Want to know the speed of the nrf54 series device firmware update
We evaluated the BLE Mesh DFU performance on the nRF52840 and observed that transferring a 342 KB binary took approximately 36 minutes. This aligns closely with the documentation provided on Nordic’s website. We would like to confirm whether the DFU speed for the nRF54 Series remains around ~1 kbps, or if higher throughput can be expected.
  • Hi Nagarajan,
    The standard throughput over BLE from Mobile app can reach even 50k. I am verifying internally whether for mesh this throughput is significantly lower ?
    Priyanka
  • I tested a point-to-point connection between a smartphone and the nRF52840, and the transmission speed reached up to 11 kbps. Could you please verify and provide clarification on the transmission speeds for both the nRF52 and nRF54 DK boards? This information is very important for our evaluation.
  • Okay, I understand. Is there a way to issue all these commands from a smartphone instead of using shell commands?
    • Bluetooth Mesh prioritizes reliability and scalability over raw throughput. DFU is especially heavy because the firmware is split into many SAR segments that share the primary advertising channels with all other mesh traffic. You can take a look here.
    • Our samples send chunks back-to-back (no gap between chunks).
    • With default settings,
      I=60 ms (SEG_INT_STEP=0x05),
      3 network repeats (NS),
      ~25 ms effective repeat spacing (NI) (incl. controller randomization),
      3 multicast rounds (T) with 250 ms gaps
      → a 15-segment SAR message ≈ 3.08 s.
      since,
      Total time needed for complete transfer of one SAR message to multicast destination is:
      • R * (N - 1 ) * I (time for all rounds) + (R - 1) * T (gap between rounds) + LastT
      • = 3 (N - 1) * 60 + 500 + 58  = 180 * (N - 1) + 558 ms. For 15 segment message,
      • = 3078 ms
    • Of course there will be additonal minor delays due to processing of each segment
    • For DFU transfer let’s assume:
      • Block Size of 4KB (default)
      • Chunk Size of 15 segments
        • Thus, BLOB data size per Chunk Transfer message = 15 * 12 - 4 - 3 = 173 bytes
        • This gives 23.67 Chunks per block, we will assume 25 chunks per block (extra room will account of additional messages sent for starting the Block Transfer, some re-sending of lost chunk, and other setup).
    • What that means for a ~550 KB image is that,
      - Total Chunks within 550KB firmware = ((550 * 1024) / 4096) * 25 = 3437.5 = ~3436 Chunks (SAR messages)
      - total time needed for 550 KB firmware transfer = Total Chunks * Time for one SAR transfer (where each SAR message has 15 segments) = 3436 * 3078 ms = 10576 seconds = 2.94 hours.
      - It is important to note that total time required to finish DFU to hundreds of nodes will be marginally higher and not linearly higher. Meaning, if it takes 2 nodes to finish DFU in 2 hours, then for 200 nodes it will take, say, 2.5 hours (and not 400 hours). It is hard to compute this theoretically due to nature of the process which involves automatic retries for lost packets.
    • You can squeeze ~30% more speed by reducing repeats and spacing—at the cost of higher network load. Instead of the default, you can set:
      • CONFIG_BT_MESH_NETWORK_TRANSMIT_COUNT=1
      • CONFIG_BT_MESH_RELAY_RETRANSMIT_COUNT=1
      • CONFIG_BT_MESH_SAR_TX_SEG_INT_STEP=0x03
    • Also, DFU is supported in the nRF Mesh iOS app (recommended).
      If you really want to do that, then use Device Manager App and connect to the distributor node (make sure to pair the device first using nRF Mesh App) ... then switch to Device Manager App. That app has a freeform text box mode where customers can manually type those commands and they will be sent to the device. That is really cumbersome though. nRF Mesh iOS app does similar things in the background automatically using Mesh messages and users don't have to type much.
  • Thank you for the information — it closely matches my practical experiments. Could I also get the same timing calculations for Zigbee and Thread? This data is really important for us to evaluate and compare all three wireless technologies.
    Sure. I am checking with the teams and will update you shortly.
    -Priyanka
    In the case of Thread, there is no single unified way as to how DFU can be done. For example Matter defines it's own Matter OTA way, though customers may implement something proprietary on top of IPv6.
    In general the throughput on Thread highly depends on the used communication scheme e.g. UDP/TCP, strategy on confirmation and packet sizes, topology of the network etc.
    For basic usages we would say it could be between 8kB to 11kB per second.
    -Priyanka
    -Priyanka
