Cannot reset or erase nRF54L15 DK
Hi
I have two nRF54L15 DK boards (PCA10156).
Both are behaving the same way right now.
ONE: Using nRFConnect in VSCode, I cannot flash the device:
Flashing myproj to nRF54L15 DK
west flash -d c:\dev\myproj\build --domain myproj --dev-id 105776****
-- west flash: rebuilding
[0/5] Performing build step for 'myproj'
ninja: no work to do.
[4/5] cmd.exe /C "cd /D C:\dev\myproj\build\_sysbuild && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe -E true"
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: C:\dev\myproj\build\merged.hex
Error: One or more batch tasks failed:
 * 105776****: Timed out waiting for response from worker. (Generic)
FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path 'C:\dev\myproj\build\generated_nrfutil_batch.json' --serial-numb
er 105776****
 *  The terminal process terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
TWO: Trying to recover the device, times out:
PS C:\dev\myproj\build\myproj>
PS C:\dev\myproj\build\myproj> nrfutil self-upgrade
nrfutil is already the newest version (8.1.1)
PS C:\dev\myproj\build\myproj> nrfutil upgrade
nrfutil-device is already the newest version (2.14.0)
[00:00:00] ###### 100% [Upgrade packages] Upgrade packages
PS C:\dev\myproj\build\myproj> nrfutil device recover
x Failed to recover 1057705837, Timed out waiting for response from worker.
Error: One or more recover tasks failed:
 * 1057705837: Timed out waiting for response from worker. (Generic)
THREE: Using nRF Connect for Desktop - Programmer, and selecting Erase All:
22:18:00.270    Selecting device with the serial number 00105776****
22:18:14.582    Error: Failed with exit code 1. One or more device info tasks failed: * 105776****: Timed out waiting for response from worker. (Generic) Message: Operation device-info failed, Timed out waiting for response from worker.
22:18:14.582    Selected device with the serial number 00105776****
22:18:14.583    Using nrfutil device to communicate with target via JLink
22:18:16.894    Error: Failed with exit code 1. One or more device info tasks failed: * 105776****: Timed out waiting for response from worker. (Generic) Message: Operation device-info failed, Timed out waiting for response from worker.
22:18:17.556    Device connected with the serial number 00105776****
22:18:17.692    Reading readback protection status for Application core
22:18:17.693    Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Emulator error: Failed to open connection
22:18:17.714    Error: Failed with exit code 1. One or more batch tasks failed: * 105776****: Emulator error: Failed to open connection (Generic) Message: Batch task protection-get failed, Emulator error: Failed to open connection.
22:18:17.800    Reading readback protection status for Application core
22:18:17.800    Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Emulator error: Failed to open connection
22:18:17.807    Error: Failed with exit code 1. One or more batch tasks failed: * 105776****: Emulator error: Failed to open connection (Generic) Message: Batch task protection-get failed, Emulator error: Failed to open connection.
22:18:18.621    Getting serial port options from the persistent store for 00105776****.pc-nrfconnect-programmer
22:18:18.621    Device connected with the serial number 00105776****
FOUR: Using nRF Connect for Desktop - Programmer, and selecting Reset:
22:18:56.040    Error: Aborted before start executing nrfutil ["device","device-info","--serial-number","00105776****","--json","--log-output=stdout","--log-level","off"]
22:18:56.099    Error: Aborted before start executing nrfutil ["device","x-execute-batch","--serial-number","00105776****","--batch-json","{\"operations\":[{\"operationId\":\"0\",\"core\":\"NRFDL_DEVICE_CORE_APPLICATION\",\"operation\":{\"type\":\"protection-get\"}}]}","--json","--log-output=stdout","--log-level","off"]
22:19:05.174    Error: Failed with exit code 1. One or more device info tasks failed: * 105776****: Timed out waiting for response from worker. (Generic) Message: Operation device-info failed, Timed out waiting for response from worker.
22:19:05.174    Selected device with the serial number 00105776****
22:19:05.174    Using nrfutil device to communicate with target via JLink
22:19:08.159    Device connected with the serial number 00105776****
22:19:08.298    Reading readback protection status for Application core
22:19:08.299    Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Emulator error: Failed to open connection
22:19:08.322    Error: Failed with exit code 1. One or more batch tasks failed: * 105776****: Emulator error: Failed to open connection (Generic) Message: Batch task protection-get failed, Emulator error: Failed to open connection.
22:19:09.285    Getting serial port options from the persistent store for 00105776****.pc-nrfconnect-programmer
22:19:09.285    Device connected with the serial number 00105776****
History:
I think I tried to flash the DK with a project I was working on. It originally was for a different board file, so I created a build config for the nRF54L15DK, then removed a lot of the application code so that it would build. Then I flash ed the DK, and the device seemed to run  - I was able run a BLE scan and see it. I can only thin that there was something wrong with the application that messed things up.
Then the next time (I think), it wouldn’t flash - I think I was trying to run it in debug mode.
I am guessing I eventually tried the 2nd DK - which probably worked the first time, although I am guessing.
SO I then created a new project from the BLE Peripheral UART sample, for the nRF54L15DK.
All the build configs above were for SDK/Toolchain 2.9.2
Question: How can I recover these devices?
Thanks
