GPIO_OUTPUT_ACTIVE meaning
I have a pin that controls the power flow to the sensors on my board.
it is active low, when it gets a raw value of 0, it allows the power flow to the sensors.
I have these two pieces of code that, from my understanding, are supposed to create the same result from the pin's perspective.
first block:
void configure_and_set_sensor_power_pin(){
      gpio_pin_configure(gpio_dev1, 10, GPIO_OUTPUT);
      gpio_pin_set(gpio_dev1, 10, 0);
second block:
      gpio_pin_configure(gpio_dev1, 10, GPIO_OUTPUT_ACTIVE);
from my understanding, GPIO_OUTPUT_ACTIVE only means it sets the first value to 1, gpio_pin_set(gpio_dev1, 10, 0); should be setting it to 0 regardless.
in practice, only the first block works, the second block doesn't.
why is that?
thanks in advance,
shlomo
  • Hello Shlomo,
    After a quick look at this, if it is active low, my understanding is this:
    The first block gpio_pin_set() sets it inactive, meaning high.
    In the second block, then gpio_pin_configure(gpio_dev1, 10, GPIO_OUTPUT_ACTIVE) sets it at first active, meaning low. Then gpio_pin_configure() sets it inactive, meaning high.
    So both would end up high, but how they get there is a bit different. In what way are you seeing the two differ?
    Elfving
