I’m trying to provision a P‑256 key pair into the KMU at runtime on an nRF54L15 (SDK v2.9.1) but psa_generate_key consistently returns PSA_ERROR_NOT_SUPPORTED, even when I fall back to local storage.
Environment
- SoC: nRF54L15 (DK)
- nRF Connect SDK: v2.9.1
What I’m doing
static int ensure_kmu_p256_key(void)
psa_status_t status = psa_crypto_init();
psa_key_id_t key_id = mbedtls_svc_key_id_make(
0,
PSA_KEY_HANDLE_FROM_CRACEN_KMU_SLOT(
CRACEN_KMU_KEY_USAGE_SCHEME_RAW, 200)); /* non-reserved slot */
psa_key_handle_t handle = PSA_KEY_ID_NULL;
status = psa_open_key(key_id, &handle);
/* ... if it exists, exit early ... */
psa_key_attributes_t attrs = PSA_KEY_ATTRIBUTES_INIT;
psa_set_key_type(&attrs, PSA_KEY_TYPE_ECC_KEY_PAIR(PSA_ECC_FAMILY_SECP_R1));
psa_set_key_bits(&attrs, 256);
psa_set_key_usage_flags(&attrs, PSA_KEY_USAGE_SIGN_HASH | PSA_KEY_USAGE_EXPORT);
psa_set_key_algorithm(&attrs, PSA_ALG_ECDSA(PSA_ALG_ANY_HASH));
const struct lifetime_option lifetimes[] = {
PSA_KEY_LIFETIME_FROM_PERSISTENCE_AND_LOCATION(
(psa_key_persistence_t)CRACEN_KEY_PERSISTENCE_REVOKABLE,
PSA_KEY_LOCATION_CRACEN_KMU),
"KMU"
PSA_KEY_PERSISTENCE_DEFAULT,
PSA_KEY_LOCATION_LOCAL_STORAGE),
"local storage"
for (...) {
psa_set_key_lifetime(&attrs, lifetimes[i].lifetime);
psa_set_key_id(&attrs,
lifetimes[i].lifetime == KMU lifetime ? key_id : PSA_KEY_ID_USER_MIN + 1);
status = psa_generate_key(&attrs, &key_id);
if (status == PSA_SUCCESS) {
LOG_INF("Generated P-256 key in %s", lifetimes[i].name);
return 0;
LOG_WRN("Key lifetime %s not supported", lifetimes[i].name);
LOG_ERR("P-256 key generation not supported by available PSA backends");
return -ENOTSUP;
Runtime output
<wrn> Key lifetime KMU not supported
<wrn> Key lifetime local storage not supported
<err> P-256 key generation not supported by available PSA backends
<err> Failed to ensure KMU key: -134
I’ve tried az bunch of things like
RAW and ENCRYPTED
Different slot indices
Falling back to local storage (PSA_KEY_LOCATION_LOCAL_STORAGE)
Nothing works, so Istart to think I'm missing something obvious:
Is runtime psa_generate_key() into KMU actually supported on nRF54L15 in NCS 2.9.1, or is external provisioning (e.g., west ncs-provision or psa_import_key) the only supported path today?
Thanks
