DFU extended error 0x07
I am trying to update an nRF52 through the DFU protocol from an esb firmware without softdevice to a bluetooth firmware with softdevice included.
I am updating the device through a UART interface, using a custom implementation of the DFU protocol complying with DFU protocol (in which PRN is set to 0). I have tested my implementation with softdevice-less esb to softdevice-less esb updates and they work fine.
To create the update package, I run nrfutil v8.0.0, with the following command:
nrfutil pkg generate
--key-file mycert.pem
--hw-version 52
--softdevice sd.hex
--sd-req 0x00,0x0100
--sd-id 0x0100
--application-version-string APP_VERSION
--application app.hex
update.zip
After sending the softdevice .dat file in the "init packet" phase I receive an extended error (0x0B) with a payload of 0x07, which, according to nordic documentation is a SD version error. This happens in response to the execute request (0x04). If I immediately send another execute after the failure I get an error 0x05
If I run nrfutil pkg display on the genarated zip I get the following output:
DFU Package: <update.zip>:
|- Image count: 2
|- Image #0:
|- Type: softdevice
|- Image file: s140_nrf52_7.2.0_softdevice.bin
|- Init packet file: s140_nrf52_7.2.0_softdevice.dat
|- op_code: INIT
|- signature_type: ECDSA_P256_SHA256
|- signature (little-endian): b'SIGNATURE'
|- fw_version: 0xFFFFFFFF (4294967295)
|- hw_version 0x00000034 (52)
|- sd_req: 0x00, 0x100
|- type: SOFTDEVICE
|- sd_size: 153140
|- bl_size: 0
|- app_size: 0
|- hash_type: SHA256
|- hash (little-endian): b'HASH'
|- boot_validation_type: ['VALIDATE_GENERATED_CRC']
|- boot_validation_signature (little-endian): [b'']
|- is_debug: False
|- Image #1:
|- Type: application
|- Image file: radio_ble.bin
|- Init packet file: radio_ble.dat
|- op_code: INIT
|- fw_version: 0x00000322 (802)
|- sd_req: 0x100
|- type: APPLICATION
|- sd_size: 0
|- bl_size: 0
|- app_size: 80356
|- hash_type: SHA256
|- is_debug: False
I have tried setting both NRF_DFU_SINGLE_BANK_APP_UPDATES=0 and NRF_DFU_SINGLE_BANK_APP_UPDATES=1, and I have NRF_DFU_APP_DOWNGRADE_PREVENTION=0
  • Hi MaxMik,
    Are you working on existing products already deployed to the field, or a new project?
    I need more information about the existing setup before DFU.
    • Is MBR programmed?
    • What kind of bootloader is there?
    • What exactly is custom about the DFU implementation? Are the new images downloaded by the application instead?
    Hieu
  • I am working on an nRF52 840.
    The DFU implementation is custom in the host implementation only, while on the nRF52 side I use the default implementation.
    MBR is programmed and I use the secure bootloader available in the examples provided in the nRF SDK from nrf sdk.
    Since you mentioned the MBR, this is how I generate the hex files for pkg generate. Maybe its helpful.
    For the esb application:
    mergehex -m mbr_nrf52_2.4.1_mbr.hex bootloader.hex bootloader_settings.hex application.hex -o app.hex
    For the ble application:
    mergehex -m s140_nrf52_7.2.0_softdevice.hex bootloader.hex bootloader_settings.hex application.hex -o app.hex
  • Can you reattempt this with the debug version of the Secure Bootloader, and send me the bootloader log?
  • After re-attempting this with the debug version of the bootloader I am able to upload the softdevice, but not the application. Even if I switch back to the release version of the bootloader, I get the same behaviour.
    However, the error I get after sending the execute for the application init packet, is the same (0x0B 0x07).
    To upload the application, I reset the nRF in DFU after receiving a successful execute reply for the softdevice upload, and then I start uploading the application with the same exact process used for the softdevice (init packet for DAT file and then sending FW chunks from BIN file). Is that incorrect?
