TIMER + PWM + SAADC + PPI
I'd like to control a DC motor using PWM (PWM0, pretty straight forward). To determine motor speed I disable the PWM every 5ms (TIMER1, pretty straight forward) and measure Back-EMF via SAADC. To synchronise this I'd like to use PPI
In order to implement a stable solution I'd like to clarify a few things with you:
1. Start SAADC
err = nrf_drv_ppi_channel_assign (ppiCh, (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[1], (uint32_t)&NRF_SAADC->TASKS_START);
NRF_PPI->FORK[ppiCh].TEP = (uint32_t)&NRF_SAADC->TASKS_SAMPLE;
Do I need the FORK instruction? What is the difference between START and SAMPLE? I find the manual is not very clear on this.
2. SAADC multi-channel Every 5ms (i.e. when PWM disabled) I'd like to sample 2 channels. Here is my code
nrf_saadc_channel_config_t  adcChannel0 = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE (AIN0);
adcChannel0.gain      = NRF_SAADC_GAIN1_4;
adcChannel0.reference = NRF_SAADC_REFERENCE_VDD4;
err = nrf_drv_saadc_channel_init (0, &adcChannel0);
nrf_saadc_channel_config_t  adcChannel1 = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE (AIN1);
adcChannel1.gain      = NRF_SAADC_GAIN1_4;
adcChannel1.reference = NRF_SAADC_REFERENCE_VDD4;
err = nrf_drv_saadc_channel_init (1, &adcChannel1);
In case that one channel is configured (AIN0 only) my code works as expected In case that two channels are configured (AIN0/1, as per example above) the 5ms time slots are lost. Why? We're working with Rev1 samples. Can we use Scan Mode? There are numerous references about it being buggy...
3. SAADC results
I believe I understand the concept behind this:
NRF_SAADC->RESULT.PTR    = (uint32_t)mAdcResult;
NRF_SAADC->RESULT.MAXCNT = 1;
When running my code I doubt that values in mAdcResult are correct. They are updated but the value doesn't change even though the actual analog voltage does.
4. Other stuff Here is some more you might need to know:
nrf_drv_saadc_init (NULL, onAdcEvent);
static void  onAdcEvent (nrf_drv_saadc_evt_t const *event)
    if (event->type == NRF_DRV_SAADC_EVT_DONE)
        NRF_SAADC->TASKS_STOP = 1;  <-- Do I need this ?
        NRF_SAADC->EVENTS_END = 0;  <-- Do I need this ?
        nrf_gpio_pin_toggle (PIN_DEBUG);
SAADC resolution: set to 10bit SAADC oversamling: set to disabled
Thanky for your help
  • Hi
    Difference between START and SAMPLE: Figure 4 in the SAADC specification shows this a bit. You need to call start to prepare the RAM buffer and you call START once for every buffer setup. However, you call SAMPLE for every sample.
    Do you not want to use the nrf_drv_saadc driver? The SAADC example in the SDK uses the driver, which seems to make the setup much easier. If you do not want to use the driver, I think it is good to look at the code in nrf_drv_saadc.c file to see how the driver sets up things.
    Sync PWM and SAADC events: From your description I imagine the procedure could be as follows:
    1. Setup timer with 5ms periodic interrupts
    2. On every interrupt, disable PWM, then sample once with SAADC. Enable oversampling for better noise immunity
    3. Change PWM duty cycle based on SAADC measurement
    4. Enable PWM
    With the SAADC driver, you enable oversampling in the nrf_drv_config.h file, which is the driver configuration file, example provided here. Also taking a single sample is a matter of calling nrf_drv_saadc_sample_convert driver function. The nrf_drv_saadc_sample_convert call is blocking so it will return the SAADC value and you do not need to implement any nrf_drv_saadc callback function.
    The SAADC scan mode is not operational for nRF52832 Engineering A, i.e. the nRF52-DK preview kit, but should be good for the nRF52-DK which holds nRF52 Engineering B chip and later. Do you think there are references for the scan mode to not work for Engineering B?
    If you use the driver, you do not need to worry about details, the driver would do that for you.
    The nrf_drv_saadc driver implements the SAADC interrupt hanlder internally and does all the necessary stuff. Look at the SAADC example in the SDK to realize what you need to implement in the nrf_drv_saadc callback.
  • Thank you Stefan and I do appreciate your elaborate answer.
    I will change my code to use the library. What you see here was started last October - very early stages for us and the nRF52...
    There is one more question: I use Timer 1, CC[0] (set to 5ms) and CC[1] (set to 300us) I use PPI to connect CC[0] to PWM0, TASKS_STOP (= stop after 5 ms) I use PPI to connect CC[1] to SAADC, TASKS_SAMPLE (= delay sampling by 300us) I use PPI to connect SAADC, EVENTS_END to PWM0, TASKS_SEQSTART --> this works well --> question is: is there a interrelation between CC[x]? In particular, if I use CC[2] (set to 1ms) for something unrelated the sampling sequence (s. above) gets out of whack. I think the manual does not make any references to this.
  • Please confirm my understanding. You say that you start PWM, then start the timer and then:
    CC[1] compare match samples SAADC 300 us from timer start
    CC[2] compare match does additional task 1 ms from timer start
    CC[0] compare match stops PWM 5 ms from timer start
    Do you restart the timer after you stop the PWM?
    I find it strange that you start PWM after each sampling, but only stop it every 5 seconds. Should you not start the PWM as many times as you stop it?
    When do you process the SAADC data? Do you use EasyDMA to collect SAADC data in RAM?
    With " the sampling sequence (s. above) gets out of whack" do you mean that the sequence of things is not as expected or is it that the timing of the sampling is not every 300us anymore? If the timing is out of order, how are you measuring the timing?
  • Hi Stefan,
    Thanks again for helping me out with this. Please refer to the diagram attached to this and note that Ch-1 means CC[0] and Ch-2 means CC[1].
    If I do what's on the diagram all works fine. If I add a 1ms timer channel (i.e. CC[2] with IR attached) the sequence stops working. Why?
    The following generates the sequence as shown in the diagram. The code works well. But why does it stop working when I add CC[2]?
       err = nrf_drv_ppi_init ();
                              /* Connect timer channel 0 to PWM-0 channel-0 stop */
        err = nrf_drv_ppi_channel_alloc (&ppiCh);
        err = nrf_drv_ppi_channel_assign (ppiCh, (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[0],
                                                 (uint32_t)&NRF_PWM0->TASKS_STOP);
        err = nrf_drv_ppi_channel_enable (ppiCh);
                              /* Connect timer channel 1 to SAADC start & sample */
                                                 (uint32_t)&NRF_SAADC->TASKS_SAMPLE);
                                   /* Connect SAADC end to PWM-0 channel 0 start */
        err = nrf_drv_ppi_channel_assign (ppiCh, (uint32_t)&NRF_SAADC->EVENTS_END,
                                                 (uint32_t)&NRF_PWM0->TASKS_SEQSTART[0]);
  • Can you tell me what hardware revision you have, what softdevice (if you are using softdevice) and what SDK version?
1 2
