ota
 Hi,Team,
I am currently using the nrf5415 to develop OTA. My NCS version is v3.0.2.
Now I have two types of devices: Hub and Terminal. Both of these devices use nrf54l15. Our OTA design scheme is:
Hub ota: Enables the mcuboot function, establishes BLE connection with our custom app, and performs firmware update. For the custom app, we will refer to the Nordic's NRF Connect tool. Now I can use the nrf connect tool to update the firmware of the hub.
Terminal OTA: Usually, the Hub and the terminal communicate via BLE power. When performing a firmware update for the terminal, the terminal and the Hub establish a BLE connection. After the Hub enables the mcuboot function, it has mcuboot_primary and mcuboot_secondary. Then I create a.yml file and add mcuboot_third in the Hub. mcuboot_third is used to store the terminal's firmware. Then the Hub reads the terminal's code from the flash and sends it to the terminal via GATT. The terminal also enables the mcuboot function. The terminal receives the firmware via GATT and manually saves mcuboot_secondary and manually updates the firmware status to perform the firmware update.
Now I have a few questions:
Question 1.
 I used the nrf connect firmware to download to the mcuboot_third area in the Hub, but the nrf connect tool reported an error.
This is a custom.yml file.
app:
  address: 0x14800
  end_address: 0x177000
  region: flash_primary
external_flash:
  address: 0x2C6000
  end_address: 0x7FF000
  region: external_flash
external_flash_update_flag:
  address: 0x7FF000
  end_address: 0x800000
littlefs_storage:
  address: 0x177000
  end_address: 0x17d000
  placement:
    before:
    - end
mcuboot:
  address: 0x0
  end_address: 0x14000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x14000
  end_address: 0x14800
  placement:
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x14000
  orig_span: &id001
  - app
  - mcuboot_pad
  span: *id001
mcuboot_primary_app:
  address: 0x14800
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0x163000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
mcuboot_third:
  address: 0x163000
  end_address: 0x2C6000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
otp:
  address: 0xffd500
  end_address: 0xffd9fc
  region: otp
sram_primary:
  address: 0x20000000
  end_address: 0x2002f000
  region: sram_primary
I made some changes to flash_map_pm.h and zephyr_img_mgmt.c.
flash_map_pm.h:
zephyr_img_mgmt.c:
#define SLOT0_PARTITION		slot0_partition
#define SLOT1_PARTITION		slot1_partition
#define SLOT1_1_PARTITION	slot1_1_partition
#define SLOT2_PARTITION		slot2_partition
#define SLOT3_PARTITION		slot3_partition
#define SLOT4_PARTITION		slot4_partition
#define SLOT5_PARTITION		slot5_partition
img_mgmt_flash_area_id(int slot)
	uint8_t fa_id;
	const struct flash_area *fap;
	switch (slot) {
	case 0:
		fa_id = FIXED_PARTITION_ID(SLOT0_PARTITION);
	case 1:
		//fa_id = FIXED_PARTITION_ID(SLOT1_PARTITION);
	uint8_t UpdateFlag[4];
    printk("\n img_mgmt_flash_area_id UpdateFlag data :");
    flash_area_open(9, &fap);
    flash_area_read(fap,0,UpdateFlag,4);
    for(int i=0;i<4;i++)
        printk("%02x ",UpdateFlag[i]);
    flash_area_close(fap);
    printk("\n");
    if(UpdateFlag[0] == 0x55 && UpdateFlag[1] == 0xaa && UpdateFlag[2] == 0x55 && UpdateFlag[3] == 0x11)
        printk("\n update firmware on slot1 \n");
    else{
		fa_id = FIXED_PARTITION_ID(SLOT1_1_PARTITION);
        printk("\n update firmware on slot2 \n");
#if FIXED_PARTITION_EXISTS(SLOT2_PARTITION)
	case 2:
		fa_id = FIXED_PARTITION_ID(SLOT2_PARTITION);
#if FIXED_PARTITION_EXISTS(SLOT3_PARTITION)
	case 3:
		fa_id = FIXED_PARTITION_ID(SLOT3_PARTITION);
#if FIXED_PARTITION_EXISTS(SLOT4_PARTITION)
	case 4:
		fa_id = FIXED_PARTITION_ID(SLOT4_PARTITION);
#if FIXED_PARTITION_EXISTS(SLOT5_PARTITION)
	case 5:
		fa_id = FIXED_PARTITION_ID(SLOT5_PARTITION);
		fa_id = -1;
	return fa_id;
Question 2:
Is the terminal's OTA solution feasible? Currently, the only way to perform firmware OTA for Aura is through the Hub. If not, how should I update the firmware for the terminal?
