Example project with Connection ID or TLS_SESSION_CACHE_ENABLED for nrf9151
I am currently experimenting with the nrf9151DK and was hoping to mimic a LTE-M sensor that would wake up once an hour, send a message over CoAP with DTLS, then go back to PSM. (I need to have as little power consumption as possible) On DevAcademy Cellular fundamentals Lesson 5 in exercise 2, it says that the NAT session timeout will close the connection in as little as 12 seconds which would be a problem, and one of the solutions to this is to use TLS_SESSION_CACHE_ENABLED. Doing some further research I found out that there is also a Connection ID (CID) that might be better for reestablishing this connection. However, I am struggling to find ways to implement either of these things into my code and I was wondering if there are any examples of how they work. For now, I am connecting to the "californium.eclipseprojects.io" server and posting my message to the echo resource. I am very much a beginner with cellular and firmware development (not sure if my approach is even correct) so any help will be greatly appreciated.
  • Some further explanation and some follow up questions: The sensor is supposed to take some measurements and send a message over, but does not receive any messages. Do I need to worry about the NAT timer if I don't use DTLS? Am I using the correct method for the lowest power consumption possible? This is a bit far fetched and I know I might not get a straight answer here, but does AWS support session cache or CID with their CoAP servers? Thanks in advance!
  • Does AWS support coap at all?
    DTLS CID is enabled using setsockopt:
    int cid = NRF_SO_SEC_DTLS_CID_SUPPORTED;
    err = setsockopt(sock, SOL_TLS, TLS_DTLS_CID, &cid, sizeof(cid));
    While that may be the case from the view of the application (only transfer in one direction will be required, at least to begin with), from a technical perspective that will come with some common UDP downsides, you will find the using a web search or AI.
    From the power consumption perspective, on large part of that energy is used to switch to RRC active. A so called one-way message will then save some energy, but that will be far away from something as 50% (you will need to measure it on your own for your case, but 20% may be more realistic).
    I run my device with CoAP/DTLS 1.2 CID (see my zephyr-coaps-client and Californium (Cf) - Cloud CoAP-S3-Proxy Server ) and in the very very most cases with CON request and responses. That comes not only with the reliability, it also provides a "downlink channel" for config changes and/or FOTA.
