I just got a power profiler kit II and I want to use it in an battery based application, where there is also the possibility that current will flow in the opposite direction. Eg when an usb cable is plugged in to transmit updates).
What will happen in case such a reverse current goes through the profiler ? Possibilities I can thing of, in order from good to bad:
- it will nicely show negative currents (one can dream right)
- it will just show 0 but let the reverse current pass,
- it blocks reverse currents
- you will get magic smoke
The magic smoke would be bad, I can foresee a bypass switch but it is a given that I am going to forget to toggle it in the heat of the moment. A diode has too much voltage drop, maybe an ideal diode would do the trick ? Anyone already tried something like that ?
And is there a way to disable the led lightshow that I am missing ? I can't find it in the options. I also tried looking at the github page to see if the source code for the firmware is there to make a build without the led. but I only see the hex image. If there is no other way i will desolder the leds but I am hoping I am missing a less drastic solution. (imho blinking is for things that need someones attention, like a firetruck or something, nor for steady state. And even those should be discrete, not blinding floodlights ;p .).
Apart from that it seems like a nice addition to the toolbox
