Matter Custom cluster Build error ValueError: Unhandled server cluster:
I am trying to Build a modified version of the Matter weather station with additional endpoints
I have created a custom Cluster and Custom Device type via Matter Cluster editor
I cant find specific guidance on this process
I have tried adding these using both
west zap-gui --clusters ./src/default_zap/scene_sequence.xml
and (am using -o so doesn't overwrite external/modules/lib/matter/src/app/zap-templates/zcl/zcl.json)
west zap-append -o ./src/default_zap/zcl-ammended.json ./src/default_zap/scene_sequence.xml
west zap-gui -j ./src/default_zap/zcl-ammended.json
Both seem to work (no errors)
then run
west zap-generate
have also tried
west zap-generate -j
but when i try to build i get
CMake Error at /home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/chip_data_model.cmake:56 (message):
  Failed to execute zap_cluster_list.py: Traceback (most recent call last):
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 113, in <module>
      main()
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 107, in main
      dump_zapfile_clusters(args.zap_file, args.cluster_implementation_data, args.external_clusters)
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 77, in dump_zapfile_clusters
      get_cluster_sources(server_clusters, SERVER_CLUSTERS, 'server'))
    File "/home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/zap_cluster_list.py", line 25, in get_cluster_sources
      raise ValueError("Unhandled %s cluster: %s"
  ValueError: Unhandled server cluster: scene_sequence (hint: add to
  src/app/zap_cluster_list.json)
  /home/fireblade/test2/matter_weather_station/external/modules/lib/matter/src/app/chip_data_model.cmake:106 (chip_configure_zap_file)
  /home/fireblade/test2/matter_weather_station/external/nrf/samples/matter/common/cmake/data_model.cmake:20 (chip_configure_data_model)
  CMakeLists.txt:48 (ncs_configure_data_model)
I think im missing something but not sure what,
I could manually alter  "src/app/zap_cluster_list.json" but that's in the external matter repo (external/modules/lib/matter/) so i'd rather avoid that if possible
could anyone point me to the correct sequence to do this or tell me the missing step(s)
thanks
    Do you get an error if you generate the files using --full?
    west zap-generate --full
    We have a guide for creating and adding a custom cluster to your application: Creating manufacturer-specific clusters in Matter application.
    Marte
  • hello
    ive tried with
    and get
    Files generated in: /home/fireblade/test2/matter_weather_station/application/src/default_zap/zap-generated
    Error: /home/fireblade/test2/matter_weather_station/external/modules/lib/matter/True does not exists or is not a file.
    FATAL ERROR: command exited with status 1: ./scripts/tools/zap/generate.py -z True -t src/app/common/templates/templates.json -o /home/fireblade/test2/matter_weather_station/application/src/default_zap/zap-generated/app-common/zap-generated
  • Ok after renaming the ./src/default_zap/zcl-ammended.json to ./src/default_zap/zcl.json
    now works
    but im still getting
    on build
    Can you share your XML file with the custom cluster and device type so I can test it on my end? If you do not want to share the file in a public ticket, let me know and I can make the ticket private.
    Marte
  • hello
    here is cluster file
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <configurator>
      <struct name="SequenceSceneStruct" isFabricScoped="true">
        <cluster code="0xff1fc00"/>
        <item fieldId="0" name="SceneID" type="int8u" default="0"/>
        <item fieldId="1" name="TimeOffset" type="int32u" isFabricSensitive="true"/>
      </struct>
      <struct name="SequenceInfoStuct" isFabricScoped="true">
        <item fieldId="0" name="SequenceCount" type="int16u" default="0"/>
        <item fieldId="1" name="CurrentSequence" type="int16u" isFabricSensitive="true"/>
        <item fieldId="2" name="RemainingCapacity" type="int16u" isFabricSensitive="true"/>
      </struct>
      <domain name="CHIP"/>
      <cluster>
        <domain>General</domain>
        <name>Scene Sequence</name>
        <code>0xff1fc00</code>
        <define>scene_sequence</define>
        <attribute name="Sequence table size" side="server" code="0x1" define="SEQUENCE_TABLE_SIZE" type="int16u" default="16" apiMaturity="provisional">
          <description>Sequence table size</description>
          Sequence table size
        </attribute>
        <attribute name="FabricSequenceInfo" side="server" code="0x0000" define="FABRIC_SEQUENCE_INFO" type="SequenceInfoStuct" apiMaturity="provisional">
          <description>FabricSequenceInfo</description>
          FabricSequenceInfo
        </attribute>
        <command name="AddSequence" code="0xfff10000" source="client" response="AddSequenceResponse">
          <description/>
          <arg name="GroupID" type="group_id"/>
          <arg name="SequenceID" type="int16u"/>
          <arg name="SequenceName" type="char_string"/>
          <arg name="SceneSequence" type="SequenceSceneStruct" array="true" />
          <access op="invoke" role="manage"/>
        </command>
        <command name="RemoveSequence" code="0xfff10003" source="client" response="RemoveSequenceResponse">
          <description/>
        </command>
        <command name="PlaySequence" code="0xfff10002" source="client" response="PlaySequenceResponse">
          <description/>
        </command>
        <command name="StopSequence" code="0xfff10004" source="client" response="StopSequenceResponse">
          <description/>
        </command>
        <command name="ViewSequene" code="0xfff10005" source="client" response="ViewSequeneResponse">
          <description/>
        </command>
        <command name="AddSequenceResponse" code="0xfff10000" source="server">
          <description/>
          <arg name="Status" type="status"/>
        </command>
        <command name="RemoveSequenceResponse" code="0xfff10003" source="server">
          <description/>
        </command>
        <command name="PlaySequenceResponse" code="0xfff10002" source="server">
          <description/>
        </command>
        <command name="StopSequenceResponse" code="0xfff10004" source="server">
          <description/>
        </command>
      </cluster>
      <deviceType>
        <name>signal-lights</name>
        <domain>Lighting</domain>
        <typeName>Signal Lights</typeName>
        <profileId>0x104</profileId>
        <deviceId>0xfff100f1</deviceId>
        <clusters lockOthers="false">
          <include cluster="Scene Sequence" server="true"/>
          <include cluster="Scenes Management" client="true"/>
        </clusters>
      </deviceType>
    </configurator>
    is basically facility to allow a device to switch between a set of scenes over a period of time without interaction with a controller
    I'm not yet that familiar with matter, so only a rough outline to test what is required.
    is create using a combination of matter cluster editor 0.1 and a few manual edits, due to bugs/missing features in the editor
    I'm building on top of  matter weather station as have that correctly building with additional drivers for i2c GPIO expanders (mcp23017 and pca9538) and shells
