west build failed due to mcuboot sysbuild
With NCS v3.1.0 and Nordic's downstream zephyr ncs-v3.1.0, I got build failure with following message:
warning: attempt to assign the value 'n' to the undefined symbol MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
This failure can be reproduced by building sample 'with_mcuboot'.
Command as below:
west build -p always -b nrf52840dk/nrf52840 zephyr/samples/sysbuild/with_mcuboot --sysbuild
But I can succeed to build it without '--sysbuild'. And BTW, with same system (machine with Ubuntu v22.04 installed) I can build this sample with original 'zephyr' according to 'Getting Started Guide'
docs.zephyrproject.org/.../index.html
  • Could you upload your nrf/west.yml file?
  • Hi Benjamin,
    Here you are.
    (v3.1.0) luser@zephyrbuild:~/ncs/v3.1.0/nrf$ cat west.yml
    # The west manifest file (west.yml) for the nRF Connect SDK (NCS).
    # The per-workspace west configuration file, ncs/.west/config,
    # specifies the location of this manifest file like this:
    #     [manifest]
    #     path = nrf
    # See the west documentation for more information:
    # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/guides/west/index.html
    manifest:
      version: "0.13"
      # "remotes" is a list of locations where git repositories are cloned
      # and fetched from.
      remotes:
        # nRF Connect SDK GitHub organization.
        # NCS repositories are hosted here.
        - name: ncs
          url-base: https://github.com/nrfconnect
        # Third-party repository sources:
        - name: zephyrproject
          url-base: https://github.com/zephyrproject-rtos
        - name: throwtheswitch
          url-base: https://github.com/ThrowTheSwitch
        - name: dragoon
          url-base: https://projecttools.nordicsemi.no/bitbucket/scm/drgn
        - name: memfault
          url-base: https://github.com/memfault
        - name: babblesim
          url-base: https://github.com/BabbleSim
        - name: bosch
          url-base: https://github.com/boschsensortec
        - name: eembc
          url-base: https://github.com/eembc
      # If not otherwise specified, the projects below should be obtained
      # from the ncs remote.
      defaults:
        remote: ncs
      group-filter:
        - -nrf-802154
        - -dragoon
        - -find-my
        - -babblesim
        - -libmodem
        - -bsec
        - -doc-internal
        - +optional
      # "projects" is a list of git repositories which make up the NCS
      # source code.
      # For 'userdata' fields in the projects area, please refer to:
      # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/dm_code_base.html
      projects:
        # The Zephyr RTOS fork in the NCS, along with the subset of its
        # modules which NCS imports directly.
        # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/introduction/index.html
        # https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/guides/modules.html
        - name: zephyr
          repo-path: sdk-zephyr
          revision: ncs-v3.1.0
          import:
            # In addition to the zephyr repository itself, NCS also
            # imports the contents of zephyr/west.yml at the above
            # revision. Only the projects explicitly named in the
            # following allowlist are imported.
            # Note that the zephyr west extensions (like 'build', 'flash',
            # 'debug', etc.) are automatically provided by this import, so
            # there's no need to add a redundant west-commands: key for
            # the zephyr project.
            # Please keep this list sorted alphabetically.
            name-allowlist:
              - canopennode
              - chre
              - cmsis
              - cmsis-dsp
              - cmsis-nn
              - cmsis_6
              - edtt
              - fatfs
              - hal_nordic
              - hal_st # required for ST sensors (unrelated to STM32 MCUs)
