APPROTECT unclarities for NRF9151
I have some unclarities for the APPROTECT mechanism on NRF9151.
Basically, I had a misunderstanding of the involved CONFIG features, and as a result I used CONFIG_NRF_APPROTECT_LOCK. However, the idea was that we could still unlock app protection via an OTA firmware update. This seems not possible now (since ERASEPROTECT is also enabled).
- Apparently, enabling CONFIG_NRF_APPROTECT_LOCK also implies that the UICR.APPROTECT is written to 0. I could not find where this is documented or explained. I was under the assumption that the UICR was not changed, so it would be possible to unlock the protection via FW update that sets NRF_APPROTECT_S->APPROTECT.DISABLE. properly. But apparently that's not the case. I could also not find in the code where this is executed. It's not applied in "system_nrf91_approtect.h".
- The reset value of UICR.APPROTECT is not 0xffffffff, but 0x50FA50FA. This is confusing (https://docs.nordicsemi.com/bundle/ps_nrf9151/page/uicr.html#ariaid-title3). It also means that the "hardware and software" AP-Protect implementation type of the table on https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/security/ap_protect.html is not enabled by default on NRF9151, on the contrary.
- To me, the table at https://docs.nordicsemi.com/bundle/ps_nrf9151/page/dif.html#d425e281 is not clear. I assume now that it means for the "debugging possible" rows, all conditions must be true whereas for the "No debugging possible" rows, debugging is not possible as soon as 1 of the conditions is true. Is this correct?
- Also on https://docs.nordicsemi.com/bundle/ps_nrf9151/page/dif.html, APPROTECT.DISABLE and APPROTECT.FORCEPROTECT eventually are the same register, but that's pretty hard to understand from the text until you look either to the code or the effective address. What's the reason for this split?
I suppose that there's no way for me to recover the devices (i.e. enable debug access) that were flashed with CONFIG_NRF_APPROTECT_LOCK? That's not a disaster, since they will later be used in the field, but it would be nice to know.
S.
