about nsc logging
I'm using the RTT log feature in NCS, and here is my prj.conf:I have two questions:
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_ESB=y
CONFIG_DK_LIBRARY=y
CONFIG_CLOCK_CONTROL=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_FLASH=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
CONFIG_FCB=y
CONFIG_FLASH_MAP=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_FLASH_LOAD_OFFSET=0x10000
# CONFIG_ESB_FAST_SWITCHING=y
# 启用日志系统
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y
# 启用 RTT 后端
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=n   # RTT输出方式,可选
# 禁用 UART 后端
CONFIG_LOG_BACKEND_UART=n
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
# 若还在使用 printk,也重定向到 RTT
CONFIG_CONSOLE=y
CONFIG_PRINTK=y
  1. After using LOG_INFto output logs, I feel the logs are not output immediately. Since I have enabled CONFIG_LOG_MODE_DEFERRED=y, I can understand this phenomenon. However, some logs are even delayed by about one second before output, which doesn't look ideal. I want to ask: in the nRF5 SDK (52 series), I could call NRF_LOG_PROCESS()in the main function's while(1) loop to quickly flush logs. How can I achieve quick log flushing in NCS?
  2. Even though I have enabled CONFIG_LOG_MODE_DEFERRED=y, the LOG_INFoperation itself still takes quite some time. I tested it with GPIO and found it takes up to 20-30 us. This makes it inconvenient for me to use LOG_INFin interrupt service routines. I remember when using Segger debugging with nRF5 SDK (52833), even with LOG_DEFERREDenabled, NRF_LOG_INFOonly took about 1-2 us. So in NCS, are there any methods to optimize the log operation time? What additional steps should I take?
Thank you!
    Could you please tell me which SDK version you are using? Also, is this a custom board or a DK? Could you also please specify which Nordic chip or DK you are working with.
    Abhijith
    I think you can use the log_flush() function from Zephyr, which processes all pending log messages and flushes them immediately. check the implementation and details in the Zephyr source.
    For the speed optimization, could you include the following configs and let me know if it makes any difference?
    CONFIG_LOG=y
    CONFIG_LOG_SPEED=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    CONFIG_LOG_BUFFER_SIZE=4096
    CONFIG_LOG_MODE_OVERFLOW=y
    CONFIG_LOG_RATELIMIT=y
    CONFIG_LOG_RATELIMIT_INTERVAL_MS=500
    Kind Regards,
    Abhijith
