ota
 Hi,Team,
I am currently using the nrf5415 to develop OTA. My NCS version is v3.0.2.
Now I have two types of devices: Hub and Terminal. Both of these devices use nrf54l15. Our OTA design scheme is:
Hub ota: Enables the mcuboot function, establishes BLE connection with our custom app, and performs firmware update. For the custom app, we will refer to the Nordic's NRF Connect tool. Now I can use the nrf connect tool to update the firmware of the hub.
Terminal OTA: Usually, the Hub and the terminal communicate via BLE power. When performing a firmware update for the terminal, the terminal and the Hub establish a BLE connection. After the Hub enables the mcuboot function, it has mcuboot_primary and mcuboot_secondary. Then I create a.yml file and add mcuboot_third in the Hub. mcuboot_third is used to store the terminal's firmware. Then the Hub reads the terminal's code from the flash and sends it to the terminal via GATT. The terminal also enables the mcuboot function. The terminal receives the firmware via GATT and manually saves mcuboot_secondary and manually updates the firmware status to perform the firmware update.
Now I have a few questions:
Question 1.
 I used the nrf connect firmware to download to the mcuboot_third area in the Hub, but the nrf connect tool reported an error.
This is a custom.yml file.
app:
  address: 0x14800
  end_address: 0x177000
  region: flash_primary
external_flash:
  address: 0x2C6000
  end_address: 0x7FF000
  region: external_flash
external_flash_update_flag:
  address: 0x7FF000
  end_address: 0x800000
littlefs_storage:
  address: 0x177000
  end_address: 0x17d000
  placement:
    before:
    - end
mcuboot:
  address: 0x0
  end_address: 0x14000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x14000
  end_address: 0x14800
  placement:
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x14000
  orig_span: &id001
  - app
  - mcuboot_pad
  span: *id001
mcuboot_primary_app:
  address: 0x14800
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0x163000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
mcuboot_third:
  address: 0x163000
  end_address: 0x2C6000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
otp:
  address: 0xffd500
  end_address: 0xffd9fc
  region: otp
sram_primary:
  address: 0x20000000
  end_address: 0x2002f000
  region: sram_primary
I made some changes to flash_map_pm.h and zephyr_img_mgmt.c.
flash_map_pm.h:
zephyr_img_mgmt.c:
#define SLOT0_PARTITION		slot0_partition
#define SLOT1_PARTITION		slot1_partition
#define SLOT1_1_PARTITION	slot1_1_partition
#define SLOT2_PARTITION		slot2_partition
#define SLOT3_PARTITION		slot3_partition
#define SLOT4_PARTITION		slot4_partition
#define SLOT5_PARTITION		slot5_partition
img_mgmt_flash_area_id(int slot)
	uint8_t fa_id;
	const struct flash_area *fap;
	switch (slot) {
	case 0:
		fa_id = FIXED_PARTITION_ID(SLOT0_PARTITION);
	case 1:
		//fa_id = FIXED_PARTITION_ID(SLOT1_PARTITION);
	uint8_t UpdateFlag[4];
    printk("\n img_mgmt_flash_area_id UpdateFlag data :");
    flash_area_open(9, &fap);
    flash_area_read(fap,0,UpdateFlag,4);
    for(int i=0;i<4;i++)
        printk("%02x ",UpdateFlag[i]);
    flash_area_close(fap);
    printk("\n");
    if(UpdateFlag[0] == 0x55 && UpdateFlag[1] == 0xaa && UpdateFlag[2] == 0x55 && UpdateFlag[3] == 0x11)
        printk("\n update firmware on slot1 \n");
    else{
		fa_id = FIXED_PARTITION_ID(SLOT1_1_PARTITION);
        printk("\n update firmware on slot2 \n");
#if FIXED_PARTITION_EXISTS(SLOT2_PARTITION)
	case 2:
		fa_id = FIXED_PARTITION_ID(SLOT2_PARTITION);
#if FIXED_PARTITION_EXISTS(SLOT3_PARTITION)
	case 3:
		fa_id = FIXED_PARTITION_ID(SLOT3_PARTITION);
#if FIXED_PARTITION_EXISTS(SLOT4_PARTITION)
	case 4:
		fa_id = FIXED_PARTITION_ID(SLOT4_PARTITION);
#if FIXED_PARTITION_EXISTS(SLOT5_PARTITION)
	case 5:
		fa_id = FIXED_PARTITION_ID(SLOT5_PARTITION);
		fa_id = -1;
	return fa_id;
Question 2:
Is the terminal's OTA solution feasible? Currently, the only way to perform firmware OTA for Aura is through the Hub. If not, how should I update the firmware for the terminal?
Thanks.
