Errors when attempting to flash target with J-Link, failure to read board memory, timeouts
I have been having a series of issues with programming from nRF Connect using a J-Link programmer. I have made a couple of other recent posts and in each of those, I thought I had found a solution only for the problem to return in a slightly different form.
My target is an Adafruit nRF52840 Express (https://www.adafruit.com/product/4062). I have used these boards a lot over the past couple of years, including for a released product. Up until the past couple of weeks, I've had no difficulty flashing them.
I am using SDK and toolchain 2.2.0.
Here is what I get when I try to flash from VSCode with nRF Connect plugin:
Flashing build to J-Link Ultra+
west flash -d c:\gitRepos\GR3_Firmware\build --dev-id 504500724
-- west flash: rebuilding
[0/4] Performing build step for 'mcuboot_subimage'
ninja: no work to do.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: C:\gitRepos\GR3_Firmware\build\zephyr\merged.hex
[error] [ Client] - Encountered error -102: Command read_device_info executed for 124 milliseconds with result -102
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 30 milliseconds with result -102
Failed to read device memories.[error] [ Worker] - An unknown error.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program 'C:\gitRepos\GR3_Firmware\build\zephyr\merged.hex' --sectoranduicrerase --verify -f NRF52 --snr 504500724
 *  The terminal process terminated with exit code: 33.
I took the command from the end of this bit and ran in from a new terminal in nRF Connect. Here's what I got:
PS C:\gitRepos\GR3_Firmware> nrfjprog --program 'C:\gitRepos\GR3_Firmware\build\zephyr\merged.hex' --sectoranduicrerase --verify -f NRF52 --snr 504500724
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 31 milliseconds with result -102
So, I ran it again with the --log option, as it suggests. Here is the log it generated.
[2025-Oct-17 14:15:21] [debug] --------------------------------------------------------------------------------
[2025-Oct-17 14:15:21] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --program C:\gitRepos\GR3_Firmware\build\zephyr\merged.hex --sectoranduicrerase --verify -f NRF52 --snr 504500724 --log
[2025-Oct-17 14:15:21] [debug] nrfjprog version 10.24.2 external
[2025-Oct-17 14:15:21] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2025-Oct-17 14:15:21] [ info] Library loaded, loading member functions.
[2025-Oct-17 14:15:21] [ info] Member functions succesfully loaded.
[2025-Oct-17 14:15:21] [debug] [ Client] - open
[2025-Oct-17 14:15:21] [debug] [ Client] - start
[2025-Oct-17 14:15:21] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence bd106a28-2265-4931-a7f7-146718fe97eb.
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2025-Oct-17 14:15:21] [debug] [  JLink] - Logger sink registered in JLink logger
[2025-Oct-17 14:15:21] [debug] [  nRF52] - open
[2025-Oct-17 14:15:21] [debug] [  nRF52] - just_check_family
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - open_dll
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2025-Oct-17 14:15:21] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V818\JLink_x64.dll.
[2025-Oct-17 14:15:21] [trace] [ Client] - Command open executed for 228 milliseconds with result 0
[2025-Oct-17 14:15:21] [debug] [ Client] - config
[2025-Oct-17 14:15:21] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2025-Oct-17 14:15:21] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - Set batch mode
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - dll_version
[2025-Oct-17 14:15:21] [ info] [SeggerBackend] - Segger dll version 8.18.  loaded.
[2025-Oct-17 14:15:21] [trace] [ Worker] - Command open executed for 18 milliseconds with result 0
[2025-Oct-17 14:15:21] [trace] [ Client] - Command config executed for 16 milliseconds with result 0
[2025-Oct-17 14:15:21] [debug] [ Client] - enum_emu_snr
[2025-Oct-17 14:15:21] [debug] [  nRF52] - config
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - enum_emu_snr
[2025-Oct-17 14:15:21] [trace] [ Worker] - Command config executed for 3 milliseconds with result 0
[2025-Oct-17 14:15:21] [debug] [  nRF52] - enum_emu_con_info
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - is_connected_to_emu
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - enum_emu_con_info
[2025-Oct-17 14:15:21] [trace] [ Client] - Command enum_emu_con_info executed for 30 milliseconds with result 0
[2025-Oct-17 14:15:21] [debug] [ Client] - connect_to_emu_with_snr
[2025-Oct-17 14:15:21] [trace] [ Worker] - Command enum_emu_con_info executed for 17 milliseconds with result 0
[2025-Oct-17 14:15:21] [debug] [  nRF52] - connect_to_emu_with_snr
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - ---just_get_num_emus
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2025-Oct-17 14:15:21] [debug] [SeggerBackend] - Segger logging enabled.
