[nRF51-ble-app-uart-static-passkey] Calling app_timer_start at BLE_GAP_EVT_CONNECTED
Using,
Hi, I modified some codes of main.c. main_edited.c
This file can be compiled after adding ble_dis.c.
The main changes are
Change1
Change1-1
  1. Changing device name, added DIS (Device Info Service) and infinite advertising.
This timer starts after connection / disconnection. The call of the timeout handler can be observed from the LEDs.
Change2
  1. Added a timer. This timer just makes the LED 0, LED 1 to blink
Change3
  1. Edited passkey properly for SDK7.2.
Change4
  1. Enabled whitelist advertising
  2. If a NUS packet was sent from the central, it echoes back the same packet.
This is for checking the connection.
One surprising this is that
the test_timer_timeout is not called after the BLE_GAP_EVT_CONNECTED.
I made the timer to start after connection, but I observed that RTC1_IRQHandler wasn't called.
However, the disconnection event called test_timer_timeout.
Why RTC1_IRQHandler isn't called after connection event happened?
Although I changed the timeout_ticks for app_timer_start and enabled the scheduler, the result was same.
Is there a change to be done in order to trigger RTC1_IRQHandler after connection?
-Regards, Mango
