Recovery of nrf52dk fails due to access port protection
Hello. I have an issue with my development board. When attempting to recover the board, i cannot due to access port protection. This is the specific error message from the programmer:
Failed "recovering application core". Error: code: 1, description: Generic, message: Batch task recover failed, Device error: Access Port is still protected after Erase and Reset
Attempting to do it manually with JLink commander also fails. The error seems to have appeared after programming it with a blank project(was working fine previously)
Attached is nrfutil-device log:
[2025-09-15T12:56:41.643Z] [1632729] INFO - [nrfutil_common::logger] nrfutil-device (version = 2.12.10, platform = x86_64-unknown-linux-gnu, classification = nrf-external) invoked with recover --log-level trace
[2025-09-15T12:56:41.643Z] [1632729] DEBUG - [nrfutil_device] Detected that we are running through nrfutil since NRFUTIL_EXEC_PATH was set. Setting NRF_PROBE_PATH to /home/antonwasser/.nrfutil/lib/nrfutil-device
[2025-09-15T12:56:41.643Z] [1632729] INFO - [nrfutil_device::watch] Starting parent process watchdog, current parent process ID: 1632728
[2025-09-15T12:56:41.649Z] [1632729] INFO - [probe::tracing_logger] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 8.18
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nrfdl::device_lister] Plugin BOARDCONTROLLER does not support `get_version_list`
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nrfdl::device_lister] Plugin SDFU-RS does not support `get_version_list`
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nrfdl::device_lister] Plugin MCUBOOT does not support `get_version_list`
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nrfutil_device] operation to get devices for : Ok("{\"operations\":[{\"operation\":{\"type\":\"recover\",\"erase_protect_key\":null},\"core\":\"NRFDL_DEVICE_CORE_APPLICATION\"}]}")
[2025-09-15T12:56:41.650Z] [1632729] TRACE - [nrfutil_device] Operations required by a device to do: {"recover"}
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate_devices
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-8"
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1"
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6"
[2025-09-15T12:56:41.650Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
[2025-09-15T12:56:41.651Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb4/4-3"
[2025-09-15T12:56:41.651Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.2"
[2025-09-15T12:56:41.651Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-10"
[2025-09-15T12:56:41.651Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1/3-4.1.1.2"
[2025-09-15T12:56:41.652Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3"
[2025-09-15T12:56:41.652Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1"
[2025-09-15T12:56:41.652Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.3"
[2025-09-15T12:56:41.653Z] [1632729] DEBUG - [serialport_lister::platform] [Linux] Linux serialport enumerate.
[2025-09-15T12:56:41.659Z] [1632729] TRACE - [serialport_lister::platform] [Linux] get_lister_item: sys_path = /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1/3-4.1.1.2/3-4.1.1.2:1.0/tty/ttyACM1
[2025-09-15T12:56:41.659Z] [1632729] TRACE - [serialport_lister::platform] [Linux] get_lister_item: devnode = /dev/ttyACM1
[2025-09-15T12:56:41.659Z] [1632729] DEBUG - [serialport_lister::platform] [Linux] parent syspath: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1
[2025-09-15T12:56:41.659Z] [1632729] DEBUG - [serialport_lister::platform] [Linux] set container ID: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1
[2025-09-15T12:56:41.660Z] [1632729] TRACE - [serialport_lister::platform] [Linux] get_lister_item: sys_path = /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1/3-4.1.1.2/3-4.1.1.2:1.2/tty/ttyACM2
[2025-09-15T12:56:41.660Z] [1632729] TRACE - [serialport_lister::platform] [Linux] get_lister_item: devnode = /dev/ttyACM2
[2025-09-15T12:56:41.660Z] [1632729] DEBUG - [serialport_lister::platform] [Linux] parent syspath: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1
[2025-09-15T12:56:41.660Z] [1632729] DEBUG - [serialport_lister::platform] [Linux] set container ID: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1
[2025-09-15T12:56:41.669Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate: Device with sn 001050391982 has board version PCA10040
[2025-09-15T12:56:41.669Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin: Probe
[2025-09-15T12:56:41.670Z] [1632729] INFO - [probe::tracing_logger] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 8.18
[2025-09-15T12:56:41.679Z] [1632729] INFO - [probe::tracing_logger] Found 1 attached J-Link devices
[2025-09-15T12:56:41.680Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin Probe done in: 10ms
[2025-09-15T12:56:41.680Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin: BOARDCONTROLLER
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [boardcontroller] Found 18 HID devices.
