about CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC
I am using ​​NCS 3.0.2 + VSCode​​ to develop for the ​​nRF54L15​​. I have two projects:
  1. \nrf\samples\bootloader\src
  2. \nrf\samples\esb_prx
Since my custom board does not have a ​​32.768 kHz crystal​​, I defined ​​CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC​​ in the prj.confof the ​​ESB project​​, and the code runs successfully. I can also confirm that CONFIG_CLOCK_CONTROL_NRF_K32SRC_RCis correctly set in the .configfile.However, when I define the same macro (CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC) in the ​​bootloader project's prj.conf​​, I get the following error:
​​CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC was assigned the value y, but got the value n. Missing dependencies: <choice CLOCK_CONTROL_NRF_SOURCE>​​
I don’t understand why the same macro definition behaves differently in the two projects. The error mentions a missing dependency (CLOCK_CONTROL_NRF_SOURCE), but I didn’t define it in the ESB project either, yet the ESB project works fine. This is very confusing to me.
​​My questions are:​​
  1. ​​How can I successfully define CONFIG_CLOCK_CONTROL_NRF_K32SRC_RCin the bootloader project?​​
  2. ​​What is the root cause of this issue?​​
    • If I encounter similar CONFIGdefinition failures in the future, what approach should I take to debug and resolve them?
Thank you!
here are prj.conf of tow project↓
bootloader prj.conf
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_CLOCK_CONTROL=y
CONFIG_IS_SECURE_BOOTLOADER=y
CONFIG_MULTITHREADING=n
CONFIG_GPIO=n
CONFIG_ARM_MPU=n
CONFIG_TICKLESS_KERNEL=n
CONFIG_ERRNO=n
CONFIG_FPROTECT=y
CONFIG_SECURE_BOOT_CRYPTO=y
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y
CONFIG_LOG_DEFAULT_LEVEL=0
CONFIG_SECURE_BOOT_VALIDATION=y
CONFIG_SECURE_BOOT_VALIDATION_LOG_LEVEL_INF=y
CONFIG_SECURE_BOOT_STORAGE=y
CONFIG_BL_ROT_VERIFY_EXT_API_ENABLED=y
CONFIG_BL_SHA256_EXT_API_ENABLED=y
CONFIG_BL_SECP256R1_EXT_API_ENABLED=y
CONFIG_BL_VALIDATE_FW_EXT_API_ENABLED=y
CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_TIMEOUT_64BIT=n
# Disable asserts because of false positive when writing to OTP.
CONFIG_ASSERT=n
# Avoid triggering IRQs from the RTC
CONFIG_NRF_RTC_TIMER=n
esb prj.conf
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_MY_ESB=y
CONFIG_DK_LIBRARY=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_FLASH=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
CONFIG_FCB=y
CONFIG_FLASH_MAP=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_FLASH_LOAD_OFFSET=0x10000
# CONFIG_ESB_FAST_SWITCHING=y
# 启用日志系统
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y
# 启用 RTT 后端
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=n   # RTT输出方式,可选
# 禁用 UART 后端
CONFIG_LOG_BACKEND_UART=n
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
# 若还在使用 printk,也重定向到 RTT
CONFIG_CONSOLE=y
CONFIG_PRINTK=y
# CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=n
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=10
CONFIG_NRFX_POWER=y
    It seems a common error for bootloader when internal RC is used. The solution is to set the correct clock source in both application and bootloader image.
    You have set CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y in config file. But it is also needed to disable the XTAL exclusively by setting CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n.
    You can try set both of these in prj.conf and mcuboot.conf ( child_image/mcuboot.conf) file
    You can try this and let us know if it works.
    Thanks.
    BR
    Kazi
