I am using NCS 3.0.2 on nRF52840. I have been using MCUBoot for a long time on my device, and it is working fine. Recently, I went through a requirement where I needed to match the flash structure with my other devices, which are running on the nRF52840 with the legacy nRF5 SDK.
In the legacy nRF5 SDK, if we see the flash sectors, the nRF bootloader is placed at the end of the flash, mostly at 0xF8000. However, in Zephyr, which uses MCUBoot, it is placed at 0x00 at the start of the flash sectors. I attempted to change the MCUBoot location using pm_static.yml, but when I flashed the code, the application failed to start. Most probably, the vector table did not find the updated MCUBoot address through the pm_static.yml, and hence it starts from 0x00; there is a bootloader.
So, my question is, is it really necessary to stick the MCUBoot at the start of the flash at 0x00? Is there any way to update this structure?.
I've gone through this ticket of devzone where it is mentioned that we can do it, and practically it's possible, but the suggested sample was on the old NCS. Did we update anything related to this in the newer NCS?
Hang with nRF5 SDK 17.1.0 Bootloader and nRF Connect SDK 2.1.0 application
Can someone explain this scenario?
Thank you
Ankit.