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin BOARDCONTROLLER done in: 3ms
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin: SDFU-RS
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin SDFU-RS done in: 0ms
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin: MCUBOOT
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [nrfdl::device_lister] enumerate plugin MCUBOOT done in: 0ms
[2025-09-15T12:56:41.683Z] [1632729] TRACE - [nrfutil_device] List of devices capable of performing the operations : [Device { id: DeviceId(8), serial_number: Some("001050391982"), traits: {"mcuBoot": false, "devkit": true, "modem": false, "nordicUsb": false, "seggerUsb": true, "serialPorts": true, "broken": false, "boardController": false, "nordicDfu": false, "usb": true, "jlink": true}, plugin_data: {"usb": Object {"device": Object {"address": Number(74), "busNumber": Number(3), "descriptor": Object {"bDescriptorType": Number(1), "bcdDevice": Number(256), "idProduct": Number(4193), "idVendor": Number(4966)}}, "manufacturer": String("SEGGER"), "osDevicePath": String("/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1/3-4.1.1.2"), "product": String("J-Link"), "serialNumber": String("001050391982")}, "devkit": Object {"boardVersion": String("PCA10040"), "deviceFamily": String("NRF52_FAMILY")}, "probe": String("{}"), "serialPorts": Array [Object {"comName": String("/dev/ttyACM1"), "manufacturer": String("SEGGER"), "path": String("/dev/ttyACM1"), "productId": String("1061"), "serialNumber": String("001050391982"), "vcom": Number(0), "vendorId": String("1366")}, Object {"comName": String("/dev/ttyACM2"), "manufacturer": String("SEGGER"), "path": String("/dev/ttyACM2"), "productId": String("1061"), "serialNumber": String("001050391982"), "vcom": Number(1), "vendorId": String("1366")}]} }]
[2025-09-15T12:56:41.683Z] [1632729] DEBUG - [nrfutil_device] No serial-number or traits provided. But only one relevant device is connected. Will perform operation with Device { id: DeviceId(8), serial_number: Some("001050391982"), traits: {"mcuBoot": false, "devkit": true, "modem": false, "nordicUsb": false, "seggerUsb": true, "serialPorts": true, "broken": false, "boardController": false, "nordicDfu": false, "usb": true, "jlink": true}, plugin_data: {"usb": Object {"device": Object {"address": Number(74), "busNumber": Number(3), "descriptor": Object {"bDescriptorType": Number(1), "bcdDevice": Number(256), "idProduct": Number(4193), "idVendor": Number(4966)}}, "manufacturer": String("SEGGER"), "osDevicePath": String("/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1/3-4.1.1.2"), "product": String("J-Link"), "serialNumber": String("001050391982")}, "devkit": Object {"boardVersion": String("PCA10040"), "deviceFamily": String("NRF52_FAMILY")}, "probe": String("{}"), "serialPorts": Array [Object {"comName": String("/dev/ttyACM1"), "manufacturer": String("SEGGER"), "path": String("/dev/ttyACM1"), "productId": String("1061"), "serialNumber": String("001050391982"), "vcom": Number(0), "vendorId": String("1366")}, Object {"comName": String("/dev/ttyACM2"), "manufacturer": String("SEGGER"), "path": String("/dev/ttyACM2"), "productId": String("1061"), "serialNumber": String("001050391982"), "vcom": Number(1), "vendorId": String("1366")}]} }