              - hal_tdk # required for Invensense sensors such as ICM42670
              - hal_wurthelektronik
              - liblc3
              - libmetal
              - littlefs
              - loramac-node
              - lvgl
              - lz4
              - mipi-sys-t
              - nanopb
              - net-tools
              - nrf_hw_models
              - nrf_wifi
              - open-amp
              - percepio
              - picolibc
              - segger
              - tf-m-tests
              - tinycrypt
              - uoscore-uedhoc
              - zcbor
              - zscilib
        # NCS repositories.
        # Some of these are also Zephyr modules which have NCS-specific
        # changes.
        - name: hostap
          repo-path: sdk-hostap
          path: modules/lib/hostap
          revision: 2b5c82cd4e833c065075bc239a7bd138d4662e34
        - name: wfa-qt-control-app
          repo-path: sdk-wi-fiquicktrack-controlappc
          path: modules/lib/wfa-qt-control-app
          revision: d4bc010be69aa89290c5af6767702ff46c1829e5
          userdata:
            ncs:
              upstream-url: https://github.com/Wi-FiQuickTrack/Wi-FiQuickTrack-ControlAppC
              upstream-sha: 1225729e8d84075f03bf9fc51eee85d84dfb0091
              compare-by-default: true
        - name: mcuboot
          repo-path: sdk-mcuboot
          path: bootloader/mcuboot
        - name: qcbor
          url: https://github.com/laurencelundblade/QCBOR
          revision: 751d36583a9ce1a640900c57e13c9b6b8f3a2ba2
          path: modules/tee/tf-m/qcbor
        - name: mbedtls
          path: modules/crypto/mbedtls
          repo-path: sdk-mbedtls
        - name: oberon-psa-crypto
          path: modules/crypto/oberon-psa-crypto
          repo-path: sdk-oberon-psa-crypto
        - name: nrfxlib
          repo-path: sdk-nrfxlib
          path: nrfxlib
          revision: v3.1.0
        - name: trusted-firmware-m
          repo-path: sdk-trusted-firmware-m
          path: modules/tee/tf-m/trusted-firmware-m
        - name: psa-arch-tests
          repo-path: sdk-psa-arch-tests
          path: modules/tee/tf-m/psa-arch-tests
          revision: 3da9313e64806d352c519e3205e81cf959067588
        - name: matter
          repo-path: sdk-connectedhomeip
          path: modules/lib/matter
          revision: v3.1.0
          west-commands: scripts/west/west-commands.yml
          submodules:
            - name: nlio
              path: third_party/nlio/repo
            - name: nlassert
              path: third_party/nlassert/repo
            - name: pigweed
              path: third_party/pigweed/repo
            - name: jsoncpp
              path: third_party/jsoncpp/repo
          userdata:
            ncs:
              upstream-url: https://github.com/project-chip/connectedhomeip
              upstream-sha: 181b0cb14ff007ec912f2ba6627e05dfb066c008
              compare-by-default: false
        - name: nrf-802154
          repo-path: sdk-nrf-802154
          path: nrf-802154
          revision: v3.1.0
          groups:
            - nrf-802154
        - name: dragoon
          # Only for internal Nordic development
          repo-path: dragoon.git
          remote: dragoon
          revision: fcde41eba2d1422400b5f8579fac9d9eaac9b434
          groups:
            - dragoon
        - name: cjson
          repo-path: sdk-cjson
          path: modules/lib/cjson
          revision: c6af068b7f05207b28d68880740e4b9ec1e4b50a
          userdata:
            ncs:
              upstream-url: https://github.com/DaveGamble/cJSON
              upstream-sha: d2735278ed1c2e4556f53a7a782063b31331dbf7
        - name: find-my
          repo-path: sdk-find-my
          revision: v3.1.0
          groups:
            - find-my
        - name: azure-sdk-for-c
          repo-path: azure-sdk-for-c
          path: modules/lib/azure-sdk-for-c
          revision: 308c171cb4b5eed266649012a68406487ec81fb2
          userdata:
            ncs:
              upstream-url: https://github.com/Azure/azure-sdk-for-c
              upstream-sha: adc56bc6138a28b5490bce339a31a2581a072092
        - name: cirrus
          repo-path: sdk-mcu-drivers
          path: modules/hal/cirrus-logic
          revision: 3873a08377d93a479105a75ac390d3bbcd31d690
          userdata:
            ncs:
              upstream-url: https://github.com/CirrusLogic/mcu-drivers
              upstream-sha: 1be6ca7253133a21a1e9fe0fbb4656e17d63a936
        - name: libmodem
          revision: 5dc5bc768dda0ddf9974920c618b70da5d67c6c3
          groups:
            - libmodem
        - name: openthread
          repo-path: sdk-openthread
          path: modules/lib/openthread
          revision: ncs-thread-reference-20250402
          userdata:
            ncs:
              upstream-url: https://github.com/openthread/openthread
              upstream-sha: c6eaeda5a1c1c5dbb24dce7e027340cb8893a77b
        - name: doc-internal
          repo-path: doc-internal
          path: modules/doc-internal
          revision: ae9f21960477636720a72ced869a6c342d502484
          groups:
            - doc-internal
        # Other third-party repositories.
        - name: cmock
          path: test/cmock
          submodules: true
          revision: f65066f15d8248e6dcb778efb8739904a4512087
          remote: throwtheswitch
        - name: memfault-firmware-sdk
          path: modules/lib/memfault-firmware-sdk
          revision: 1.26.0
          remote: memfault
        - name: bsim
          repo-path: bsim_west
          remote: babblesim
          revision: a88d3353451387ca490a6a7f7c478a90c4ee05b7
          import:
            path-prefix: tools
        - name: bme68x
          repo-path: Bosch-BME68x-Library
          remote: bosch
          path: modules/lib/bme68x
          revision: v1.1.40407
          groups:
            - bsec
        - name: bsec
          repo-path: Bosch-BSEC2-Library
          remote: bosch
          path: modules/lib/bsec
          revision: v1.5.2400
          groups:
            - bsec
        - name: coremark
          remote: eembc
          path: modules/benchmark/coremark
          revision: d5fad6bd094899101a4e5fd53af7298160ced6ab
          groups:
            - benchmark
      # West-related configuration for the nrf repository.
      self:
        # This repository should be cloned to ncs/nrf.
        path: nrf
        # This line configures west extensions.
        west-commands: scripts/west-commands.yml
  • The warning and error you are getting is because the build system doesn't find the Kconfig symbol MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION. This Kconfig symbol is defined in the following file:
    v3.1.0/nrf/sysbuild/Kconfig.mcuboot
    Could you check if you have this file and if the Kconfig symbol is defined there?
  • Hi Benjamin,
    Yes, there is item 'MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION' defined in Kconfig.mcuboot. But I don't understand that the building procedure is passed with *mcuboot* and is failed at application part, ie. 'with_mcuboot', in my previous example.
    (v3.1.0) luser@zephyrbuild:~/ncs/v3.1.0/nrf$ cat sysbuild/Kconfig.mcuboot
    # Copyright (c) 2023 Nordic Semiconductor
    menu "MCUboot configuration"
            depends on BOOTLOADER_MCUBOOT
    config MCUBOOT_SIGN_MERGED_BINARY
            bool "Sign single, merged update package [EXPERIMENTAL]"
            default y if (MCUBOOT_MODE_DIRECT_XIP || MCUBOOT_MODE_DIRECT_XIP_WITH_REVERT)
            depends on SOC_NRF54H20
            select EXPERIMENTAL
    config MCUBOOT_BUILD_DIRECT_XIP_VARIANT
            bool "Build DirectXIP variant image"
            depends on MCUBOOT_MODE_DIRECT_XIP || MCUBOOT_MODE_DIRECT_XIP_WITH_REVERT
            default y
            help
              Will build the alternative slot (variant) image of the main application.
    menuconfig MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
            bool "Downgrade prevention using hardware security counters"
            depends on (SOC_NRF5340_CPUAPP || SOC_SERIES_NRF91X || SOC_SERIES_NRF54LX)
            depends on !SECURE_BOOT_APPCORE
            depends on !QSPI_XIP_SPLIT_IMAGE
            help
              This option can be enabled by the application and will ensure that the
              MCUBOOT_HW_DOWNGRADE_PREVENTION Kconfig option is enabled in the MCUboot image.
              Note that this can only be used on first image, it will not be applied to the second
              image (network core updates) on nRF5340 which will use software downgrade protection
              on the network core CPU instead.
    if MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
    config MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS
            int "Number of available hardware counter slots"
            default 240
            range 2 300
            help
              When MCUBOOT_HW_DOWNGRADE_PREVENTION is enabled, MCUboot will use one hardware counter
              for each updatable image (UPDATEABLE_IMAGE_NUMBER). This configuration specifies how many
              counter slots will be allocated for each hardware counter. The hardware counters are
              stored in OTP storage. The rationale for the default number (240): Assume one update a
              month for 10 years, then double that value just in case. This default fits comfortably
              within the OTP region of UICR.
    config MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_VALUE
            int "Security counter value"
            default 1
            range 1 65535
            help
              The security counter value for this image.
