Why 'pwm_set_dt(xxx, 0)' can not set gpio floating on NCS SDK 3.0.2 ?
For power cost down, use dts config  to set pwm gpio H0D1 as follow:
pwm1_default: pwm1_default {
group1 {
psels = <NRF_PSEL(PWM_OUT1, 0, 26)>;
nordic,drive-mode = <NRF_DRIVE_H0D1>;
1. When on NCS 2.4.1,  pwm func 'pwm_set_dt(xxx, 0)' can set gpio floating
2. When on NCS 3.0.2, 'pwm_set_dt(xxx, 0)' can NOT set gpio floating, because current get up 50 uA !
How can I use  'pwm_set_dt(xxx, 0)' set pwm gpio floating ?  and get current cost down?
  • On DK board, use pwm to drive LED3, compare the different bottom current condition between CONFIG_I2C=y and CONFIG_I2C=n
    In overlay, config P0.19 to drive LED3:
    It seems CONFIG_I2C=y affect power cost of pwm pin ?
    Setting CONFIG_I2C=y will cause an added current consumption due to the pins floating.
    Try adding a internal pull-up resistor and see if this helps with the current consumption.
    When running on nRF52-DK, with CONFIG_SERIAL=n, I see this current consumption.
    * CONFIG_I2C=n : ~0.3 mA
    * CONFIG_I2C=y : ~0.35 mA
    * CONFIG_I2C=y + SDA/SCL pin pull up: ~0.3 mA
    PS: PWM is active here.
    Please note that if I set pwm = 0 % or 100 %, I see < 10 uA.
    Here's the nrf52dk_nrf52832.overlay file with pull-up on SDA/SCL P0.26/P0.27:
    &pinctrl {
    	i2c0_default: i2c0_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
    				<NRF_PSEL(TWIM_SCL, 0, 27)>;
    			bias-pull-up;
    Please note that the I2C is now idle, and if started; you should use the pm_device API to set it to sleep/active state, similar to what is shown here:
    https://github.com/nrfconnect/sdk-zephyr/blob/ncs-v3.1.1/samples/sensor/apds9960/src/main.c#L80-L83
    Håkon
  • Hi Hakon,
    I try your code on my DK board, I found i2c0 is okay, but if I change i2c0 to i2c1,  and use P0.03/P0.04, the issue(bottom current increase) can be reproduce, as below:
    &pinctrl {
        i2c1_default: i2c1_default {  //use i2c1, and P0.03/P0.04
            group1 {
            psels = <NRF_PSEL(TWIM_SDA, 0, 4)>,
            <NRF_PSEL(TWIM_SCL, 0, 3)>;
            bias-pull-up;
    If the I2C is active, it will raise your current consumption, and you will need to do as I previously shared, ie. turn off the hardware peripheral:
     And pull-up resistors shall be applied when the I2C is disabled.
    Can you please try to disable I2C and apply pull-ups to the pins when entering sleep in this scenario?
    Max_Singsun said:
    2. On product board(P0.26 drive LED), keep I2C pin disconnect, let CONFIG_I2C=n and delete all I2C application code(delete I2C init and other I2C ops), high bottom current disappear(bottom current  is about 5~6 uA).
    Håkon
  • Hi Hakon,
    I 've got the point:  if replace "i2c1" to "i2c0  in overlay file, then the issue dispeared.  I mean that using i2c1 and P0.03/P0.04 may have some bugs in ncs 3.0.2, if you are not sure, you can try i2c1 and P0.03/P0.04 to confirm if it can work, as:
    &pinctrl {
            group1 {
            bias-pull-up;
    I want to know why i2c1 and P0.03/P0.04 cannot work together.
