west build failed due to mcuboot sysbuild
With NCS v3.1.0 and Nordic's downstream zephyr ncs-v3.1.0, I got build failure with following message:
warning: attempt to assign the value 'n' to the undefined symbol MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
This failure can be reproduced by building sample 'with_mcuboot'.
Command as below:
west build -p always -b nrf52840dk/nrf52840 zephyr/samples/sysbuild/with_mcuboot --sysbuild
But I can succeed to build it without '--sysbuild'. And BTW, with same system (machine with Ubuntu v22.04 installed) I can build this sample with original 'zephyr' according to 'Getting Started Guide'
docs.zephyrproject.org/.../index.html
  • Hi Benjamin,
    Here is the file, yes, MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is presented as well.
    (v3.1.0) luser@zephyrbuild:~/ncs$ cat v3.1.0/nrf/modules/mcuboot/Kconfig
    menu "MCUboot"
    if BOOTLOADER_MCUBOOT
    menuconfig MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
            bool "Downgrade prevention using hardware security counters"
            depends on SOC_NRF5340_CPUAPP || SOC_SERIES_NRF91X || SOC_SERIES_NRF54LX
            help
              This option can be enabled by the application and will ensure
              that the MCUBOOT_HW_DOWNGRADE_PREVENTION Kconfig option is
              enabled in the MCUboot image.
    if MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
    config MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS
            int "Number of available hardware counter slots"
            default 240
            range 2 300
            help
              When MCUBOOT_HW_DOWNGRADE_PREVENTION is enabled, MCUboot will use
              one hardware counter for each updatable image (UPDATEABLE_IMAGE_NUMBER).
              This configuration specifies how many counter slots will be allocated
              for each hardware counter. The hardware counters are stored in OTP storage.
              The rationale for the default number (240): Assume one update a month for
              10 years, then double that value just in case. This default fits
              comfortably within the OTP region of UICR.
    config MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_VALUE
            int "Security counter value"
            default 1
            range 1 65535
            help
              The security counter value for this image.
              This is the value that will be passed to the --security-counter
              parameter of imgtool.py
    endif # MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION
    # HACK: NCS temphack to keep our imgtool integration working now that
    # there is no CONFIG_DT_* CMake namespace anymore. Use Zephyr
    # kconfigfunctions to thread the flash write block size through
    # Kconfig so it can be accessed from CMake. Needs a better solution.
    DT_ZEPHYR_FLASH := zephyr,flash
    DT_CHOSEN_ZEPHYR_FLASH := $(dt_chosen_path,$(DT_ZEPHYR_FLASH))
    config MCUBOOT_FLASH_WRITE_BLOCK_SIZE
            int
            default $(dt_node_int_prop_int,$(DT_CHOSEN_ZEPHYR_FLASH),write-block-size)
    endif # BOOTLOADER_MCUBOOT
    config DT_FLASH_WRITE_BLOCK_SIZE
            int
    config MCUBOOT_USB_SUPPORT
            bool
            default y if "$(dt_nodelabel_enabled,zephyr_udc0)"
    config USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY
            bool "Allow nRF53 multi-image update support [dangerous]"
            help
              Enabling this option allows you to use NRF53_MULTI_IMAGE update
              without having BOOT_UPGRADE_ONLY enabled, allowing you to use
              different swapping methods. This will however give you the potential
              of bricking the network core upon reverts.
    config MCUBOOT_USE_ALL_AVAILABLE_RAM
            bool "Allow MCUBoot to use all available RAM"
            depends on ARM_TRUSTZONE_M
            default y if BOARD_THINGY53_NRF5340_CPUAPP_NS || BOARD_THINGY53_NRF5340_CPUAPP
            help
              By default MCUBoot uses only the secure RAM partition.
    endmenu
  • Thanks. I suspect something may have gone wrong in your system-wide installation of NCS. Did you deviate from the setup steps at any point?
    Could you share the build folder generated during the failed build?
  • Hi Benjamin,
    Finally, I found out that the issue is related to the version I've chosen for bootloader/mcuboot.
    With source from repo 'https://github.com/nrfconnect/sdk-mcuboot', it can be built successfully.
    And my failure case is from repo 'github.com/.../mcuboot'
    Sorry for your time on helping me for the debugging.