              This is the value that will be passed to the --security-counter parameter of imgtool.py
    endif # MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
    config MCUBOOT_COMPRESSED_IMAGE_SUPPORT
            bool "Compressed image support"
            depends on MCUBOOT_MODE_OVERWRITE_ONLY
            help
              When enabled, supports loading compressed images using LZMA2 to the secondary slot which
              will then be decompressed and loaded to the primary slot.
    config MCUBOOT_MAX_UPDATEABLE_IMAGES
            int
            default 1 if MCUBOOT_MODE_SINGLE_APP
            default 4
    config MCUBOOT_APPLICATION_IMAGE_NUMBER
            int
            default 0
    config MCUBOOT_NETWORK_CORE_IMAGE_NUMBER
            int
            default 1 if NETCORE_APP_UPDATE && !MCUBOOT_MODE_SINGLE_APP
            default 1 if BOOTLOADER_MCUBOOT && !NETCORE_NONE && (SOC_NRF54H20 && !MCUBOOT_SIGN_MERGED_BINARY)
            default -1
    config MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER
            int
            default 2 if (WIFI_PATCHES_EXT_FLASH_XIP || WIFI_PATCHES_EXT_FLASH_STORE) && MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1
            default 1 if (WIFI_PATCHES_EXT_FLASH_XIP || WIFI_PATCHES_EXT_FLASH_STORE)
            default -1
    config MCUBOOT_QSPI_XIP_IMAGE_NUMBER
            int
            default 3 if QSPI_XIP_SPLIT_IMAGE && MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 && MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1
            default 2 if QSPI_XIP_SPLIT_IMAGE && MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1
            default 1 if QSPI_XIP_SPLIT_IMAGE
            default -1
    config MCUBOOT_MCUBOOT_IMAGE_NUMBER
            int
            default 4 if SECURE_BOOT_APPCORE && MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 && MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1 && MCUBOOT_QSPI_XIP_IMAGE_NUMBER != 1
            default 3 if SECURE_BOOT_APPCORE && ((MCUBOOT_QSPI_XIP_IMAGE_NUMBER != -1 && (MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 || MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1)) || (MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 && MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1))
            default 2 if SECURE_BOOT_APPCORE && (MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 || MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1 || MCUBOOT_QSPI_XIP_IMAGE_NUMBER != -1)
            default 1 if SECURE_BOOT_APPCORE
            default -1
    config MCUBOOT_MIN_UPDATEABLE_IMAGES
            int
            default 4 if MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 && MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1 && MCUBOOT_QSPI_XIP_IMAGE_NUMBER != -1
            default 3 if (MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 && MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1) || (MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 && MCUBOOT_QSPI_XIP_IMAGE_NUMBER != -1) || (MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1 && MCUBOOT_QSPI_XIP_IMAGE_NUMBER != -1)
            default 2 if MCUBOOT_NETWORK_CORE_IMAGE_NUMBER != -1 || MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER != -1 || MCUBOOT_QSPI_XIP_IMAGE_NUMBER != -1
            default 1
    config MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES
            int
            default 1 if MCUBOOT_MCUBOOT_IMAGE_NUMBER != -1
            default 0
    config MCUBOOT_UPDATEABLE_IMAGES
            int "Updateable images"
            range MCUBOOT_MIN_UPDATEABLE_IMAGES MCUBOOT_MAX_UPDATEABLE_IMAGES
            help
              The number of images that MCUboot will be built with. Note that if
              ``MCUBOOT_ADDITIONAL_UPDATEABLE_IMAGES`` is set to a non-zero value then that value will
              be added to the MCUboot updateable image number but not the application, this is to allow
              for features like NSIB updates of MCUboot itself.
    config MCUBOOT_ADDITIONAL_UPDATEABLE_IMAGES
            int "Additional MCUboot-only updateable images"
            range MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES
            default MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES
            help
              The number of additional images that MCUboot will be built with.
    config MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES
            bool "Sync updateable image value to main application"
            default y
            help
              If enabled then will synchronise the value of ``MCUBOOT_UPDATEABLE_IMAGES`` to MCUboot
              and the main application, if disabled then will only set this value to MCUboot.