[2025-Oct-17 14:15:22] [trace] [  JLink] - Firmware: J-Link Ultra V4 compiled Sep 22 2022 15:00:10
[2025-Oct-17 14:15:22] [trace] [  JLink] - Decompressing FW timestamp took 168 us
[2025-Oct-17 14:15:22] [trace] [  JLink] - Hardware: V4.00
[2025-Oct-17 14:15:22] [trace] [  JLink] - S/N: 504500724
[2025-Oct-17 14:15:22] [trace] [  JLink] - OEM: SEGGER
[2025-Oct-17 14:15:22] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2025-Oct-17 14:15:22] [trace] [  JLink] - Bootloader: (FW returned invalid version)
[2025-Oct-17 14:15:22] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2025-Oct-17 14:15:22] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2025-Oct-17 14:15:22] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2025-Oct-17 14:15:22] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V818\JLinkGUIServer.exe
[2025-Oct-17 14:15:22] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V818\JLinkGUIServer.exe
[2025-Oct-17 14:15:22] [trace] [ Client] - Command connect_to_emu_with_snr executed for 205 milliseconds with result 0
[2025-Oct-17 14:15:22] [debug] [ Client] - read_connected_emu_snr
[2025-Oct-17 14:15:22] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.18 "
[2025-Oct-17 14:15:22] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 151.113ms returns "O.K."
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_HasError()
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_Lock()
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2025-Oct-17 14:15:22] [debug] [ Client] - read_device_info
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.003ms returns 0x01
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.002ms returns 0x00
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.008ms returns 0x00
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.027ms returns 0
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.561ms returns 0x00
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2025-Oct-17 14:15:22] [trace] [  JLink] - 1600000000 Hz / n, n >= 32
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.014ms
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 50000kHz
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.095ms
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_GetSpeed()
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.008ms returns 2000
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_GetSN()
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.005ms returns 504500724
[2025-Oct-17 14:15:22] [debug] [  nRF52] - read_device_family
[2025-Oct-17 14:15:22] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 192 milliseconds with result 0
[2025-Oct-17 14:15:22] [debug] [  nRF52] - read_connected_emu_snr
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - is_connected_to_emu
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_IsOpen()
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.015ms returns 0x01
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - read_connected_emu_snr
[2025-Oct-17 14:15:22] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2025-Oct-17 14:15:22] [debug] [  nRF52] - read_device_info
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.020ms returns 0x01
[2025-Oct-17 14:15:22] [debug] [  nRF52] - Just_read_device_version
[2025-Oct-17 14:15:22] [debug] [  nRF52] - Just_readback_status
[2025-Oct-17 14:15:22] [debug] [  nRF52] - Just_is_ctrl_ap_available
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - read_access_port_register
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - ---just_read_access_port_register
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - coresight_configure
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.184ms returns 0
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 100.912ms returns 0
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - read_debug_port_idr
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - read_debug_port_register
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.658ms returns -1
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - ---just_abort_debug_action
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.527ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.535ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.519ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.520ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.562ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.524ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.601ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.518ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.504ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.485ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.502ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.522ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.745ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.427ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.536ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.494ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.564ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.525ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.549ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.690ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.422ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.677ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.539ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.432ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.469ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.392ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.441ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.492ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.475ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.476ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.487ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.484ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.465ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.480ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.456ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.853ms returns -1
[2025-Oct-17 14:15:22] [error] [ Client] - Encountered error -102: Command read_device_info executed for 140 milliseconds with result -102
[2025-Oct-17 14:15:22] [warning] Failed to read device info. Attempting to complete command anyways.
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.773ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.167ms
[2025-Oct-17 14:15:22] [error] [ Worker] - An unknown error.
[2025-Oct-17 14:15:22] [trace] [ Worker] - Command read_device_info executed for 125 milliseconds with result -102
[2025-Oct-17 14:15:22] [debug] [ Client] - read_memory_descriptors
[2025-Oct-17 14:15:22] [debug] [  nRF52] - read_memory_descriptors
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.045ms returns 0x01
[2025-Oct-17 14:15:22] [debug] [  nRF52] - Just_read_memory_descriptors
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.683ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.453ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.555ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.451ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.471ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.460ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.445ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.554ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.540ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.584ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.702ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.571ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.547ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.731ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.459ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.443ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.446ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.412ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.474ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.424ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.399ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.455ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.837ms returns -1
[2025-Oct-17 14:15:22] [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 30 milliseconds with result -102
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.449ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.529ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.500ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.561ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.583ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.506ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.587ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.435ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.083ms
[2025-Oct-17 14:15:22] [trace] [ Worker] - Command read_memory_descriptors executed for 23 milliseconds with result -102
[2025-Oct-17 14:15:22] [debug] [  nRF52] - close
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.014ms returns 0x01
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - close
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - disconnect_from_emu
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - is_connected_to_device
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_IsConnected()
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.006ms returns FALSE
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.643ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.545ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.753ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.477ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.580ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.478ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.623ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.582ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.574ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.621ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.503ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.497ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.450ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.442ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.464ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.457ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.578ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.531ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.467ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.466ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.439ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.444ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.624ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.534ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.608ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.512ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.448ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.486ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.468ms returns -1
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.560ms returns -1
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2025-Oct-17 14:15:22] [trace] [  JLink] - - 0.088ms
[2025-Oct-17 14:15:22] [trace] [  JLink] - JLINK_Close()
[2025-Oct-17 14:15:22] [debug] [SeggerBackend] - Segger Backend closed.