    These are the logs of the bootloader when I encounter the failure (they are quite long since I include the whole procedure starting from the upload of the softdevice):
    <debug> app: DFU mode requested via pin-reset.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> app: Enter main loop
    <debug> nrf_dfu_serial: Received ping 1
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    <debug> nrf_dfu_serial: Set receipt notif target: 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
    <debug> nrf_dfu_serial: Received serial mtu
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    <debug> nrf_dfu_serial: Sending Response: [0x7, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 69
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating hash (len: 69)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <debug> app: Enter nrf_dfu_cache_prepare()
    <debug> app: required_size: 0x25634.
    <debug> app: single_bank: false.
    <debug> app: keep_app: false.
    <debug> app: keep_softdevice: false.
    <debug> app: SD_PRESENT: false.
    <debug> app: Bank contents:
    <debug> app: Bank 0 code: 0x01: Size: 0xE160
    <debug> app: Bank 1 code: 0x00: Size: 0x0
    <debug> app: pass: 0.
    <debug> app: cache_address: 0x10000.
    <debug> app: cache_too_small: false.
    <debug> app: keep_firmware: false.
    <debug> app: delete_more: false.
    <debug> nrf_dfu_validation: Write address set to 0x00010000
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20001598, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x20001218, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00010000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00010000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000100C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000100C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000101C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000101C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000102C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000102C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000103C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000103C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000104C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000104C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000105C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000105C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000106C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000106C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000107C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000107C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000108C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000108C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000109C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000109C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00010FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00010FC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:4096, CRC:0x36E4BF70
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00011000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00011000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00001000, CRC: 0x36E4BF70
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000110C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000110C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000111C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000111C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000112C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000112C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000113C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000113C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000114C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000114C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000115C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000115C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000116C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000116C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000117C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000117C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000118C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000118C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000119C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000119C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00011FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00011FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:8192, CRC:0x57D22D0B
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00012000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00012000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00002000, CRC: 0x57D22D0B
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000120C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000120C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000121C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000121C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000122C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000122C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000123C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000123C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000124C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000124C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000125C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000125C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000126C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000126C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000127C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000127C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000128C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000128C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000129C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000129C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00012FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00012FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:12288, CRC:0x48168B32
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00013000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00013000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00003000, CRC: 0x48168B32
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000130C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000130C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000131C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000131C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000132C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000132C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000133C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000133C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000134C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000134C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000135C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000135C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000136C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000136C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000137C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000137C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000138C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000138C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000139C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000139C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00013FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00013FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:16384, CRC:0x7EE2A1D6
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00014000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00014000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00004000, CRC: 0x7EE2A1D6
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000140C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000140C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000141C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000141C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000142C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000142C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000143C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000143C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000144C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000144C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000145C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000145C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000146C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000146C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000147C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000147C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000148C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000148C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000149C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000149C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014E40, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014E80, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014F80, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00014FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00014FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:20480, CRC:0x5B4F1902
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00015000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00015000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00005000, CRC: 0x5B4F1902
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000150C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000150C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000151C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000151C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015200, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000152C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000152C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000153C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000153C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000154C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000154C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000155C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000155C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000156C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000156C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000157C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000157C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000158C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000158C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000159C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000159C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00015FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00015FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:24576, CRC:0x5C072F52
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00016000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00016000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00006000, CRC: 0x5C072F52
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000160C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000160C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000161C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000161C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000162C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000162C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000163C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000163C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000164C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000164C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000165C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000165C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000166C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000166C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000167C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000167C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000168C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000168C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000169C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000169C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00016FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00016FC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:28672, CRC:0x28FBC268
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00017000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00017000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00007000, CRC: 0x28FBC268
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000170C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000170C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000171C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000171C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000172C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000172C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000173C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000173C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000174C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000174C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000175C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000175C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000176C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000176C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000177C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000177C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000178C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000178C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000179C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000179C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00017FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00017FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:32768, CRC:0x48F94489
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00018000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00018000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00008000, CRC: 0x48F94489