[2025-09-15T12:56:41.684Z] [1632729] DEBUG - [probe::tracing_logger] Checking whether operations are supported
[2025-09-15T12:56:41.684Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-8"
[2025-09-15T12:56:41.684Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1"
[2025-09-15T12:56:41.684Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6"
[2025-09-15T12:56:41.685Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
[2025-09-15T12:56:41.685Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb4/4-3"
[2025-09-15T12:56:41.685Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.2"
[2025-09-15T12:56:41.685Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-10"
[2025-09-15T12:56:41.686Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.1/3-4.1.1.2"
[2025-09-15T12:56:41.686Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3"
[2025-09-15T12:56:41.686Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1"
[2025-09-15T12:56:41.686Z] [1632729] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.1/3-4.1.3"
[2025-09-15T12:56:41.687Z] [1632729] DEBUG - [probe::tracing_logger] Executing operation: {"operations":[{"core":"NRFDL_DEVICE_CORE_APPLICATION","operation":{"erase_protect_key":null,"type":"recover"}}]}
[2025-09-15T12:56:41.687Z] [1632729] DEBUG - [probe::tracing_logger] Looking for file in /home/antonwasser/.nrfutil/lib/nrfutil-device/plugin-probe-worker
[2025-09-15T12:56:41.687Z] [1632729] DEBUG - [probe::tracing_logger] Found file at /home/antonwasser/.nrfutil/lib/nrfutil-device/plugin-probe-worker
[2025-09-15T12:56:41.687Z] [1632729] TRACE - [probe::tracing_logger] Created IPC server /tmp/.tmpivktNU/socket
[2025-09-15T12:56:41.688Z] [1632729] DEBUG - [probe::tracing_logger] Spawned worker process with id 1632758
[2025-09-15T12:56:41.688Z] [1632729] TRACE - [probe::tracing_logger] Accepting IPC connection
[2025-09-15T12:56:41.691Z] [1632729] TRACE - [probe::tracing_logger] Accepted IPC connection
[2025-09-15T12:56:41.691Z] [1632729] TRACE - [probe::tracing_logger] The worker supervisor's role is finished
[2025-09-15T12:56:41.698Z] [1632729] DEBUG - [probe::tracing_logger] Received signal from master, returning alive worker.
[2025-09-15T12:56:41.698Z] [1632729] INFO - [probe::tracing_logger] Handshake signatures match
[2025-09-15T12:56:41.698Z] [1632729] INFO - [probe::tracing_logger] Connection with Probe worker established.
[2025-09-15T12:56:41.698Z] [1632729] TRACE - [probe::tracing_logger] Starting trace thread
[2025-09-15T12:56:41.698Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} nrf-probe version 0.44.0
[2025-09-15T12:56:41.698Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Sending IPC handshake response from worker...
[2025-09-15T12:56:41.699Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Started worker message processing loop
[2025-09-15T12:56:41.699Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None }, target: DeviceConfig { swd_clock_frequency: None, adac_timeout: None, firmware_config: None, swd_mode: PointToPoint, target_family: None, override_detection: None, override_sdfw_variant: None } } })
[2025-09-15T12:56:41.705Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Setting up JLink interface.
