I'd like to send/receive data over UART using the expansion board connector of my Thingy:91 X (pins 0.18 & 0.19 as RX/TX). With SB8&9 separated (to isolate pins from I2C), I can without problems send messages using uart_poll_out and read them with another device. However, I never receive anything with uart_poll_in, although I can measure the UART signal on TP32/33 with an oscilloscope. I've also tried to switch the pins in the overlay and on hardware side, but still - sending works, receiving not. Attached my code, could you please support?
Simon
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/uart.h>
#include <string.h>
#define UART_NODE DT_NODELABEL(uart0)
#define RX_BUF_SIZE 128
/* Simple helper to send strings over UART using poll_out */
static void uart_send(const struct device *dev, const char *msg)
while (*msg) {
uart_poll_out(dev, *msg++);
/* Add CRLF for nicer formatting */
static void uart_send_line(const struct device *dev, const char *msg)
uart_send(dev, msg);
uart_poll_out(dev, '\r');
uart_poll_out(dev, '\n');
void main(void)
const struct device *uart_dev = DEVICE_DT_GET(UART_NODE);
if (!device_is_ready(uart_dev)) {
/* If UART not ready, we can’t print anywhere else */
return;
uart_send_line(uart_dev, "UART echo example started!");
uart_send_line(uart_dev, "Type something and press Enter...");
uint8_t c;
char rx_buf[RX_BUF_SIZE];
size_t idx = 0;
while (1) {
/* Non-blocking read of one character */
if (uart_poll_in(uart_dev, &c) == 0) {
if (c == '\r' || c == '\n') {
if (idx > 0) {
rx_buf[idx] = '\0';
uart_send(uart_dev, "Echo: ");
uart_send_line(uart_dev, rx_buf);
idx = 0; // reset buffer
} else if (idx < sizeof(rx_buf) - 1) {
rx_buf[idx++] = c;
uart_poll_out(uart_dev, c); // local echo while typing
} else {
k_sleep(K_MSEC(10)); // avoid busy loop
