Matter Custom cluster Build error ValueError: Unhandled server cluster:
I am trying to Build a modified version of the Matter weather station with additional endpoints
I have created a custom Cluster and Custom Device type via Matter Cluster editor
I cant find specific guidance on this process
I have tried adding these using both
west zap-gui --clusters ./src/default_zap/scene_sequence.xml
and (am using -o so doesn't overwrite external/modules/lib/matter/src/app/zap-templates/zcl/zcl.json)
west zap-append -o ./src/default_zap/zcl-ammended.json ./src/default_zap/scene_sequence.xml
west zap-gui -j ./src/default_zap/zcl-ammended.json
Both seem to work (no errors)
then run
west zap-generate
have also tried
west zap-generate -j
but when i try to build i get
CMake Error at /home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/chip_data_model.cmake:56 (message):
  Failed to execute zap_cluster_list.py: Traceback (most recent call last):
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 113, in <module>
      main()
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 107, in main
      dump_zapfile_clusters(args.zap_file, args.cluster_implementation_data, args.external_clusters)
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 77, in dump_zapfile_clusters
      get_cluster_sources(server_clusters, SERVER_CLUSTERS, 'server'))
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 25, in get_cluster_sources
      raise ValueError("Unhandled %s cluster: %s"
  ValueError: Unhandled server cluster: scene_sequence (hint: add to
  src/app/zap_cluster_list.json)
  /home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/chip_data_model.cmake:106 (chip_configure_zap_file)
  /home/fireblade/test2/matter_weather_station/external/nrf/samples/matter/common/cmake/data_model.cmake:20 (chip_configure_data_model)
  CMakeLists.txt:48 (ncs_configure_data_model)
I think im missing something but not sure what,
I could manually alter  "src/app/zap_cluster_list.json" but that's in the external matter repo (external/modules/lib/matter/) so i'd rather avoid that if possible
could anyone point me to the correct sequence to do this or tell me the missing step(s)
thanks
    I tested adding your custom cluster and device in the Matter Template sample. I got some errors that it expected StopSequenceResponse instead of ViewSequeneResponse for ViewSequeneResponse::DecodableType in src/default_zap/zap-generated/clusters/SceneSequence/Commands.h, but I do not get the error about unhandled server cluster that you get.
    To add the cluster and run the ZAP tool I used this command:
    west zap-gui -j ./src/default_zap/zcl.json --clusters ./scene_sequence.xml
    I added the Signal Lights device on endpoint 1 and saved the zap file, then I generated the C++ files with the following:
    west zap-generate --full
    Lastly, I added this to CMakeLists.txt:
    project(matter-template)
    # Override zap-generated directory.
    include(${ZEPHYR_NRF_MODULE_DIR}/samples/matter/common/cmake/zap_helpers.cmake)
    ncs_get_zap_parent_dir(ZAP_PARENT_DIR)
    get_filename_component(CHIP_APP_ZAP_DIR ${ZAP_PARENT_DIR}/zap-generated REALPATH CACHE)
    # Existing code in CMakeList.txt
    ncs_configure_data_model(
       EXTERNAL_CLUSTERS "scene_sequence" # Add EXTERNAL_CLUSTERS flag
    # NORDIC SDK APP END
    I also noticed that the device shows up as "undefined" if I re-opened ZAP Tool. This was fixed by adding editable="false" to the deviceId in the XML file:
    <deviceId editable="false">0xfff100f1</deviceId>
    Marte
  • some tweaks and fixes to the cluster xml file and
    adding
    seems to fix that error and the "StopSequenceResponse instead of ViewSequeneResponse" error
    however this leads me to a different error
    CMake Error at /home/fireblade/race-start-signals/external/modules/lib/matter/src/app/chip_data_model.cmake:34 (include):
      include could not find requested file:
        /home/fireblade/race-start-signals/external/modules/lib/matter/src/app/clusters/timer-server/app_config_dependent_sources.cmake
      /home/fireblade/race-start-signals/external/modules/lib/matter/src/app/chip_data_model.cmake:62 (chip_configure_cluster)
      /home/fireblade/race-start-signals/external/modules/lib/matter/src/app/chip_data_model.cmake:106 (chip_configure_zap_file)
      /home/fireblade/race-start-signals/external/nrf/samples/matter/common/cmake/data_model.cmake:20 (chip_configure_data_model)
      CMakeLists.txt:40 (ncs_configure_data_model)
    after some examination it appears to originate fro the fact that the upstream repo is missing the timer cluster
    and if you get it into your .zap file its difficult to remove without recreating it, as just deselecting and saving in zap-gui doesn't seem to remove it
    e.g if you run
    or just
    and check timer cluster in any endpoint save
    you get the error
    and if uncheck and save again
    you still get the error as the cluster definitions are not removed from then zap file
    as i think this is a matter sdk error i have created an issue
    do you want this mentioned anywhere else?