[2025-09-15T12:56:41.705Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> connect
[2025-09-15T12:56:41.711Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Applied firmware settings to JLink
[2025-09-15T12:56:41.734Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Max frequency: 2000 kHz
[2025-09-15T12:56:41.734Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} Clock frequency was set to 2000 kHz
[2025-09-15T12:56:41.734Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} Emulator Usb(JLinkSerialNumber(1050391982)) running firmware: J-Link OB-nRF5340-NordicSemi compiled Jul  8 2025 10:15:34
[2025-09-15T12:56:41.734Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- connect
[2025-09-15T12:56:41.734Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Probe worker received message: Request(DetectDeviceInformation { use_cache: true })
[2025-09-15T12:56:41.735Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3300, tck: 0, tdi: 1, tdo: 1, tms: 1, tres: 1, trst: 255 }
[2025-09-15T12:56:41.735Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> Powering up sys and debug region
[2025-09-15T12:56:41.735Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.736Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:56:41.736Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.736Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.737Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0xf0000040 from CTRL/STAT
[2025-09-15T12:56:41.737Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.737Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Powered up sys and dbg regions in 1 ms
[2025-09-15T12:56:41.737Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- Powering up sys and debug region
[2025-09-15T12:56:41.737Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> detect device family
[2025-09-15T12:56:41.737Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0x2ba01477 from DPIDR
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.738Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} DPIDR: Register { content: 731911287, revision: 2, part_no: 186, res0: 0, min: 0, version: 1, designer: 571, always_one: 1 }
[2025-09-15T12:56:41.738Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- detect device family
[2025-09-15T12:56:41.738Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} -> Get AP-Protect Status
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:56:41.738Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x010000f0 to SELECT = 0x08
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x02880000 from IDR
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.739Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Detected CTRL-AP revision 0 at AP 1
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.739Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.740Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:41.740Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.740Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.740Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.740Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.740Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.741Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.741Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.741Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:41.741Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.741Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.741Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.742Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect status is 'All'
[2025-09-15T12:56:41.742Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} <- Get AP-Protect Status
[2025-09-15T12:56:41.742Z] [1632729] WARN - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect is enabled, unable to read the device revision for nRF52. Returning only with the family
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] Got regular response.
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] Not able to properly detect connected device, skipping default external flash configuration
[2025-09-15T12:56:41.742Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Probe worker received message: Request(Recover { core_id: Application, erase_protect_key: None })
[2025-09-15T12:56:41.742Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> Powering down debug region
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.742Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.743Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0xf0000040 from CTRL/STAT
[2025-09-15T12:56:41.743Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.743Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.743Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:56:41.743Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.743Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.744Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0xf0000040 from CTRL/STAT
[2025-09-15T12:56:41.744Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.744Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.744Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to CTRL/STAT = 0x04
[2025-09-15T12:56:41.744Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.746Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.746Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:56:41.746Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.747Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.747Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0x00000040 from CTRL/STAT
[2025-09-15T12:56:41.747Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.747Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Powered down sys and dbg regions in 4 ms
[2025-09-15T12:56:41.747Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- Powering down debug region
[2025-09-15T12:56:41.747Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3300, tck: 0, tdi: 1, tdo: 1, tms: 1, tres: 1, trst: 255 }
[2025-09-15T12:56:41.748Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> Powering up sys and debug region
[2025-09-15T12:56:41.748Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.748Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:56:41.748Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.748Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.748Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0xf0000040 from CTRL/STAT
[2025-09-15T12:56:41.748Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.749Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Powered up sys and dbg regions in 0 ms
[2025-09-15T12:56:41.749Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- Powering up sys and debug region
[2025-09-15T12:56:41.749Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> detect device family
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0x2ba01477 from DPIDR
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:56:41.749Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} DPIDR: Register { content: 731911287, revision: 2, part_no: 186, res0: 0, min: 0, version: 1, designer: 571, always_one: 1 }
[2025-09-15T12:56:41.749Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- detect device family
[2025-09-15T12:56:41.749Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} -> Get AP-Protect Status
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.749Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.750Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:56:41.750Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.750Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.750Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.750Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x010000f0 to SELECT = 0x08
[2025-09-15T12:56:41.750Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.751Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x02880000 from IDR
[2025-09-15T12:56:41.751Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.751Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Detected CTRL-AP revision 0 at AP 1
[2025-09-15T12:56:41.751Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.751Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.751Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.751Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.752Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:41.752Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.752Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.752Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.752Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.752Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.753Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.753Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.753Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.753Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.753Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.753Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] Got progress from worker.
