Bluetooth pairing fails when running sample peripheral_cts_client
I am trying to run the sample using NCS v2.5.0. This is what happens on the console when I try to connect from the dongle, when running the Test Procedure:
The discovery procedure succeeded
Security failed: E3:FE:4E:E0:6D:C5 (random) level 1 err 4
Pairing failed conn: E3:FE:4E:E0:6D:C5 (random), reason 4
Disconnected from E3:FE:4E:E0:6D:C5 (random) (reason 0x16)
Please advise. I don't have much BLE experience. Thank you.
Burt Silverman
  • It seemed to connect once after a "west flash --erase" rather than a "west flash". But it only paired once and then failed. And I never saw any time data, and it only paired once so it's impossible to experiment and see what is going on. I know nothing much about Bluetooth other than I have used devices that pair, and as a user I would have no access to reflashing let alone with a --erase, and it's not like I have to discard the device after one usage. So, what the heck is going on here???
  • Pairing failed because the dongle still had old bonding keys after you erased and re-flashed the board. Delete the bond on the dongle as well, then pairs again. The CTS example is a client and it only prints time when it connects to a device that provides CTS service, such as a phone or some other device that is broadcasting CTS service.
    Did you make sure that you have Settings enabled in your prj.conf for persistence key storage?
    CONFIG_BT_SETTINGS=y
    CONFIG_SETTINGS=y
  • I will give up with CONFIG_BT_SMP=n and stick with the original. But I am about to give up entirely. It would be helpful to me if you could go through the test procedure yourself and then tell me step by step where it is possible for something to go wrong--anything that may be missing from the instructions (assumptions made by an experienced person). The other question I can ask--what if rather than use the dongle and Bluetooth Low Energy application from nRF Connect for Desktop, I wish to use one of your phone apps. I would need a step-by-step procedure. For example, with BLE app we copy the file cts_central.ncs by using capabilities built into the BLE app, but what's the corresponding method if we wish to use the appropriate Nordic iPhone app? Thanks, Susheel.
    Burt
  • I am setting CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE so at least I can get a bonded encrypted unauthenticated link. I added some printk statements to the standard LOG_DBG. Why can't I read the Current Time? Why am I getting Invalid Argument -22 return at the bottom:
    [00:14:05.686,340] <dbg> bt_smp: smp_pairing_req: req: io_capability 0x03, oob_flag 0x00, auth_req 0x09, max_key_size 0x10, init_key_dist 0x01, resp_key_dist 0x01
    smp_pairing_req() called get_pair_method(); method=0 (0==JUST_WORKS)
    [00:14:05.686,431] <dbg> bt_smp: smp_pairing_req: rsp: io_capability 0x03, oob_flag 0x00, auth_req 0x09, max_key_size 0x10, init_key_dist 0x00, resp_key_dist 0x00
    [00:14:05.731,567] <dbg> bt_smp: bt_smp_recv: Received SMP code 0x0c len 64
    [00:14:05.731,597] <dbg> bt_smp: smp_public_key:
    [00:14:05.746,459] <dbg> bt_smp: bt_smp_recv: Received SMP code 0x04 len 16
    [00:14:05.746,459] <dbg> bt_smp: smp_pairing_random:
    [00:14:05.758,850] <dbg> bt_smp: bt_smp_dhkey_ready: 0x20004c4c
    [00:14:05.761,444] <dbg> bt_smp: bt_smp_recv: Received SMP code 0x0d len 16
    [00:14:05.761,474] <dbg> bt_smp: smp_dhkey_check:
    [00:14:05.763,519] <dbg> bt_smp: sc_smp_send_dhkey_check:
    bt_conn_security_changed() entered hci_err=0(31==BT_HCI_ERR_UNSPECIFIED) err=0
    [00:14:05.831,085] <dbg> bt_smp: bt_smp_encrypt_change: chan 0x20001fdc conn 0x20001d08 handle 11 encrypt 0x01 hci status 0x00
    [00:14:05.831,115] <dbg> bt_smp: smp_pairing_complete: got status 0x0
    Pairing completed: E3:FE:4E:E0:6D:C5 (random), bonded: 1
    Security changed: E3:FE:4E:E0:6D:C5 (random) level 2
    Cannot read Current Time: E3:FE:4E:E0:6D:C5 (random), error: -22
    a little more detail using printk's...no matter what I try to enter into the BLE Application, I end up with
    button_changed() about to bt_cts_read_current_time
    bt_cts_read_current_time() about to bt_gatt_read(...)
    bt_cts_read_callback() err=0
    current_time_decode() length=1 expected length=10
    read_current_time_cb() entered...err=-22
  • I have solved the problem of the time not getting to the client. It was the user interface on BLE App. When you fill in the 10 byte Time, you have to press the check mark--I'm not sure if it is after or before hitting the Write button--regardless, the poor instructions in the documentation do not describe the user interface properly--no mention is made about the check box.
    In order to not get screwed up with double bonding I added
    CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
    to my prj.conf. Please advise of any other possibilities that will protect me from having to re-flash. Also, please have the documentation team correct the instructions in the documentation to make them idempotent. I should be able to run through the test procedure as written multiple times without a severe error that requires re-flashing. Thank you.
    Burt Silverman
    Maybe create a button event if your board has a button to clear out all or some bonds when needed? I am not sure, there are many ways to do it but that depends on your product and application.
    Keep one identity for stable testing, or set CONFIG_BT_ID_MAX and switch identities to repeat tests.
  • Thank you, Susheel. I think I have to learn and get a better understanding of how to use the BLE Application to check for bonds and/or remove bonds on one or both sides of the connection. I know there is online documentation for the BLE Application--it seems like it was a bit sketchy in this area, but I will have to go back and check.
    Burt
