CONFIG_SERIAL=y
# Enable console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
Copilot or GPT can't solve the problem.
In the memory report preview, I see the same partitions as those generated by the nRF9160DK board.
A simple task, and I’m already fed up with this system:(
Thank you for your responses. Best regards!
