DFU extended error 0x07
I am trying to update an nRF52 through the DFU protocol from an esb firmware without softdevice to a bluetooth firmware with softdevice included.
I am updating the device through a UART interface, using a custom implementation of the DFU protocol complying with DFU protocol (in which PRN is set to 0). I have tested my implementation with softdevice-less esb to softdevice-less esb updates and they work fine.
To create the update package, I run nrfutil v8.0.0, with the following command:
nrfutil pkg generate
--key-file mycert.pem
--hw-version 52
--softdevice sd.hex
--sd-req 0x00,0x0100
--sd-id 0x0100
--application-version-string APP_VERSION
--application app.hex
update.zip
After sending the softdevice .dat file in the "init packet" phase I receive an extended error (0x0B) with a payload of 0x07, which, according to nordic documentation is a SD version error. This happens in response to the execute request (0x04). If I immediately send another execute after the failure I get an error 0x05
If I run nrfutil pkg display on the genarated zip I get the following output:
DFU Package: <update.zip>:
|- Image count: 2
|- Image #0:
|- Type: softdevice
|- Image file: s140_nrf52_7.2.0_softdevice.bin
|- Init packet file: s140_nrf52_7.2.0_softdevice.dat
|- op_code: INIT
|- signature_type: ECDSA_P256_SHA256
|- signature (little-endian): b'SIGNATURE'
|- fw_version: 0xFFFFFFFF (4294967295)
|- hw_version 0x00000034 (52)
|- sd_req: 0x00, 0x100
|- type: SOFTDEVICE
|- sd_size: 153140
|- bl_size: 0
|- app_size: 0
|- hash_type: SHA256
|- hash (little-endian): b'HASH'
|- boot_validation_type: ['VALIDATE_GENERATED_CRC']
|- boot_validation_signature (little-endian): [b'']
|- is_debug: False
|- Image #1:
|- Type: application
|- Image file: radio_ble.bin
|- Init packet file: radio_ble.dat
|- op_code: INIT
|- fw_version: 0x00000322 (802)
|- sd_req: 0x100
|- type: APPLICATION
|- sd_size: 0
|- bl_size: 0
|- app_size: 80356
|- hash_type: SHA256
|- is_debug: False
I have tried setting both NRF_DFU_SINGLE_BANK_APP_UPDATES=0 and NRF_DFU_SINGLE_BANK_APP_UPDATES=1, and I have NRF_DFU_APP_DOWNGRADE_PREVENTION=0
  • Hi MaxMik,
    I just want to update that I tried to setup a reproduction of the issue but met some problems with the debugging bootloader I work with failed to boot correctly.
    I will keep looking into this and keep you updated.
  • Hi MaxMik,
    My failure last time turned out to be a silly human file handling mistake. I was able to DFU a BLE image today by first DFU only the SD (with sd-req set to 0x00), and then DFU only the application (with sd-req set to 0x100).
    Would you like to give that a try?
    Below is the information about my setup for reference.
    1. Starting firmware
      1. nRF5 SDK v17.0.2 MBR (v2.4.1)
      2. nRF5 SDK v17.0.2 secure_bootloader example, pca10056_uart_debug, with the following modifications:
        1. Set NRF_BL_DFU_ENTER_METHOD_BUTTON to 0
        2. Set NRF_BL_DFU_ENTER_METHOD_PINRESET to 1
        3. Set NRF_BL_DFU_INACTIVITY_TIMEOUT_MS to 30000
      3. nRF5 SDK v17.0.2 blinky example, pca10056, mbr
      4. Bootloader settings generated with this command:
        1. nrfutil settings generate --family NRF52840 --application .\_4_app-blinky_pca10056_mbr.hex --application-version 0 --bootloader-version 0 --bl-setting-version 2 _3_bl_settings-bootloader_settings.hex
    2. Confirm blinky boot fine using debugger-triggered soft reset
    3. Put the device into DFU mode with the reset button
    4. DFU v17.1.0 S140 v7.2.0
      1. Package generated with
        1. nrfutil pkg generate --hw-version 52 --softdevice .\v17.1.0_sd-s140_nrf52_7.2.0_softdevice.hex --sd-req 0x00 --key-file .\c352346.key dfu_pkg_sd-sd_req_0x00.zip
    5. DFU v17.1.0 BLE HRS test image
      1. Located at: nRF5_SDK_17.1.0_ddde560\examples\dfu\secure_dfu_test_images\ble\nrf52840\hrs_application_s140.hex
      2. Package generated with
        1. nrfutil pkg generate --hw-version 52 --application-version 1 --application .\v17.1.0_app-hrs_application_s140.hex --sd-req 0x100 --key-file .\c352346.key dfu_pkg_app-sd_req_0x100.zip
    6. Confirm BLE HRS image is advertising as expected
    And here are the relevant project files, build artifacts, hex, and DFU packages, and log from the bootloader.
    c352346_dfu-251107_02.7z
  • After some more trial and error, I was finally able to update my device from the softdevice-less ESB application to the BLE application with softdevice. Turns out what was causing the failures was the pin reset I was performing between processing the softdevice and processing the application. Removing that reset and replacing it with a small delay solved the issue, and I am now able to perform the updates consistently.
  • That's good to hear. I was a little worried we reached a dead end.
    Then, if everything is working as expected, then please feel free to close the ticket at your convenience.
