I am trying to implement serial recovery via USB on NRF 5340. I have come across this page that I used as a guide:
I am either missing something or some of this page is wrong.
The second option it offers for network core recovery is documented as "Serial recovery for the network core in the one image pair mode, where sysbuild Kconfig option SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES is set to == 1." I think there is a problem with this.
SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES cannot be set (or at least I don't know how to) to 1 unless SB_CONFIG_MCUBOOT_MODE_SINGLE_APP is enabled. However, when SB_CONFIG_MCUBOOT_MODE_SINGLE_APP is enabled, and I apply the rest of the configuration described there, the update does not work. This seems to be because with SB_CONFIG_MCUBOOT_MODE_SINGLE_APP, NET_CORE_VIRTUAL_PRIMARY_SLOT is defined as -1, so the comparison in boot_serial_uploaded_hook() never recognizes the image as intended for the network core. As a consequence, with single slot, I can successfully upload the new network image, but it is never applied.
If SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES is set to 2 instead, then I also need to define the mcuboot_secondary_1 partition, something not mentioned on this page. In this setup, the upload is successful AND the new image is applied.
Is the documentation wrong or am I missing something? Ideally I would like to use a single slot configuration, but if it is not possible, then we'll work with what is.
