My devices restart app but no log
When my device receives data from the Xiaomi Zigbee switch, sometimes it reboots without any logs.
(Note: Normally, when there’s a bug, the device pushes logs to UART, but in this case, there’s nothing.)
#:[00:01:12.909] APP_DBG callback_handle.c:77 Device send command info:
[00:01:12.918] APP_DBG callback_handle.c:78 Short addr : 0x0C2B
[00:01:12.926] APP_DBG callback_handle.c:79 Endpoint : 1
[00:01:12.933] APP_DBG callback_handle.c:80 Cluster ID : 6 (0x0006)
[00:01:12.941] APP_DBG callback_handle.c:81 Command ID : 10 (0x0A)
[00:01:12.949] APP_DBG callback_handle.c:82 Direction : 1 (To Client)
[00:01:12.958] APP_DBG callback_handle.c:86 Send response : 1 (Do NOT send default response)
[00:01:12.968] APP_DBG callback_handle.c:39 Payload data: (len = 4):
[00:01:12.977] APP_DBG callback_handle.c:40 << START PAYLOAD >>
[00:01:12.984] APP_DBG callback_handle.c:71 0x0000: 00 80 20 03 | .. .
[00:01:12.994] APP_DBG callback_handle.c:73 << END PAYLOAD >>
[00:01:13.002] APP_DBG callback_handle.c:164 [ZCL RSSI] src:0x0C2B cluster:0x0006 cmd:0x0A LQI:169 RSSI:-25 dBm
[00:01:13.014] APP_DBG callback_handle.c:172 CB ==> Handle Client command
[00:01:13.022] APP_DBG callback_handle.c:327 [ONOFF][CLIENT] Report Attribute received from 0x0C2B, endpoint 1
[00:01:13.034] APP_DBG callback_handle.c:328 Payload len = 4
[00:01:13.042] APP_DBG callback_handle.c:336 - Attribute ID : 0x32768
[00:01:13.050] APP_DBG callback_handle.c:337 - Type : 0x32
[00:01:13.058] APP_DBG callback_handle.c:338 - Value : 3 (0x03)
[00:01:13.067] APP_DBG callback_handle.c:355 => Button Action: TRIPLE CLICK
[00:04:21.168] APP_DBG callback_handle.c:77 Device send command info:
[00:04:21.177] APP_DBG callback_handle.c:78 Short addr : 0x0C2B
[00:04:21.185] APP_DBG callback_handle.c:79 Endpoint : 1
[00:04:21.192] APP_DBG callback_handle.c:80 Cluster ID : 6 (0x0006)
[00:04:21.200] APP_DBG callback_handle.c:81 Command ID : 10 (0x0A)
[00:04:21.209] APP_DBG callback_handle.c:82 Direction : 1 (To Client)
[00:04:21.217] APP_DBG callback_handle.c:86 Send response : 1 (Do NOT send default response)
[00:04:21.227] APP_DBG callback_handle.c:39 Payload data: (len = 4):
[00:04:21.236] APP_DBG callback_handle.c:40 << START PAYLOAD >>
[00:04:21.243] APP_DBG callback_handle.c:71 0x0000: 00 00 10 00 | ....
[00:04:21.253] APP_DBG callback_handle.c:73 << END PAYLOAD >>
[00:04:21.261] APP_DBG callback_handle.c:164 [ZCL RSSI] src:0x0C2B cluster:0x0006 cmd:0x0A LQI:169 RSSI:-33 dBm
[00:04:21.273] APP_DBG callback_handle.c:172 CB ==> Handle Client command
[00:04:21.281] APP_DBG callback_handle.c:327 [ONOFF][CLIENT] Report Attribute received from 0x0C2B, endpoint 1
[00:04:21.293] APP_DBG callback_handle.c:328 Payload len = 4
[00:04:21.301] APP_DBG callback_handle.c:336 - Attribute ID : 0x0000
[00:04:21.309] APP_DBG callback_handle.c:337 - Type : 0x16
[00:04:21.317] APP_DBG callback_handle.c:338 - Value : 0 (0x00)
[00:04:21.326] APP_DBG callback_handle.c:346 => Device is now OFF
▒I: nRF5 802154 radio initialized
*** Booting nRF Connect SDK v2.9.2-4ab7b98fc76f ***
*** Using Zephyr OS v3.7.99-aa34a5632971 ***
[00:00:00.016] APP_PRINT app.cpp:33 Starting Zigbee Gateway Application...
[00:00:00.025] APP_PRINT app.cpp:36 Main thread starting
[00:00:00.032] APP_DBG led.cpp:35 Init led
[TaskCreate] TaskSystem id: 0 StackSize: 0x1000 Prio: 10 Cb: 0x000084D9
[TaskCreate] TaskSerial id: 1 StackSize: 0x1000 Prio: 8 Cb: 0x000081D1
[TaskCreate] TaskZigbee id: 2 StackSize: 0x1000 Prio: 10 Cb: 0x00008705
[TaskCreate] TaskConsole id: 3 StackSize: 0x1000 Prio: 10 Cb: 0x00007E85
[00:00:00.501] APP_PRINT app_console.cpp:137 Init console !!!
[00:00:00.508] APP_LOG app_console.cpp:141 [Console] ==> Started [3]
Is it possible that the device was rebooted by the ZBOSS library without any logs being pushed to UART? I need some advice on how to debug this issue. It only occurs during data exchange with another device.