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000180C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000180C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000181C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000181C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000182C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000182C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000183C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000183C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000184C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000184C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000185C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000185C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000186C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000186C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000187C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000187C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000188C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000188C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000189C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000189C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00018FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00018FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:36864, CRC:0xB193867D
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00019000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00019000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00009000, CRC: 0xB193867D
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000190C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000190C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000191C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000191C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000192C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000192C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000193C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000193C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000194C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000194C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000195C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000195C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000196C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000196C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000197C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000197C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000198C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000198C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000199C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000199C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00019FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00019FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:40960, CRC:0xD44ADD6E
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001A000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0001A000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000A000, CRC: 0xD44ADD6E
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A040, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A180, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A480, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001A9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001A9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ABC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ABC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ACC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ACC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ADC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ADC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001AFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001AFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:45056, CRC:0xAAD6CC7E
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001B000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0001B000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000B000, CRC: 0xAAD6CC7E
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001B9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001B9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001BFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001BFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:49152, CRC:0xF7BA5C1E
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001C000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0001C000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000C000, CRC: 0xF7BA5C1E
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001C9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001C9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001CFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001CFC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:53248, CRC:0xD0489370
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001D000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0001D000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000D000, CRC: 0xD0489370
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001D9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001D9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001DFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001DFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:57344, CRC:0xBFEF5A06
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001E000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0001E000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000E000, CRC: 0xBFEF5A06
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001E9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001E9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ECC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ECC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ED00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ED00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ED40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ED40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001ED80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001ED80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001EFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001EFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:61440, CRC:0x42C4B22E
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0001F000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0001F000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0000F000, CRC: 0x42C4B22E
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F280, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F2C0, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F400, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F6C0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001F9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001F9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0001FFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0001FFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:65536, CRC:0x20D76932
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00020000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00020000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00010000, CRC: 0x20D76932
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000200C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000200C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000201C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000201C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000202C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000202C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000203C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000203C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000204C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000204C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000205C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000205C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000206C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000206C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000207C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000207C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000208C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000208C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000209C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000209C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00020FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00020FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:69632, CRC:0xF0912255
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00021000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00021000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00011000, CRC: 0xF0912255
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000210C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000210C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000211C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000211C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000212C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000212C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000213C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000213C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000214C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000214C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000215C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000215C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000216C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000216C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000217C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000217C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000218C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000218C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000219C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000219C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00021FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00021FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:73728, CRC:0xED887AB8
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00022000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00022000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00012000, CRC: 0xED887AB8
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000220C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000220C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000221C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000221C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000222C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000222C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000223C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000223C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000224C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000224C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000225C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000225C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000226C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000226C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000227C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000227C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000228C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000228C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000229C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000229C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00022FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00022FC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:77824, CRC:0x677CD790
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00023000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00023000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00013000, CRC: 0x677CD790
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000230C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000230C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000231C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000231C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000232C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000232C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000233C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000233C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000234C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000234C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000235C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000235C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000236C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000236C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000237C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000237C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000238C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000238C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000239C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000239C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00023FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00023FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:81920, CRC:0x34242461
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00024000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00024000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00014000, CRC: 0x34242461
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000240C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000240C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000241C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000241C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000242C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000242C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000243C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000243C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000244C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000244C0, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024540, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000245C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000245C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024680, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000246C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000246C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000247C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000247C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000248C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000248C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024900, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000249C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000249C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00024FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00024FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:86016, CRC:0x11E928F0
