GPIO pull up timing
We are testing a custom board based on the nRF5340 that drives an RGB LED strip using the TI TLC5947 LED driver.
The TLC5947 has an OE (Blank) pin that disables/enables the outputs. When the system powers up, the LEDs briefly flash before the MCU finishes initializing, which we’d like to avoid.
Our board does not include a hardware pull-up on the OE pin, so I enabled the internal pull-up in the device tree as follows:
rgb_led_strip: rgb_strip {
    compatible = "ti,tlc5947";
    clk-gpios = <&gpio1 11 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
    data-gpios = <&gpio1 10 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
    lat-gpios  = <&gpio1 12 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
    oe-gpios   = <&gpio1 13 (GPIO_PULL_UP   | GPIO_ACTIVE_HIGH)>;
    chain-length = <1>;
    color-mapping = <3 2 1>;
    status = "okay";
Initialization function
int tlc5947_init(const struct device *dev)
    const struct tlc5947_config *cfg = dev->config;
    const struct gpio_dt_spec *clk = &cfg->clk;
    const struct gpio_dt_spec *data = &cfg->data;
    const struct gpio_dt_spec *latch = &cfg->latch;
    const struct gpio_dt_spec *blank = &cfg->blank;
    int err = 0;
    if(!gpio_is_ready_dt(clk))
        LOG_ERR("%s: no LEDs found (DT child nodes missing)", dev->name);
		return -ENODEV;
    if(!gpio_is_ready_dt(data))
		return -ENODEV;
    if(!gpio_is_ready_dt(latch))
		return -ENODEV;
    if(!gpio_is_ready_dt(blank))
		return -ENODEV;
    err = gpio_pin_configure_dt(clk, GPIO_OUTPUT_INACTIVE);
	if (err < 0) {
		LOG_ERR("%s: Unable to setup clk port", dev->name);
		return -EIO;
    err = gpio_pin_configure_dt(data, GPIO_OUTPUT_INACTIVE);
	if (err < 0) {
		LOG_ERR("%s: Unable to setup data port", dev->name);
		return -EIO;
    err = gpio_pin_configure_dt(latch, GPIO_OUTPUT_INACTIVE);
	if (err < 0) {
		LOG_ERR("%s: Unable to setup LAT port", dev->name);
		return -EIO;
    err = gpio_pin_configure_dt(blank, GPIO_PULL_UP | GPIO_OUTPUT_ACTIVE);
	if (err < 0) {
		LOG_ERR("%s: Unable to setup OE port", dev->name);
		return -EIO;
 //gpio_pin_set_dt(blank, 1);
    return 0;
Module definition
#define TLC5947_DATA_BUFFER_LENGTH(i) (DT_INST_PROP(i, num_channels))
#define TLC5947_DEVICE(i)        \
	static struct tlc5947_config tlc5947_config_##i = {                                            \
		.clk = GPIO_DT_SPEC_INST_GET(i, clk_gpios),                                                 \
        .data = GPIO_DT_SPEC_INST_GET(i, data_gpios),                                           \
        .latch = GPIO_DT_SPEC_INST_GET(i, lat_gpios),                                         \
        .blank = GPIO_DT_SPEC_INST_GET(i, oe_gpios),                                          \
		.channels = DT_INST_PROP(i, num_channels),                                      \
        .max_pwm = DT_INST_PROP(i, max_pwm),                                         \
    static uint16_t tlc5947_##i##_data_buffer[TLC5947_DATA_BUFFER_LENGTH(i)];             \
	static struct tlc5947_data tlc5947_##i##_data = {                                       \
		.data_buffer = tlc5947_##i##_data_buffer,                                       \
		.gbc_color_1 = 4096,                              \
		.gbc_color_2 = 4096,                              \
		.gbc_color_3 = 4096,                              \
	DEVICE_DT_INST_DEFINE(i, tlc5947_init, NULL, &tlc5947_##i##_data, &tlc5947_config_##i, POST_KERNEL,   \
			        40, &tlc5947_gpio_api);
DT_INST_FOREACH_STATUS_OKAY(TLC5947_DEVICE)
Goal
Prevent any LED activity at power-up by ensuring OE = HIGH (outputs disabled) as early as possible, ideally before or during MCU startup.
Questions
  1. Is my GPIO configuration correct to guarantee OE stays HIGH before firmware initialization?
    (i.e., should I rely on the internal pull-up or configure OE earlier in system startup?)
  2. Is there a recommended way to ensure that OE remains asserted immediately after reset, before Zephyr fully configures the pins (e.g., via pinctrl or bootloader stage)?
    Does the "glitch"  happen during the initialization in tlc5947_init()? Since all the pins are outputs, I don’t see any reason to enable the pull-ups or pull-downs. The active high outputs initialized with the GPIO_OUTPUT_INACTIVE flag should be configured as output low and ensure that the signal is driven low. Are the pads accessible so you can probe the signals with a scope or logic analyzer?
    Vidar