    I was intending to use a timer, but think i can workaround that
  • ok
    after working through that im now getting
    numerous  multiple definition of ` errors
    e.g.
    /home/fireblade/ncs/toolchains/b2ecd2435d/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: modules/connectedhomeip/lib/libCHIP.a(libClusterObjects.cluster-objects.cpp.o): in function `chip::app::Clusters::PushAvStreamTransport::Commands::AllocatePushTransportResponse::Type::Encode(chip::app::DataModel::FabricAwareTLVWriter&, chip::TLV::Tag) const':
    /home/fireblade/test2/matter_weather_station2/application/src/default_zap/zap-generated/clusters/PushAvStreamTransport/Commands.ipp:72: multiple definition of `chip::app::Clusters::PushAvStreamTransport::Commands::AllocatePushTransportResponse::Type::Encode(chip::app::DataModel::FabricAwareTLVWriter&, chip::TLV::Tag) const'; modules/connectedhomeip/libmatter-data-model.a(cluster-objects.cpp.obj):/home/fireblade/test2/matter_weather_station2/application/src/default_zap/zap-generated/clusters/PushAvStreamTransport/Commands.ipp:72: first defined here
    /home/fireblade/ncs/toolchains/b2ecd2435d/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: modules/connectedhomeip/lib/libCHIP.a(libClusterObjects.cluster-objects.cpp.o): in function `chip::app::Clusters::PushAvStreamTransport::Commands::FindTransportResponse::Type::Encode(chip::app::DataModel::FabricAwareTLVWriter&, chip::TLV::Tag) const':
    /home/fireblade/test2/matter_weather_station2/application/src/default_zap/zap-generated/clusters/PushAvStreamTransport/Commands.ipp:268: multiple definition of `chip::app::Clusters::PushAvStreamTransport::Commands::FindTransportResponse::Type::Encode(chip::app::DataModel::FabricAwareTLVWriter&, chip::TLV::Tag) const'; modules/connectedhomeip/libmatter-data-model.a(cluster-objects.cpp.obj):/home/fireblade/test2/matter_weather_station2/application/src/default_zap/zap-generated/clusters/PushAvStreamTransport/Commands.ipp:268: first defined here
    for what looks like every cluster
    im guessing something is causing inclusion of duplicates
    appears to be in "/home/fireblade/test2/matter_weather_station2/application/build/application/modules/connectedhomeip/obj/ABS_PATH/home/fireblade/test2/matter_weather_station2/application/src/default_zap/zap-generated/app-common/zap-generated/"
    it seems   "/src/default_zap/zap-generated/app-common/zap-generated/cluster-objects.cpp"
    includes all the /src/default_zap/zap-generated/clusters/<clustername>*.ipp files
    ive tried this with the matter template as well and cant see why is doing this
    CMakeLists.txt is currently
    cmake_minimum_required(VERSION 3.20.0)
    list(APPEND BOARD_ROOT ${CMAKE_CURRENT_SOURCE_DIR})
    set(SHIELD fbas_race_start)
    find_package(Zephyr HINTS $ENV{ZEPHYR_BASE})
    project(race-start-signals)
    # Enable GNU STD support.
    include(${ZEPHYR_CONNECTEDHOMEIP_MODULE_DIR}/config/nrfconnect/app/enable-gnu-std.cmake)
    # NORDIC SDK APP START
    # Include all source files that are located in the Matter common directory.
    include(${ZEPHYR_NRF_MODULE_DIR}/samples/matter/common/cmake/source_common.cmake)
    # Include Data Model utils
    include(${ZEPHYR_NRF_MODULE_DIR}/samples/matter/common/cmake/data_model.cmake)
    target_include_directories(app PRIVATE
        src
        ${ZAP_PARENT_DIR}
    target_sources(app PRIVATE
        src/app_task.cpp
        src/main.cpp
    #    src/battery.cpp
    #    src/buzzer.cpp
        src/zcl_callbacks.cpp
    Can you share a project where this can be reproduced?
    Marte
  • 3583.application.zip
    have attached zip of application from west workspace
    is basically copy of matter template modified for thingy53 with a simple shield
    and added custom cluster.
    thx