Thanks.
  • dede said:
    How can the hub set secondary slot 1 and secondary slot 2 outside the flash?
    The hub doesn't per say "set this", but I'm guessing that you're asking about how to write the candidate image from the hub to the secondary slot of the remote device?
    Let's break it down once more.
    In your OTA hub you want to be able to do two things (w.r.t DFU): Update it's own firmare and update remote devices. This means that you either have to
    1. Create a flag that separates if the candidate image in hub_mcuboot_secondary is for the hub or for the remote device (proprietary). If it's for the hub, then do DFU as normal and if it's for the remote then proceed with the routine you make for instance as described below
    2. Have a storage partition for the remote device(s) and mcuboot_secondary is for only the candidate image to the hub.
    After you've uploaded the image to the hub, the next thing you need to do is to connect to the remote. From there, you transfer the image using MCUMGRs img_mgnt to specify what to send to the remote. Depending on the solution above you need to take the contents of the candidate image slot in your hub and write to mcuboot_secondary on the remote. This is described in https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/samples/cellular/lwm2m_client/fota_external_mcu.html
    I'm sorry but we really don't have any implementations other than the lwm2m that shows how to update a remote device.
    Andreas
    Thank you for your reply.
    Your analysis is correct.
    I have created a flag. If the flag is 0x55AA5511, it means to update the hub because the firmware of the hub is defaultly downloaded to mcuboot_secondary. So I can easily implement the firmware update of the hub. If the flag is 0x55AA5522, it means to download the terminal firmware. But the problem is that I don't know how to download the firmware to mcuboot_third.
    Do you know how to solve this problem?
    Reference for the overwrite file is as follows:
    app:
      address: 0x14800
    external_flash:
      address: 0x2C6000
      address: 0x7FF000
    littlefs_storage:
      address: 0x177000
      placement:
        before:
        - end
    mcuboot:
      address: 0x0
      placement:
        align:
          end: 0x1000
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x14000
      placement:
        before:
    mcuboot_primary:
      address: 0x14000
      orig_span: &id001
      - app
      - mcuboot_pad
      span: *id001
      address: 0x14800
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x0
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
    mcuboot_third:
      address: 0x163000
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
    otp:
      address: 0xffd500
      region: otp
    sram_primary:
      address: 0x20000000
    Thanks.
    The short answer is unfortunately no, I don't know this.
    I did some more digging and found this unofficial sample that a colleague of mine made for NCS 2.4.0 https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/v2.6.0/bootloader_samples/client_smp/smp_client_ble. The implementation is hacky and you will have to do some patching, but hopefully it might be good enough to show case how to transfer data to a remote device. There's an issue if you attempt to transfer the candidate image in chunks to the remote if you call the transfer within an ISR. This sample shows how to do it in a workqueue.
    It doesn't use sysbuild so this porting needs to be done as well.
    I might have another sysbuild version that showcases how to do this in a thread context, but lets focus on the other one for now..
    Andreas
    Because the terminal cannot establish a connection with the app to perform OTA (Over-The-Air Update), it can only communicate with the hub. I have now successfully implemented app splitting, and I have written the terminal's firmware into the mcuboot third area of the hub. So, is there such a custom Ota method? My idea is that the hub sends the firmware data of the mcuboot third version to the aura, the aura stores it in the mcuboot secondary, and then the terminal makes its own judgment based on certain conditions and performs the firmware upgrade. If possible, how can I add the judgment conditions?
    Thanks.
  • Hi,team,
    I haven't solved this problem yet. Who can help me?
    Thanks.
