Hello Nordic team,
we are using a nRF52820 module in a beacon. After flashing the firmware and connecting via nRF Connect for Mobile, we can read the Service and Characteristic list. However, performing a write operation fails when the supply voltage is below 2.8V.
We have confirmed that this issue occurs when the supply voltage is below 2.8V.
When powered above 2.8V, configuration changes work normally.
Could you please advise if there is any known voltage threshold or internal limitation in nRF52820 that prevents writing configuration data below 2.8V?
Or could this be related to flash write operation voltage levels?
Additional Information:
nRF52820 module
Firmware: Custom beacon firmware based on SDK 2.5.0
Supply voltage: 1.8–3.0V (problem occurs below 2.8V)
Tool: nRF Connect for Mobile (iOS/Android version)
Thank you in advance for your support.
