NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP fails unexpectedly
I'm trying to use the nRF Desktop project as a base for our project, prototyping on the nrf54l15dk_nrf54l15_cpuapp board target. I have an overlay file defined like this:
&i2c21 {
    status = "okay";
    compatible = "nordic,nrf-twim", "i2c-device";
    pinctrl-0 = <&i2c21_default>;
    pinctrl-1 = <&i2c21_sleep>;
    clock-frequency = <I2C_BITRATE_FAST>;
    bmi270: bmi270@69 {
        compatible = "bosch,bmi270";
        reg = <0x69>;
        irq-gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
&pinctrl {
    i2c21_default: i2c21_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SCL, 1, 11)>, <NRF_PSEL(TWIM_SDA, 1, 12)>;
    i2c21_sleep: i2c21_sleep {
        group1 {
            psels = <NRF_PSEL(TWIM_SDA, 1, 11)>, <NRF_PSEL(TWIM_SCL, 1, 12)>;
            low-power-enable;
&nfct {
    status = "disabled";
Which yields the following build failure:
from /.../sdk-nrf/v3.1.1/zephyr/drivers/i2c/i2c_nrfx_twim.c:7:
/.../sdk-nrf/v3.1.1/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "/soc/peripheral@50000000/i2c@c7000 defined without sleep state"
   87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert((EXPR), "" MSG)
/.../sdk-nrf/v3.1.1/zephyr/soc/nordic/common/./soc_nrf_common.h:235:9: note: in expansion of macro 'BUILD_ASSERT'
  235 |         BUILD_ASSERT(!IS_ENABLED(CONFIG_PM_DEVICE) ||                          \
/.../sdk-nrf/v3.1.1/zephyr/drivers/i2c/i2c_nrfx_twim.c:255:9: note: in expansion of macro 'NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP'
  255 |         NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP(I2C(idx));                         \
/.../sdk-nrf/v3.1.1/zephyr/drivers/i2c/i2c_nrfx_twim.c:326:1: note: in expansion of macro 'I2C_NRFX_TWIM_DEVICE'
  326 | I2C_NRFX_TWIM_DEVICE(21);
[295/422] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
I can see the build system is picking up this overlay, and I can also see it in device tree VSCode GUI. The GUI can modify the file fine and there are no parse errors. The configurations I have set are:
CONFIG_ASSERT=y
CONFIG_ASSERT_LEVEL=2
#I2C and sensors configuration
CONFIG_I2C=y
CONFIG_PINCTRL=y
CONFIG_I2C_NRFX=y
CONFIG_SENSOR=y
CONFIG_BMI270=y
CONFIG_I2C_DW_EXTENDED_SUPPORT=y
I'm at a loss trying to debug this any further. As far as I can tell, I have everything set up correctly. Please let me know if I'm missing something.
  • Hi Martin,
    Could you try to test with \zephyr\samples\drivers\i2c\rtio_loopback sample ?
    I can see that it also has an overlay that uses the i2c21. I couldn't spot any problem with  your overlay compare to the one in this example. But maybe you can try to use the sample overlay in your application to see if it work ?
    Could you provide a simple sample that we can test here ?
