Mqtt subscriber error
I am experiencing an error that I can't figure it out why it is happening and where to go and try to fix it.
I am using the subscriber implementation on my nRF51, Raspberry Pi as router and broker.
To test it i'm using a python program on Raspberry to publish the "led/state" topic. I set the publisher to send a publish message every 0.5 seconds inside a loop to send 1200 packets, than it closes the connection.
I saw in wireshark that the broker send the publish message to the subscriber than the subscriber send Acknowledgement to the broker and the broker send an Acknowledgement to the subscriber.
So, around 1887 packets sent in this 3 way handshake, the subscriber stops executing and the broker disconnects it because of the timeout. But to get subscriber running again I have to restart and connect it again to the Rpi.
I ran this test publishing in many other ways and the subscriber halts every time around 1885 to 1890 packets.
Is there something on the mqtt code that I can change to not have this issue?
