periodic_adv_conn data ack
hi
I am using periodic_adv_conn and periodic_sync_conn from the NCS 3.0.0 SDK.
After periodic_sync_conn reports data to periodic_adv_conn in the corresponding time slot, the periodic_adv_conn program normally calls the response_cb to parse the data. I see that the function calls bt_conn_le_create_synced to enable the periodic_adv_conn node and the periodic_sync_conn node to connect in the next cycle.
I now want the periodic_adv_conn to reply to the periodic_sync_conn when parsing the data in the response_cb, to acknowledge that the data has been received. So, is there any way to implement this reply directly, or must I use bt_conn_le_create_synced to establish a connection first before replying?
Thanks!
