I am using the zephyr\samples\subsys\nvs example.
By default the program stores data in internal flash in storage_partition.
I would like to create a custom board file for my board. I am using nrf52840dk board.
However when I create a custom board using the nrfconnect menu on VSCode and using sdk 3.0.2 the program doesn't run at all.
The default dts that is generated once I create the custom board is as follows:
#include <nordic/nrf52840_qiaa.dtsi>
#include "nvs_test_sdk3-pinctrl.dtsi"
model = "Nvs Test";
compatible = "Gearbox,nvs-test-sdk3";
chosen {
zephyr,sram = &sram0;
zephyr,flash = &flash0;
zephyr,code-partition = &slot0_partition;
zephyr,flash-controller = &flash_controller;
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x00000000 DT_SIZE_K(48)>;
slot0_partition: partition@c000 {
label = "image-0";
reg = <0x0000c000 DT_SIZE_K(472)>;
slot1_partition: partition@82000 {
label = "image-1";
reg = <0x00082000 DT_SIZE_K(472)>;
storage_partition: partition@f8000 {
label = "storage";
reg = <0x000f8000 DT_SIZE_K(32)>;
Is there something that I need to enable in my devicetree visual editor inorder for my program to use internal flash using the custom board that i created