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00025000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00025000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00015000, CRC: 0x11E928F0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000250C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000250C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000251C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000251C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000252C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000252C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000253C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000253C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000254C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000254C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000255C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000255C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000256C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000256C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000257C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000257C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000258C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000258C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000259C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000259C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00025FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00025FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:90112, CRC:0x250B336E
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00016000, CRC: 0x250B336E
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000260C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000261C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000262C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000263C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000264C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000265C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000266C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000267C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000268C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000268C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000269C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000269C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:94208, CRC:0xE927E187
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00027000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00027000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00017000, CRC: 0xE927E187
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000270C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000270C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000271C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000271C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000272C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000272C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000273C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000273C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000274C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000274C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000275C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000275C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000276C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000276C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000277C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000277C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000278C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000278C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000279C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000279C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00027FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:98304, CRC:0x7AE36DCA
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00028000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00028000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00018000, CRC: 0x7AE36DCA
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000280C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000280C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000281C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000281C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000282C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000282C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000283C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000283C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000284C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000284C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000285C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000285C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000286C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000286C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000287C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000287C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000288C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000288C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000289C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000289C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00028FC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:102400, CRC:0x0302EAD0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00029000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00029000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00019000, CRC: 0x0302EAD0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000290C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000290C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000291C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000291C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000292C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000292C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000293C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000293C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000294C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000294C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000295C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000295C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000296C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000296C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029700, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000297C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000297C0, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000298C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000298C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029900, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000299C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000299C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029B40, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00029FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:106496, CRC:0xC771B12A
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002A000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002A000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0001A000, CRC: 0xC771B12A
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ABC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ABC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ACC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ACC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ADC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ADC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:110592, CRC:0x27C93A47
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002B000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002B000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0001B000, CRC: 0x27C93A47
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:114688, CRC:0x952AA505
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002C000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002C000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0001C000, CRC: 0x952AA505
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:118784, CRC:0x9E204DAB
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002D000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002D000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0001D000, CRC: 0x9E204DAB
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:122880, CRC:0x91D46BCF
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0001E000, CRC: 0x91D46BCF
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E940, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EA40, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EB80, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ECC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ECC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ED00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ED00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ED40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ED40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002ED80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002ED80, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002EFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002EFC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:126976, CRC:0x2996B261
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002F000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002F000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x0001F000, CRC: 0x2996B261
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F0C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F0C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F1C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F1C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F2C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F2C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F3C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F3C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F4C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F4C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F5C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F5C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F6C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F6C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F7C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F7C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F8C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F8C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002F9C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002F9C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FA00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FA00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FA40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FA40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FA80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FA80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FAC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FAC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FB00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FB00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FB40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FB40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FB80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FB80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FBC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FBC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FC00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FC00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FC40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FC40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FC80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FC80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FCC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FCC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FD00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FD00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FD40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FD40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FD80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FD80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FDC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FDC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FE00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FE00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FE40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FE40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FE80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FE80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FEC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FEC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FF00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FF00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FF40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FF40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FF80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FF80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002FFC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002FFC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:131072, CRC:0x8DDB2091
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00030000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00030000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00020000, CRC: 0x8DDB2091
