s140_nrf52_7.0.1_softdevice.hex 500k and 2M
    Can I disable coded phy 500k and phy 2M when using the nrf52833 protocol stack from s140_nrf52_7.0.1_softdevice.hex?
  • Hi
    The 500k Coded PHY is not supported on the nRF5 SDK in the first place. If you only want to use the 1MBPS PHY, you can make sure to set only the 1MBPS PHY in your advertising initiailization function and that should result in you only using the 1MBPS PHY:
    init.config.ble_adv_primary_phy       = BLE_GAP_PHY_1MBPS;
    init.config.ble_adv_secondary_phy     = BLE_GAP_PHY_1MBPS;
    Simon