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.754Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect status is 'All'
[2025-09-15T12:56:41.754Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} <- Get AP-Protect Status
[2025-09-15T12:56:41.754Z] [1632729] WARN - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect is enabled, unable to read the device revision for nRF52. Returning only with the family
[2025-09-15T12:56:41.754Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> recover
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.754Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x010000f0 to SELECT = 0x08
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x02880000 from IDR
[2025-09-15T12:56:41.755Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Detected CTRL-AP revision 0 at AP 1
[2025-09-15T12:56:41.755Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:56:41.756Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:41.756Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:41.756Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:41.756Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000001 to TAR(mem-ap) or ERASEALL(ctrl-ap)
[2025-09-15T12:56:41.756Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:56:42.256Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:42.256Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:42.257Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:42.257Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:42.257Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:42.257Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:42.757Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:42.757Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:42.758Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:42.758Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:42.759Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:42.759Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:43.259Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:43.259Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:43.260Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:43.260Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:43.261Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:43.261Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:43.761Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:43.761Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:43.761Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:43.761Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:43.762Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:43.762Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:44.262Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:44.262Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:44.263Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:44.263Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:44.263Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:44.263Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:44.764Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:44.764Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:44.764Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:44.764Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:44.765Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:44.765Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:45.265Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:45.265Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:45.266Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:45.266Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:45.266Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:45.266Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:45.766Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:45.766Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:45.767Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:45.767Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:45.767Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:45.767Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:46.268Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:46.268Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:46.269Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:46.270Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:46.270Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:46.270Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:46.770Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:46.770Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:46.771Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:46.771Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:46.772Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:46.772Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:47.272Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:47.272Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:47.273Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:47.273Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:47.273Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:47.273Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:47.773Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:47.773Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:47.774Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:47.774Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:47.774Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:47.774Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:48.274Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:48.275Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:48.276Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:48.276Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:48.277Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:48.277Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:48.777Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:48.777Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:48.778Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:48.778Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:48.778Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:48.778Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:49.278Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:49.278Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:49.279Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:49.279Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:49.280Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:49.280Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:49.780Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:49.780Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:49.782Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:49.782Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:49.783Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:49.783Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:50.283Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:50.283Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:50.284Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:50.284Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:50.284Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:50.284Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:50.784Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:50.784Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:50.785Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:50.785Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:50.786Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:50.786Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.286Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.286Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.287Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.287Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.288Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:51.288Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.788Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.788Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.789Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.789Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.789Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:51.789Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.789Z] [1632729] WARN - [probe::tracing_logger] {jlink_usb_001050391982} Failed CTRL-AP erase when unprotecting nRF52 device:  Timed out erasing flash
[2025-09-15T12:56:51.789Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:56:51.789Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.790Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.790Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.790Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000001 to CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:56:51.790Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:56:51.800Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:56:51.800Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.801Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.801Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.802Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000000 to CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:56:51.802Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:56:51.802Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:56:51.802Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.803Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.803Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.803Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000000 to TAR(mem-ap) or ERASEALL(ctrl-ap)
[2025-09-15T12:56:51.803Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:56:51.853Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} -> Get AP-Protect Status
[2025-09-15T12:56:51.853Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.853Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.854Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.854Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.854Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:56:51.854Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.854Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.854Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x010000f0 to SELECT = 0x08
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x02880000 from IDR
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.855Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Detected CTRL-AP revision 0 at AP 1
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.855Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:51.856Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.856Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.856Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.856Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.856Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.856Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.857Z] [1632729] TRACE - [probe::tracing_logger] Got progress from worker.
[2025-09-15T12:56:51.857Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect status is 'All'
[2025-09-15T12:56:51.857Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} <- Get AP-Protect Status
[2025-09-15T12:56:51.858Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:56:51.858Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:51.858Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:51.858Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:51.858Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000001 to TAR(mem-ap) or ERASEALL(ctrl-ap)
[2025-09-15T12:56:51.858Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:56:52.358Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:52.358Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:52.359Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:52.359Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:52.360Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:52.360Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:52.860Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:52.860Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:52.861Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:52.861Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:52.861Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:52.862Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:53.362Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:53.362Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:53.362Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:53.362Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:53.363Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:53.363Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:53.863Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:53.863Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:53.864Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:53.864Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:53.865Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:53.865Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:54.365Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:54.365Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:54.367Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:54.367Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:54.368Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:54.368Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:54.868Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:54.868Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:54.869Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:54.869Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:54.869Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:54.869Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:55.370Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:55.370Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:55.370Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:55.370Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:55.371Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:55.371Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:55.871Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:55.871Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:55.872Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:55.872Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:55.872Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:55.872Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:56.373Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:56.373Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:56.374Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:56.374Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:56.375Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:56.375Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:56.875Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:56.875Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:56.876Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:56.876Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:56.877Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:56.877Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:57.377Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:57.377Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:57.377Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:57.377Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:57.378Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:57.378Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:57.878Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:57.878Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:57.879Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:57.879Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:57.879Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:57.879Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:58.379Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:58.379Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:58.380Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:58.380Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:58.381Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:58.381Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:58.881Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:58.881Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:58.883Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:58.883Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:58.883Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:58.884Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:59.384Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:59.384Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:59.384Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:59.384Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:59.385Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:59.385Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:56:59.885Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:56:59.885Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:56:59.886Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:56:59.886Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:56:59.886Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:56:59.886Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:00.386Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:00.386Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:00.387Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:00.387Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:00.387Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:00.387Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:00.887Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:00.887Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:00.888Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:00.888Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:00.888Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:00.888Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.388Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:01.388Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.389Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.389Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.389Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:01.389Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.890Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:01.890Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.890Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.890Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.890Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.891Z] [1632729] WARN - [probe::tracing_logger] {jlink_usb_001050391982} Failed CTRL-AP erase when unprotecting nRF52 device:  Timed out erasing flash
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000001 to CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:57:01.891Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:01.901Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:01.901Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.902Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.902Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.902Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000000 to CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:57:01.902Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:01.902Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:01.902Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.903Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000000 to TAR(mem-ap) or ERASEALL(ctrl-ap)
[2025-09-15T12:57:01.903Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:01.953Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} -> Get AP-Protect Status
[2025-09-15T12:57:01.953Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:01.953Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.953Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.953Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x010000f0 to SELECT = 0x08
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.954Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x02880000 from IDR
[2025-09-15T12:57:01.954Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Detected CTRL-AP revision 0 at AP 1
[2025-09-15T12:57:01.955Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.955Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.955Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:57:01.955Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.955Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:01.955Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.956Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.956Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.956Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:57:01.956Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.956Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:01.956Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:01.957Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect status is 'All'
[2025-09-15T12:57:01.957Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} <- Get AP-Protect Status
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] Got progress from worker.
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000001 to TAR(mem-ap) or ERASEALL(ctrl-ap)
[2025-09-15T12:57:01.957Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:02.457Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:02.457Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:02.458Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:02.458Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:02.458Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:02.458Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:02.958Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:02.958Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:02.959Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:02.959Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:02.959Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:02.959Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:03.459Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:03.459Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:03.460Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:03.460Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:03.460Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:03.460Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:03.960Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:03.960Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:03.961Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:03.961Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:03.961Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:03.961Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:04.461Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:04.461Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:04.462Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:04.462Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:04.462Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:04.462Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:04.962Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:04.962Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:04.963Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:04.963Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:04.963Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:04.963Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:05.463Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:05.463Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:05.464Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:05.464Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:05.464Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:05.464Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:05.964Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:05.964Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:05.965Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:05.965Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:05.965Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:05.965Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:06.465Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:06.465Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:06.467Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:06.467Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:06.467Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:06.467Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:06.968Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:06.968Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:06.968Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:06.968Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:06.969Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:06.969Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:07.469Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:07.469Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:07.470Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:07.470Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:07.470Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:07.470Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:07.970Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:07.970Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:07.971Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:07.971Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:07.971Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:07.971Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:08.471Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:08.471Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:08.472Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:08.472Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:08.472Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:08.472Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:08.972Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:08.972Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:08.974Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:08.983Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:08.983Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:08.983Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:09.475Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:09.475Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:09.475Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:09.475Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:09.475Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:09.475Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:09.975Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:09.976Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:09.976Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:09.976Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:09.976Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:09.976Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:10.476Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:10.477Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:10.477Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:10.477Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:10.477Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:10.477Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:10.977Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:10.977Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:10.978Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:10.978Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:10.978Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:10.978Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:11.478Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:11.478Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:11.479Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:11.479Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:11.479Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:11.479Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:11.979Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:11.979Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:11.980Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:11.980Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:11.980Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
[2025-09-15T12:57:11.980Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:11.980Z] [1632729] WARN - [probe::tracing_logger] {jlink_usb_001050391982} Failed CTRL-AP erase when unprotecting nRF52 device:  Timed out erasing flash
[2025-09-15T12:57:11.980Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:11.980Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:11.982Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:11.982Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:11.982Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000001 to CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:57:11.982Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:11.992Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:11.992Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:11.993Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:11.993Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:11.993Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000000 to CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:57:11.993Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:11.993Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_ap
[2025-09-15T12:57:11.993Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:11.994Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:11.994Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:11.994Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Submitted write to AP 1: Write 0x00000000 to TAR(mem-ap) or ERASEALL(ctrl-ap)
[2025-09-15T12:57:11.994Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_ap
[2025-09-15T12:57:12.044Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} -> Get AP-Protect Status
[2025-09-15T12:57:12.044Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:12.044Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.045Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:12.045Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.045Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
[2025-09-15T12:57:12.045Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:12.045Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:12.045Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x010000f0 to SELECT = 0x08
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x02880000 from IDR
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:12.046Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Detected CTRL-AP revision 0 at AP 1
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.046Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:12.047Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:57:12.047Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:12.047Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:12.047Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.047Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:12.047Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.048Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x01000000 to SELECT = 0x08
[2025-09-15T12:57:12.048Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.048Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:57:12.048Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:12.048Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_ap
[2025-09-15T12:57:12.048Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} AP 1 read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_ap
[2025-09-15T12:57:12.049Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} AP-Protect status is 'All'
[2025-09-15T12:57:12.049Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} <- Get AP-Protect Status
[2025-09-15T12:57:12.049Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} -> Powering down debug region
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] Got progress from worker.
