nRF SDK Device Tree Editor problems
I am trying to make a custom board device tree for evaluation of some new parts and am struggling.  I have attached the Schematic as reference sine this is only for part discovery there is nothing proprietary.  I seem to be having issues on adding my sensors (BMP585 & ADXL367) as children to spi0.  I am also curious why nRF SDk for VS Code DeviceTree Visual Editor puts all pinctrl data in the .dts file instead of using the .dtsi file?
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
#include "PCB7410_10_006-pinctrl.dtsi"
	model = "PCB7410-10-006";
	compatible = "InstantCare,PCB7410-10-006";
	chosen {
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	leds {
		compatible = "gpio-leds";
		grn: grn {
			gpios = <&gpio0 2 GPIO_ACTIVE_LOW>;
			label = "GRN";
		red: red {
			gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
			label = "RED";
	buttons {
		compatible = "gpio-keys";
		sw2 {
			label = "SW2";
			gpios = <&gpio0 20 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
	sounders {
		SN1: SN1 {
			gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
			label = "SN1";
		SN2: SN2 {
			gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
			label = "SN2";
		SN3: SN3 {
			gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
			label = "SN3";
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 DT_SIZE_K(48)>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000c000 DT_SIZE_K(220)>;
		slot1_partition: partition@43000 {
			label = "image-1";
			reg = <0x00043000 DT_SIZE_K(220)>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 DT_SIZE_K(24)>;
&gpio0 {
	status = "okay";
&uart0 {
	status = "okay";
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
	current-speed = <115200>;
&spi0 {
	status = "okay";
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
	adxl367@0 {
		compatible = "adi,adxl367";
		reg = <0x0>;
		spi-max-frequency = <8000000>;
		cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>; // Is this how to do CS?
		int1-gpios = <&gpio0 12 0>; // Is this the INT pin?
	bmp585@1 {
		compatible = "bosch,bmp585";
		reg = <0x1>;
		cs-gpios = <&gpio0 14 GPIO_ACTIVE_LOW>; // Is this how to do CS?
		int1-gpios = <&gpio0 11 0>; // Is this INT pin?
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 26)>, <NRF_PSEL(UART_RX, 0, 27)>;
	uart0_sleep: uart0_sleep {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 26)>;
	spi0_default: spi0_default {
		group1 {
			psels = <NRF_PSEL(SPIM_MISO, 0, 17)>,
			        <NRF_PSEL(SPIM_MOSI, 0, 16)>,
			        <NRF_PSEL(SPIM_SCK, 0, 15)>;
	spi0_sleep: spi0_sleep {
		group1 {
			psels = <NRF_PSEL(SPIM_MISO, 0, 17)>;
SCH_7410_10_006.pdf
    Technically your original definition should be in a .dtsi file, and any overriding of such, should be in a overlay. Both will however work.
    cs-gpios is an array that shall belong to the root node, ie spi0 in this case:
    &spi0 {
    	status = "okay";
    	pinctrl-names = "default", "sleep"
    	cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>, <&gpio0 14 GPIO_ACTIVE_LOW>;
    	adxl367@0 {
    		reg = <0x0>;
    	bmp585@1 {
    		reg = <0x1>;
    Please note that you are referencing a sensor that is not present in zephyr/ncs. The "closest" you get here is the bmp581 sensor. I would recommend that you ask the manufacturer about the differences and possibly if they have a zephyr rtos based driver for you.
    Håkon
  • Thank you for the suggestion.  I have reached out to Bosch about the BMP585 driver.  I am still confused though how the cs-gpios are just an array in the root spi0 node.  How do they then get associated to the correct respective sub-nodes?  Can you point me to some example code that uses a shared SPI Bus like this?
    cs-gpios is an array, and the "reg" variable, and the sensor@index will look up the corresponding index in cs-gpios array.
    index 0 is in bold and index 1 is underlined:
    adxl367@0 {
    reg = <0x0>;
    bmp585@1 {
    reg = <0x1>;
    The code itself will use device tree defines/macros:
    https://docs.zephyrproject.org/latest/build/dts/api-usage.html
    For the adxl367, the referencing is here:
    https://github.com/nrfconnect/sdk-zephyr/blob/ncs-v3.1.1/drivers/sensor/adi/adxl367/adxl367.c#L1185-L1188
    Håkon