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000300C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000300C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000301C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000301C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000302C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000302C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000303C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000303C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000304C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000304C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000305C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000305C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000306C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000306C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000307C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000307C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000308C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000308C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000309C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000309C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00030FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00030FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:135168, CRC:0xC251F038
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00031000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00031000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00021000, CRC: 0xC251F038
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000310C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000310C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000311C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000311C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000312C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000312C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000313C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000313C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000314C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000314C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000315C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000315C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000316C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000316C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000317C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000317C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000318C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000318C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000319C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000319C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00031FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00031FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:139264, CRC:0x68234339
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00032000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00032000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00022000, CRC: 0x68234339
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000320C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000320C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000321C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000321C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000322C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000322C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000323C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000323C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000324C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000324C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000325C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000325C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000326C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000326C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000327C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000327C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000328C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000328C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000329C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000329C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00032FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00032FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:143360, CRC:0xE9A47EEB
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00033000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00033000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00023000, CRC: 0xE9A47EEB
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000330C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000330C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000331C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000331C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000332C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000332C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000333C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000333C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000334C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000334C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000335C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000335C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000336C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000336C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000337C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000337C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000338C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000338C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000339C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000339C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033B80, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033CC0, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000100
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033E00, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20000184
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00033FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00033FC0, pending 0
    <debug> nrf_dfu_req_handler: Offset:147456, CRC:0x38ADD540
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00034000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00034000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00024000, CRC: 0x38ADD540
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000340C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000340C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000341C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000341C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000342C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000342C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000343C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000343C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000344C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000344C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000345C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000345C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034600, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034640, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034680, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000346C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000346C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034700, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034740, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034780, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000347C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000347C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034800, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034840, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034880, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000348C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000348C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034900, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034940, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034980, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000349C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000349C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034A00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034A40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034A80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034AC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034B00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034B40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034B80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034BC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034C00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034C40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034C80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034CC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034D00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034D40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034D80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034DC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034E00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034E40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034E80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034EC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034F00, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034F40, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034F80, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00034FC0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00034FC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:151552, CRC:0x07ADC1FC
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00035000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00035000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 1588. Offset: 0x00025000, CRC: 0x07ADC1FC
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035000, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035040, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035080, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000350C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000350C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035100, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035140, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035180, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000351C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000351C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035200, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035240, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035280, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000352C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000352C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035300, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035340, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035380, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000353C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000353C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035400, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035440, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035480, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000354C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000354C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035500, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035540, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035580, src=0x20000188, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000355C0, src=0x20000104, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000355C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00035600, src=0x20000188, len=52 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00035600, pending 0
    <debug> nrf_dfu_req_handler: Offset:153140, CRC:0xF49EAC19
    <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    <debug> nrf_dfu_validation: Hash verification. start address: 0x10000, size: 0x25634
    <warning> nrf_dfu_validation: Invalidating app because it is incompatible with the SoftDevice.
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <info> nrf_dfu_settings: Restoring settings from backup since the settings page contents are invalid (CRC error).
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20001598, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: App is valid
    <debug> app: DFU mode requested via pin-reset.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    <debug> nrf_dfu_validation: PB: Init packet data len: 69
    <debug> app: Enter main loop
    <debug> nrf_dfu_serial: Received ping 2
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    <debug> nrf_dfu_serial: Set receipt notif target: 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
    <debug> nrf_dfu_serial: Received serial mtu
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    <debug> nrf_dfu_serial: Sending Response: [0x7, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 65
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating hash (len: 65)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <warning> nrf_dfu_ver_validation: SD req not met.
    <warning> nrf_dfu_validation: Prevalidation failed.
    <debug> nrf_dfu_validation: Init command:
    <debug> nrf_dfu_validation:  08 A2 06 10 34 1A 02 80|....4...
    <debug> nrf_dfu_validation:  02 20 00 28 00 30 00 38|. .(.0.8
    <debug> nrf_dfu_validation:  E4 F3 04 42 24 08 03 12|...B$...
    <debug> nrf_dfu_validation:  20 EB FA 8F 38 F8 E0 4B| ...8..K
    <debug> nrf_dfu_validation:  8B 70 07 BD 20 3E 1C 06|.p.. >..
    <debug> nrf_dfu_validation:  BE E7 AA 9B 28 4F AD 8E|....(O..
    <debug> nrf_dfu_validation:  81 6F E0 56 BB 23 3B C3|.o.V.#;.
    <debug> nrf_dfu_validation:  18 48 00 52 04 08 01 12|.H.R....
    <debug> nrf_dfu_validation:  00                     |.
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0xB
    <warning> nrf_dfu_serial: DFU request completed with result: 0xB
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0xB]
    <error> nrf_dfu_validation: Handler: Invalid init command.
    <error> nrf_dfu_validation: Failed to decode init packet
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x5
    <warning> nrf_dfu_serial: DFU request completed with result: 0x5
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x5]
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
  • Referring to these log lines:
    Could you double check to see if the package was generated with the correct --sd-id requirement? I know the information in your initial post show correct SD requirement from the pkg display command, but this is the part that doesn't check out.