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0xf0000040 from CTRL/STAT
[2025-09-15T12:57:12.049Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0xf0000040 from CTRL/STAT
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:57:12.050Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to CTRL/STAT = 0x04
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> write_dp_unchecked
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP wrote 0x00000000 to SELECT = 0x08
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- write_dp_unchecked
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} -> read_dp
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} DP read 0x00000040 from CTRL/STAT
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} <- read_dp
[2025-09-15T12:57:12.053Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Powered down sys and dbg regions in 3 ms
[2025-09-15T12:57:12.053Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- Powering down debug region
[2025-09-15T12:57:12.053Z] [1632729] INFO - [probe::tracing_logger] {jlink_usb_001050391982} <- recover
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] Got device error response
[2025-09-15T12:57:12.053Z] [1632729] TRACE - [probe::tracing_logger] Expecting trace channel to disconnect.
[2025-09-15T12:57:12.053Z] [1632729] DEBUG - [probe::tracing_logger] Terminating worker with id 1632758
[2025-09-15T12:57:12.054Z] [1632729] TRACE - [probe::tracing_logger] Waiting for worker to exit.
[2025-09-15T12:57:12.054Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Probe worker received message: Shutdown
[2025-09-15T12:57:12.054Z] [1632729] TRACE - [probe::tracing_logger] {jlink_usb_001050391982} Closing emulator connection
[2025-09-15T12:57:12.055Z] [1632729] TRACE - [probe::tracing_logger] Waiting for worker to exit.
[2025-09-15T12:57:12.056Z] [1632729] TRACE - [probe::tracing_logger] Waiting for worker to exit.
[2025-09-15T12:57:12.058Z] [1632729] TRACE - [probe::tracing_logger] Waiting for worker to exit.
[2025-09-15T12:57:12.060Z] [1632729] DEBUG - [probe::tracing_logger] {jlink_usb_001050391982} Probe worker stopped.
[2025-09-15T12:57:12.061Z] [1632729] TRACE - [probe::tracing_logger] Waiting for worker to exit.
[2025-09-15T12:57:12.062Z] [1632729] TRACE - [probe::tracing_logger] Trace channel disconnected as expected.
[2025-09-15T12:57:12.062Z] [1632729] TRACE - [probe::tracing_logger] Trace thread ends now...
[2025-09-15T12:57:12.066Z] [1632729] INFO - [probe::tracing_logger] Worker exited successfully
[2025-09-15T12:57:12.066Z] [1632729] TRACE - [probe::tracing_logger] Joined trace thread.
[2025-09-15T12:57:12.066Z] [1632729] DEBUG - [nrfdl::operation_worker] join thread finished: true
[2025-09-15T12:57:12.066Z] [1632729] TRACE - [boardcontroller] BoardControllerPlugin::drop - ref 0x640bae0c0a90
[2025-09-15T12:57:12.066Z] [1632729] TRACE - [sdfu] SdfuPlugin::drop - ref 0x640bae08f930
[2025-09-15T12:57:12.066Z] [1632729] TRACE - [mcuboot] McuBootPlugin::drop - ref 0x640bae0bd1c0
