I2C Read Register during GPIOTE callback
The application here is reading a Manchester stream on a GPIO. which comes from a MAX41473 radio IC.
Decoding is working fine using GPIOTE, timers & PPI to time & decode the data stream. But when I have detected the signature of a valid packet I need to read a I2C register on the MAX41473 in order to get the RSSI value from the radio with as little latency as possible - otherwise I could be reading the RSSI when the packet has finished. Getting the packet RSSI is a must-have for this application.
If I call i2c_reg_read_byte() during the GPIO callback it fails with a return code of 251. If for example I set a flag and call the same from main() it works.
Is this an IRQ priority issue, stack levels or something else?
Using nRF54L15, IO pin P1.05 and comms is on I2C30.