[2025-Oct-17 14:15:22] [debug] [  nRF52] - nRF family DLL closed
[2025-Oct-17 14:15:22] [trace] [ Worker] - Command close executed for 61 milliseconds with result 0
[2025-Oct-17 14:15:22] [trace] [ Client] - Command close executed for 78 milliseconds with result 0
[2025-Oct-17 14:15:22] [debug] [ Client] - terminate
[2025-Oct-17 14:15:22] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2025-Oct-17 14:15:22] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2025-Oct-17 14:15:22] [trace] [ Worker] - Executed 9 commands for 439 milliseconds
[2025-Oct-17 14:15:22] [debug] [ Client] - Worker process exited with code: 0
[2025-Oct-17 14:15:22] [debug] [ Client] - Child process terminated with result 0
[2025-Oct-17 14:15:22] [trace] [ Client] - Executed 9 commands for 742 milliseconds
Earlier today, after switching the project to use nrfjprog, I was able to flash several times in a row with no problems at all, and I thought the issue was solved.
The fact that the problem seems to come and go like that made me wonder if it could be something like a bad connection. On that thread of investigation:
  • I have tried this with two different target boards and with two different SWD cables and get the same results each time.
  • I am programming through an adapter that goes from the connector on the J-Link to the small 10-pin ribbon cable often used for SWD. Careful inspection of that adapter board reveals no obvious faults or bad solder joints.
  • The programmer itself is a Segger J-Link Ultra+. The label on the bottom says it is version 4.5, manufactured week 25 2018, part number 8.16.28.
I also found another thread here on DevZone where a similar issue was resolved with the addition of a -c option to the programming command to slow down the data rate. I tried adding this and still had the same problems, though the timeouts mentioned were longer.
    The log shows that there is no communication between the Jlink probe and the nRF target. I can reproduce the same error too if I cut the power to the nRF52840 chip on my nRF52840 DK board. However, it’s strange that it suddenly stopped working on your end and also that it happens on two different boards. Do you have any existing firmware running on these boards that tells if you if the chips are powered and functional (for example, blinking an LED, etc.)?
    Vidar
  • Hi Vidar,
    One indication that the existing firmware is running is that I can see output from the serial over USB CDC ACM. Also, the board has an LED that lights amber when USB is connected. (That's where it's getting power from.)
    When I watch TeraTerm while attempting to flashing, here's what I see:
    • Initially, normal operation, everything is running and I see, for example, indication when a Bluetooth packet is received.
    • Then I click flash in nRF Connect. The process initiates, then I see the error message and it exits with status 33.
    • Immediately after that, I see a short burst of serial spam from the USB CDC about "ring buffer full."
    • Then my firmware starts up again from a clean reset and normal operation resumes.
    So, I am pretty confident that the target does have power. As an experiment, I just went into the jlink utility and typed "power on" to turn on the programmer's power for the target. Then I tried to flash again and got the same errors.
    Next I tried within the jlink.exe console utility typing "connect."  It asked me to configure parameters such as device family, SWD, speed. Then it attempted to connect and failed with the same symptoms.
    We have another product that uses the nRF5340. I tried flashing one of those boards with this programmer. It worked 100% fine, no problem at all and nothing unusual. (Perhaps of note, though, is that when I connect to those boards, I use a different set of cables and adapter, because those boards don't use the small SWD 10-pin connector.)
    So, it has problems with the nRF52840 board, but not the 5340. I have an nRF52840-DK. I plugged the J-Link into the DEBUG-IN port on that and connected using the jlink console app. It seemed to connect fine. I plug it back into the Feather nRF52840 Express board... will not connect.
    So, the problem is with these Feather boards specifically, though they have all worked in the past and I have a product in the field based around these boards. What could have changed? Something with the J-Link software? Any idea what else I should be looking at?
  • After thinking about this some more, I pulled out the JTAG to SWD adapter I use for these, looked at it under a bench microscope, cleaned it and inspected it. I put it back on the JLink, careful to make solid connections. And now... everything works again. My current theory is that this adapter has been the problem the whole time. Maybe something is a little wiggly in there. If I wiggle it out of socket slightly I can get the same error message again.
    Thank you for your help! I'll mark this as a resolution and order extra adapters. Thank you for your time and patience troubleshooting this issue.
    Scott
