Wi-Fi Throughput when device is in AP mode?
Hi
I noticed nordic provides Wi-Fi: Throughput to evaluate the throughput when device is working in STA mode.
If I want to evaluate the device in AP mode, is there any samples?
Thanks!
  • Hi
    Could you give me more details? How could we use the DK in AP mode? Does it simply turn on  CONFIG_NRF70_AP_MODE = y in the project config?
    # Copyright (c) 2023 Nordic Semiconductor ASA
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF70=y
    # WPA supplicant
    CONFIG_WIFI_NM_WPA_SUPPLICANT=y
    CONFIG_NET_L2_WIFI_SHELL=y
    CONFIG_NET_ZPERF=y
    CONFIG_NET_ZPERF_SERVER=y
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_LOG=y
    CONFIG_NET_IPV6=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_NET_DHCPV4=y
    CONFIG_DNS_RESOLVER=y
    CONFIG_NET_STATISTICS=y
    CONFIG_NET_STATISTICS_WIFI=y
    CONFIG_NET_STATISTICS_USER_API=y
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    # Below section is the primary contributor to SRAM and is currently
    # tuned for performance, but this will be revisited in the future.
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NRF70_RX_NUM_BUFS=16
    CONFIG_NRF70_MAX_TX_AGGREGATION=4
    CONFIG_NET_TC_TX_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=4
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=5
    CONFIG_NET_MAX_CONTEXTS=5
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_INIT_STACKS=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_SHELL=y
    CONFIG_NET_SOCKETS_POLL_MAX=12
    # Memories
    CONFIG_MAIN_STACK_SIZE=5200
    CONFIG_SHELL_STACK_SIZE=5200
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_NET_RX_STACK_SIZE=4096
    # Debugging
    CONFIG_STACK_SENTINEL=y
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    CONFIG_SHELL_CMDS_RESIZE=n
    #CONFIG_DEBUG=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF=y
    # Kernel options
    CONFIG_ENTROPY_GENERATOR=y
    # Logging
    CONFIG_LOG=y
    CONFIG_PRINTK=y
    CONFIG_SHELL=y
    CONFIG_SHELL_GETOPT=y
    CONFIG_DEVICE_SHELL=y
    CONFIG_POSIX_TIMERS=y
    CONFIG_DATE_SHELL=y
    CONFIG_NET_CONFIG_AUTO_INIT=n
    CONFIG_WIFI_CREDENTIALS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NVS=y
    # printing of scan results puts pressure on queues in new locking
    # design in net_mgmt. So, use a higher timeout for a crowded
    # environment.
    CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
  • Here are some configs that have been used for this in the past:
    Sta compilation command - nrf/samples/wifi/shell
    west build -p -b nrf7002dk/nrf5340/cpuapp -- -DEXTRA_CONF_FILE=overlay-zperf.conf -DCONFIG_NET_PKT_BUF_TX_DATA_POOL_SIZE=20000 -DCONFIG_NET_PKT_BUF_RX_DATA_POOL_SIZE=90000 -DCONFIG_NRF70_RX_NUM_BUFS=64
    cat overlay-zperf.conf
    CONFIG_NET_ZPERF=y
    CONFIG_ZVFS_OPEN_MAX=20
    # Zperf TCP=6, UDP=2, Others=1
    CONFIG_NET_SOCKETS_POLL_MAX=20
    # Sockets: select + poll take up more stack
    CONFIG_NET_MGMT_EVENT_STACK_SIZE=4600
    # Optimized networking settings for performance
    CONFIG_NET_PKT_RX_COUNT=64
    CONFIG_NET_BUF_RX_COUNT=64
    CONFIG_HEAP_MEM_POOL_SIZE=40144
    CONFIG_NRF_WIFI_CTRL_HEAP_SIZE=20000
    CONFIG_NRF_WIFI_DATA_HEAP_SIZE=180000
    CONFIG_NRF70_QSPI_LOW_POWER=n
    # To enable optimization configuration options
    CONFIG_PICOLIBC_USE_MODULE=y
    CONFIG_SPEED_OPTIMIZATIONS=y
    # Necessary for zperf_tcp_receiver.c
    CONFIG_NET_CONFIG_SETTINGS=y
    CONFIG_NET_CONFIG_INIT_TIMEOUT=0
    # Zephyr NET Connection Manager Connectivity layer.
    CONFIG_NET_CONNECTION_MANAGER=n
    # Consumes more memory
    CONFIG_WIFI_CREDENTIALS=n
    CONFIG_FLASH=n
    CONFIG_NVS=n
    CONFIG_SETTINGS=n
    CONFIG_NRF70_UTIL=y
    # Disable rate limiting to avoid log flooding (default is drop)
    CONFIG_LOG_RATELIMIT=n
    SAP compilation command nrf/samples/wifi/shell
    west build -p -b nrf7002dk/nrf5340/cpuapp -- -DCONFIG_NET_DHCPV4_SERVER=y -DCONFIG_NET_ZPERF_SERVER=y  -DCONFIG_NET_PKT_BUF_TX_DATA_POOL_SIZE=90000 -DCONFIG_NET_PKT_BUF_RX_DATA_POOL_SIZE=13000 -DOVERLAY_CONFIG=overlay-sap.conf -DCONFIG_NRF70_RX_NUM_BUFS=16
    cat overlay-sap.conf
    CONFIG_NRF70_AP_MODE=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_AP=y
    CONFIG_NET_ZPERF=y
    CONFIG_ZVFS_OPEN_MAX=16
    CONFIG_NET_PKT_TX_COUNT=64
    CONFIG_NET_BUF_RX_COUNT=8
    CONFIG_NET_BUF_TX_COUNT=128
    CONFIG_HEAP_MEM_POOL_SIZE=43000
    CONFIG_NET_ZPERF_MAX_PACKET_SIZE=1500
    CONFIG_FLASH=n
    CONFIG_NVS=n
    CONFIG_SETTINGS=n
    # IP is mandatory for successful STA connection
    CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.1"
    CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
    CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
    # Disable DHCPv4 client
    CONFIG_NET_DHCPV4=n
    # Enable DHCPv4 server
    # Temporarily enable FS support so that linking succeeds.
    CONFIG_FILE_SYSTEM=y
    CONFIG_MBEDTLS_HEAP_SIZE=1024
    Zperf commands
    STA- UDP-RX- zperf udp download 8001
    SAP- UDP-TX - zperf udp upload 192.168.1.2 8001 10 1472 20M
    Elfving