              Note: ``MCUBOOT_MIN_ADDITIONAL_UPDATEABLE_IMAGES`` will be applied to MCUboot only
              irrespective of this option.
    config SECURE_BOOT_MCUBOOT_VERSION
            string "MCUboot S0/S1 image update version"
            default "0.0.0+0"
            depends on SECURE_BOOT
            help
              The version of the MCUboot S0/S1 upgrade package
    choice BOOT_SIGNATURE_TYPE
            default BOOT_SIGNATURE_TYPE_RSA if THINGY91_STATIC_PARTITIONS_FACTORY
            default BOOT_SIGNATURE_TYPE_ED25519 if SOC_SERIES_NRF54LX || SOC_SERIES_NRF54HX
            default BOOT_SIGNATURE_TYPE_ECDSA_P256 if ((SOC_NRF52840 || SOC_SERIES_NRF91X) && !BOARD_THINGY91_NRF9160 && !BOARD_THINGY91_NRF52840)
            default BOOT_SIGNATURE_TYPE_ECDSA_P256 if SECURE_BOOT_APPCORE
    endchoice
    config BOOT_SIGNATURE_TYPE_PURE
            bool "Verify signature directly over image"
            depends on SOC_SERIES_NRF54LX
            depends on BOOT_SIGNATURE_TYPE_ED25519
            help
              The image signature will be verified over image rather than
              hash of an image.
              This option is currently only supported with ED25519 and configurations
              where both image slots are within internal SoC device storage.
    config BOOT_IMG_HASH_ALG_SHA512
            bool "Use SHA512 for image hash calculation"
            default y if SOC_SERIES_NRF54LX || SOC_SERIES_NRF54HX
            help
              The image hash will be calculated using SHA512 algorithm.
    config MCUBOOT_SIGNATURE_USING_KMU
            bool "Use KMU stored keys for signature verification"
            help
              The device needs to be provisioned with proper set of keys.
    config MCUBOOT_SIGNATURE_USING_ITS
            bool "Use ITS stored keys for signature verification [EXPERIMENTAL]"
            depends on SOC_SERIES_NRF54HX
            select EXPERIMENTAL
            help
    config BOOT_SHARED_CRYPTO_ECDSA_P256
            bool "Use external crypto from NSIB for ECDSA P256 signature"
            depends on SECURE_BOOT_APPCORE && SECURE_BOOT_SIGNATURE_TYPE_ECDSA
            depends on BOOT_SIGNATURE_TYPE_ECDSA_P256 && !SOC_SERIES_NRF54LX
            default y
    config MCUBOOT_GENERATE_DEFAULT_KMU_KEYFILE
            bool "Generate default keyfile for provisioning during build"
            depends on MCUBOOT_SIGNATURE_USING_KMU
            help
              If enabled, the build system will generate keyfile.json file in the build directory.
    endif
    config MCUBOOT_USE_ALL_AVAILABLE_RAM
            bool "Allow MCUboot to use all available RAM"
            depends on BOARD_IS_NON_SECURE
            help
              By default MCUboot uses only the secure RAM partition.
    config MCUBOOT_NRF53_MULTI_IMAGE_UPDATE
            bool "Network core multi-image update (in single operation)"
            depends on NETCORE_APP_UPDATE
            depends on !MCUBOOT_MODE_SINGLE_APP
            help
              If selected, network core image updates can be applied in a single operation. This is
              required if the secondary partition resides in off-chip memory.
              Note: if not using overwrite only mode for MCUboot, this can result in a bricked device
              upon firmware reverts.
    endmenu
  • Hi Dunk,
    I have looked at your ticket again and I made a mistake in my previous reply.
    This is the file I want you to look at:
    v3.1.0/nrf/modules/mcuboot/Kconfig
    Can you confirm MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is defined in the file if you have it?
