I started off doing a v3.1.1 build and got this serious warning message
warning: BT_CTLR_DTM_HCI (defined at subsys/bluetooth/controller/Kconfig.dtm:14) was assigned the
value 'y' but got the value 'n'. Check these unsatisfied dependencies: BT_CTLR_DTM_HCI_SUPPORT (=n).
See docs.zephyrproject.org/.../kconfig.html and/or look up
BT_CTLR_DTM_HCI in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
Because my colleague is using nRF SDK v3.0.2, I switched to that and found even more warnings: the one mentioned above is preceded by
warning: UART_1_NRF_HW_ASYNC (defined at drivers/serial/Kconfig.nrfx_uart_instance:51) was assigned
the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
(!UART_NRFX_UARTE_ENHANCED_RX) (=n). See
UART_1_NRF_HW_ASYNC in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: UART_1_NRF_HW_ASYNC_TIMER (defined at drivers/serial/Kconfig.nrfx_uart_instance:83) was
assigned the value '2' but got the value ''. Check these unsatisfied dependencies:
UART_1_NRF_HW_ASYNC (=n). See
UART_1_NRF_HW_ASYNC_TIMER in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
I have to take all these warnings seriously. Past experience is 1) they usually happen only if I modify off the shelf prj.conf (no mods being done here) 2) I won't end up with what I asked for if I ignore the warnings.
Aside, it took me a few tries to convince my colleague that they exist--he assumed that they would be colored. So I would say that it would be a big help for everybody if they <were> colored yellow or something similar.
Please help me proceed! Thanks.
Burt Silverman
