A bare metal example of Inter Processor Communication (IPC) on nrf5340
Dear experts,
I am programming bare metal using Segger Embedded Studio and nrf.h and want to achieve a simple example of network core sending data to the application core.
Since the network core runs in non-secure domain and application core runs in secure domain, there is a bit of initialization needed but I cannot get it to work.
Here is my example:
In main() on the application core, I run
  spu_configure();
  ipc_rx_configure();
  ipc_rx_recieve();
spu:
#include "SPU.h"
// IPC is peripheral ID 42 on nRF5340
#define IPC_PERIPH_ID 42
void spu_configure(void) {
// In secure boot eller startup på application core
// Configure RAM region 63 (0x2003E000-0x2003FFF) as non-secure
NRF_SPU_S->RAMREGION[63].PERM =
   (SPU_RAMREGION_PERM_READ_Msk |
    SPU_RAMREGION_PERM_WRITE_Msk |
    SPU_RAMREGION_PERM_EXECUTE_Msk);    // SECATTR bit is 0 => non-secure
NRF_SPU_S->PERIPHID[IPC_PERIPH_ID].PERM &= ~SPU_PERIPHID_PERM_SECATTR_NonSecure;
                                        // SECATTR = 0 => non-secure access
and ipc_rx
#include "ipc_rx.h"
#define SHARED_MEM_ADDR ((volatile uint8_t*)0x2003E000)
typedef struct {
    uint8_t id;
    uint16_t value;
    char label[8];
} message_t;
// Configure the app core to trigger an event every time a message is transmitted from network core
void ipc_rx_configure(void) {
  // Enable interrupt for RECEIVE[0]
  NRF_IPC_S->INTENSET = IPC_INTENSET_RECEIVE0_Msk;
  NVIC_EnableIRQ(IPC_IRQn);
void ipc_rx_recieve(void) {
  // From now on this will be interrupt driven so stay here
  while (1) {
    __WFE();
// This event will be triggered every time there is a message.
void IPC_IRQHandler(void) {
    if (NRF_IPC_S->EVENTS_RECEIVE[0]) {
        NRF_IPC_S->EVENTS_RECEIVE[0] = 0;
        message_t *msg = (message_t *)SHARED_MEM_ADDR;
        printf("Message: ");
        printf("%s", msg->label);
        printf(" \n");
        // Use msg->id, msg->value, msg->label
In network core I run<
main()
 ipc_tx_configure();
 for (int i=1; i<1000; i++) {
  ipc_tx_transmit();
  for(int j=0; j<50000; j++) {
    float dummy = sinf(sinf(3.56));
and ipc_tx
#include "ipc_tx.h"
typedef struct {
    uint8_t id;
    uint16_t value;
    char label[8];
} message_t;
void ipc_tx_configure(void){
// Not really needed
void ipc_tx_transmit(void) {
    msg->id = 1;
    msg->value = 1234;
    memcpy(msg->label, "TEMP", 5);
    // Trigger IPC event on channel 0
    NRF_IPC_NS->TASKS_SEND[0] = 1;
The code compiles and runs but I cannot seem to get the interrupt triggered on the application core
Any help appreciated.
/Jonas
  • I don't see the required IRQ_CONNECT() macro in your code. Zephyr interrupt handlers are not called by name. Your program thus tries to to fire an unhandled interrupt which should trigger a corresponding fault.
  • Thank you for your reply. I am not using Zephyr at all since this is bare metal.
  • A small update.
    I can get the interrupt to work now. The app core has to listen to channel 0 and the network core has to be started from the app core.
      // Listen to channel 0
      NRF_IPC_S->RECEIVE_CNF[0] = 1;
      // Enable IPC interrupt in NVIC
      // Start up the network core
      NRF_RESET_S->NETWORK.FORCEOFF = RESET_NETWORK_FORCEOFF_FORCEOFF_Release;
    Next up is to figure out how I can transfer a message through shared memory.
    I read about that the IPC contains two registers for general purpose data GPMEM[0] and [1] but I cannot seem to get the data across to the other core.
    On the network core I use NRF_IPC_NS->GPMEM[0] = 27;
    and on the application core I try printf("Value %u", NRF_IPC_S->GPMEM[0]);
    but the value does not seem to get across and stays at 0. Also in the debugger.
    Any thoughts?
  • Here is an update.
    It works now. I summarize the solution below for anyone who is interested:
    App core main()
      spu_configure();
      ipc_rx_configure();
      ipc_rx_recieve();
    ipc_rx
    volatile uint32_t __attribute__((section(".shared_memory"))) shared_value;
      while (1) {
        //__WFE();
            printf("%u", shared_value);
            printf(" \n");
    spu
    #define SPU_RAM_REGION_INDEX 31
    // Configure RAM region 31 (0x2003F000) as non-secure
    NRF_SPU_S->RAMREGION[SPU_RAM_REGION_INDEX].PERM =
        SPU_RAMREGION_PERM_SECATTR_Non_Secure << SPU_RAMREGION_PERM_SECATTR_Msk |
    I have added a reference to the right memory area in the linker script for both network and application cores as
    place at address 0x2003F000 { section .shared_memory };
    //but for the network core I have also added
    do not initialize                           { section .shared_memory };
    // ...since the app core must unlock the area before the network core can write
    Here is the network core
    main()
     ipc_tx_configure();
     while(1) {
      delay_one_second();
      ipc_tx_transmit();
    ipc_tx
    #define IPC_CHANNEL 0
    // Set up the IPC channel 0 to be used for trigger a signal to application core.
    // We will only send on channel 0 (so we set bit 0 here)
        NRF_IPC_NS->SEND_CNF[IPC_CHANNEL] = 1;
        //Use the shared memory to send a message to the application core
        shared_value = 23;
        NRF_IPC_NS->TASKS_SEND[IPC_CHANNEL] = 1;
