BFAR Address: 0xb4; Zephyr Fatal Error 25
I am currently working on NUS sample code with one nRF5340 as central board and ISP2053 module as the Peripheral to send data with 264kbps. The peripheral is flashed with NUS+PMIC integrated code.
I have configured Peripheral's config file to the below settings:
APP Core:-
Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_GATT_DM=y
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
# This example requires more stack
# CONFIG_MAIN_STACK_SIZE=8192
# CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
# Config logger
CONFIG_LOG=y
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_PRINTK=y
CONFIG_ASSERT=y
CONFIG_USB_CDC_ACM=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF=y
# BT Transmission Buffer
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_ATT_TX_COUNT=10
CONFIG_BT_L2CAP_TX_MTU=498
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=4000000
CONFIG_BT_BUF_ACL_RX_COUNT=40
CONFIG_UART_00_NRF_HW_ASYNC=y
# nPM1300
CONFIG_GPIO=y
CONFIG_REGULATOR=y
CONFIG_SENSOR=y
CONFIG_I2C=y
CONFIG_LED=y
CONFIG_NRF_FUEL_GAUGE=y
CONFIG_REQUIRES_FLOAT_PRINTF=y
# Enable the nPM1300 charger
CONFIG_NPM1300_CHARGER=y
CONFIG_REGULATOR_NPM1300=y
# Input buttons
CONFIG_PM_DEVICE=y
CONFIG_INPUT=y
# Watchdog
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_LOG_LEVEL_INF=y
CONFIG_WATCHDOG_APPLICATION_TIMEOUT_SEC=5
CONFIG_REBOOT=y
Network Core:-
CONFIG_SERIAL=n
CONFIG_UART_CONSOLE=n
CONFIG_LOG=n
CONFIG_MBOX=y
CONFIG_IPC_SERVICE=y
CONFIG_BT=y
CONFIG_BT_HCI_RAW=y
CONFIG_BT_CTLR_ASSERT_HANDLER=y
#CONFIG_BT_MAX_CONN=16
# Enable and adjust the below value as necessary
# CONFIG_BT_BUF_EVT_RX_COUNT=16
# CONFIG_BT_BUF_EVT_RX_SIZE=255
# CONFIG_BT_BUF_ACL_RX_SIZE=255
# CONFIG_BT_BUF_ACL_TX_SIZE=251
# CONFIG_BT_BUF_CMD_TX_SIZE=255
CONFIG_BT_BUF_ACL_TX_SIZE=502
# CONFIG_BT_L2CAP_TX_MTU=247
# CONFIG_BT_BUF_ACL_TX_COUNT=40
# CONFIG_BT_BUF_ACL_RX_COUNT=40
CONFIG_BT_MAX_CONN=2
CONFIG_ASSERT=y
CONFIG_DEBUG_INFO=y
CONFIG_EXCEPTION_STACK_TRACE=y
CONFIG_IPC_RADIO_BT=y
CONFIG_IPC_RADIO_BT_HCI_IPC=y
CONFIG_WATCHDOG=y
I have observed that BLE stream stops in  between after connecting to the central and throws the following error in the RTT Viewer---->
00> [01:05:01.980,072] <err> os: ***** BUS FAULT *****
00> [01:05:01.980,072] <err> os: Precise data bus error
00> [01:05:01.980,072] <err> os: BFAR Address: 0xb4
00> [01:05:01.980,102] <err> os: r0/a1: 0x200044b8 r1/a2: 0x200079ac r2/a3: 0x00000000
00> [01:05:01.980,102] <err> os: r3/a4: 0x00009745 r12/ip: 0xe7b65e25 r14/lr: 0x00028d0d
00> [01:05:01.980,133] <err> os: xpsr: 0x81000018
00> [01:05:01.980,133] <err> os: Faulting instruction address (r15/pc): 0x00002e0a
00> [01:05:01.980,163] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
00> [01:05:01.980,194] <err> os: Fault during interrupt handling
00>
00> [01:05:01.980,224] <err> os: Current thread: 0x200025a8 (unknown)
00> [01:05:02.331,573] <err> os: Halting system
Any idea on why this happening? I am trying to figure the issue, but any guidance will be of great help.
Also my UART_BUF_SIZE=180.
Thanks and Regards
Pallavi
